Results 1 to 19 of 19
Thread: Spool time gt42 on ls1
    Registered User GMMAD's Avatar
    nowra
    231
    Anyone know when you would see full boost(10psi) with gt42 t4 1.10 on a stock LS1 manual
    And when woul it start to get boost
    Jul 2005
    643
    Don't know about a GT42. But a GTX42 is the way to go. It spools the same as a T04Z on an LS1 full boost by 4000rpm. GT42 will be a fair bit slower than that.
    I make 550whp @ 12psi and 621whp @ 14psi on a stock LS1 with valve springs and rod bolts with E85. Gets driven everyday and done 22,000km turboed and 152,000km in total.
    Rides:
    Ultima GTR
    BMW E46 M3 Turbo 570rwhp @18psi Eflex
    Holden VY SS 1004.6rwhp @ 28psi Eflex
    Ford Escort Mk2 2JZGTE 600rwhp @16 psi Eflex
    04 Yamaha R1 154.3rwhp
    For Sale:
    AP Racing 6 Spot Calipers = $1,500
    2JZGTE intake Manifold complete with all sensors $150
    13,537
    Isn't the GTX series designed for high-boost applications?
    infantile egomaniac CussCuss's Avatar
    Old Pac
    5,823
    I was under that impression also, no real benifit unless you are almost off the compressor map.
    this signature intentionally left blank
    13,616
    Quote Originally Posted by 0x2DLVR View Post
    how do you figure that??/
    last gt42 i did was full boost at 3900rpm with a .96 rear housing.. ran 137mph in a full weight VY on street tyres.. on petrol not E85 too..
    nowra
    231
    thanks guys I might look for something a little smaller thats is a bit laggy for my liking
    VT clubsport LS1 M6
    VK calais LS1 turbo M6
    turbo V6 3.8 4runner build
    KTM 520/540 BB
    Registered User prasac's Avatar
    Dec 2009
    Little Sudan
    1,028
    Quote Originally Posted by GMMAD View Post
    check out the range of Precision PT67's comes with all different size exhaust wheels, 900-1000hp turbo, will spool up very quick. seen a fair few LS guys in the US use them.
    Jul 2005
    643
    GTX is billet comp wheel as well. Lighter wheel spins quicker. You know the rest
    Rides:
    Ultima GTR
    For Sale:
    Jul 2005
    643
    Quote Originally Posted by 10sec rx7 View Post
    My GTX is a 1.10A/R is I'm guessing a GT with the same A/R rear would be slower to spool. And since the original poster asked about a 1.10A/R then what I said was valid.
    Rides:
    Ultima GTR
    For Sale:
    13,537
    hmm i think i'd prefer the better efficiency at the lower airflows - and sacrifice the performance at 50psi on an LS1..
    13,616
    Yours will be the new housing.. Which is smaller than the old .96.. The old housing was a T6 inlet and was massive
    are hairy dogsballs's Avatar
    3,042
    i would of thought it'd spot on. but meh!
    Quote Originally Posted by FatBoy View Post
    Blowjobs are like pizza - even when they're not that great they're still pretty good...
    Arrogant wankeler
    Lithgow/Newcastle
    211
    Posts maps to "prove his point" obviously doesn't actually look at them in detail. Check the efficiency numbers or where they cross pressure & mass flow lines? That clearly indicates say between 1.5-2 PR (your 7-15psi "low boost" range) that the GTX compressor map is wider and at a higher efficiency point (albeit maybe only a % point or 2, which equates to maybe 3-4% operating efficiency improvement) pretty much everywhere than the cast wheel, but extends beyond it at the same efficiency levels. More total flow, no loss in the bottom end, almost like an improved design you might say, rather than just a different wheel trim of the same technology?
    13,537
    I don't see that they both peak at 77% at a pr of 2, but the GTX requires the engine to take more air.. - i see the gtx goes to a slightly higher airflow at a pr of 2.. the gtx does do it with a few less shaft rpm.. I still think for a streeter (without headwork etc) the GT42 is probably better.
    but hey - im just a nerd at a keyboard - so if you have experience that tells you otherwise - please tell me.
    nowra
    231
    Quote Originally Posted by prasac View Post
    yeah Ive been looking at the precisions only problem there over the 1k mark so ill get hit with taxs and import duty
    I seriously looking at the turbonetics TC78 with a 1.15 rear spools very quick and makes good numbers
    I dont want huge figures around 400rwkw mark and ill be happy ..in a VK it should go well
    VT clubsport LS1 M6
    KTM 520/540 BB
    Arrogant wankeler
    Lithgow/Newcastle
    211
    Guess I was a bit tired & grumpy this morning. Realistically there is SFA between them for most of the map width.
    13
    GTX is the best
    No hybrid, No care! <---cop's Avatar
    Nov 2007
    あなたの娘
    4,613
    No. Your* the best.
    And then..... cunts outta nowhere!
    日産シルビアS13 古い学校 1809cc/131ps - RIP 1989-2013
    The worst disasters of all time;
    1: Cairns loses mobile phone and data services for three hours
    2: The Holocaust
    3: September 11
    No 1gz no care Cracka's Avatar
    Laying 11's
    3,473
    Lol at arguing with dale about it.
