---- ALL SOLD -----
Up for sale I have a 1600+HP Blow Through E85 Carb system.
CSU 850CFM carburettor built for E85. This carb is equipped with dual needle and seat bowls, dual CSU proprietry boost referenced power valves, and annular discharge boosters.
CSU polished aluminium intake hat.
HVC super sucker intake manifold spacer.
Aeromotive 4 port EFI-to-carb boost referenced fuel pressure regulator.
Holley accelerator cable bracket modified to suit the dual needle fuel bowls.
Brother and I had the 350 SBC wound up to 1150 moroso HP carefully winding in the tune and the standard case powerglide called in sick...
Anyhow the plans escalated from new glide to rebuild engine while it was all apart. Now the mischief being plotted will not suit this carb anymore...![]()
$2100ono for everything you need to build a killer blow through turbocharged engine! (The carb alone cost $1800US plus delivery!)
Located in Rockhampton Qld. In todays age freight can easily be arranged!
Contact Jason by PM or 0438154499
Cheers,
Jason
