Results 1 to 3 of 3
Thread: RA28/RA23 1G conversion package
    Oct 2004
    Ipswich
    120
    As per gumtree ad, I'm selling my 1G from my RA28
    http://www.gumtree.com.au/s-ad/karal...age/1002266532
    1991 Gen 3 1G-GTE 2L twin cam twin turbo inline 6.
    Timing belt, plugs and rear main seal were replaced <5000kms ago. Turbos in good condition, no shaft play when installed.
    Wiring loom, Coil, AFM and factory ECU. Everything needed to wire into your Celica. Can supply wiring diagrams.
    300mm x 600mm aftermarket intercooler. Pipes to suit.
    Manual bellhousing to suit W58 gearbox, throwout bearing, fork, flywheel and exedy clutch.
    Dump pipe with flange for cat converter to suit RA2*
    1G-GE engine mounts and new 18R lower mounts to bolt straight onto your celicas crossmember.
    Sump has been massaged to clear steering arm.
    $1200
    0413 348 668
    Nowra
    35
    G'day you know if this would fit a TA22? I know that they have a shorter front end but just interested anyway.
    Oct 2004
    Ipswich
    120
    Alot of work by the sounds of things. Quote from toymods:
    Ive done a 1G-GTE into TA22 conversion. Its easier than doing a 3SGTE to rear wheel conversion. Just bang and whack the firewall till you think you got enough space for the gearbox to fit. Engine is quite long so the main pulley just sits on top of the front frame about 10mm. Main pulley has to be modified. I machined away a few mm to make diameter smaller just enough for belts to go around safely. The 'mid type' oil sump was changed with the 'front type' and slightly modified to clear the sway bar or you could just remove the sway bar like my friend did. The radiator has been pushed foreward together with the aircond condensor and the intercooler. I cant fit the front grill though. Lost of original stuff has to be cut away so the engine can go straight in after taking out the front bumper and stuff in the front. Oh ya .. both mounts on engine and crossmember have to be custom made. I have been using the car for almost 3 years now and so far no problems. Total costs include wiring, exhaust, engine in $3030 and a little patience. You can see some old pics here .. not so detail though
    http://forums.toymods.org.au/index.p...t=0#msg_392481
