Results 1 to 12 of 12
Thread: Buick V6 assembly question
    Useful cunt littlefireyone's Avatar
    North QLD
    1,054
    So I was cleaning the VR's said block to put the heads back on when I ran the air gun into the head bolt holes....and coolant spewed out of the galleries. I was peaking that the block was fucked but apparently that's not the case it's just some gumby design where you have to seal the head bolts to stop coolant rusting the bolts ect.
    I don't have the genuine holden stuff and at a guess couldn't get any till Tuesday, is there something non genuine that I can use for this purpose? no.3 aviation gasket sealant perhaps?
    10,297
    look at bogandaves VK thread, A few products got mentioned to use, but from memory TK swears by the GM stuff
    Some say he's roger cordia without the disability pension and shaving cream, others say his bus windows are licked clean every day - all we know is he's called boothy.
    I have CDO. It's like OCD except the letters are in alphabetical order, as they should be
    i have sexdaily, i mean dyslexia
    Liiive action! Mr Jones's Avatar
    Opium den
    1,926
    Yeah the gm stuff is the go, although from the smell of it I wouldn't be surprised if its just a can of contact adhesive… you could try the aviation stuff but no guarantees. I think glenno also started a thread not long ago about alternatives because he didn't want to pay $50 for the gm stuff. Personally I'd wait and get the right shit
    Hold it flat cunt
    Opium den
    1,926
    Also Chevs have this same retarded feature so google and Americans may be able to help with alternatives
    Hold it flat cunt
    740
    Just buy the Holden goo, Ive used it heaps of times and its worked perfectly every time.
    deep south, NSW
    2,058
    Any sort of engine thread sealant will do the trick. I know I never used the genuine stuff and the engine made about 450hp (single turbo).
    I love cable ties. Steve's Avatar
    10,144
    I'd probably drain the block before using any sort of sealant into coolant galleys. There's a 10mm bolt goes into each side of the block right in the middle are the drains.
    Auto Electrical Accessory fitting in Brisbane!
    http://securityandaudio.hopout.com.au
    Registered User Glenno's Avatar
    Hiding
    6,029
    I used Permatex high temperature thread sealant based on a few American forums in the last buick I did its still running around fine. Holden goop is $70 a can.
    PM me for more info
    deep south, NSW
    2,058
    Quote Originally Posted by Glenno View Post
    Permatex rings a bell with me also
    North QLD
    1,054
    Thanks guys, I'll go find some of this stuff
    Brobdingnagian Member Passion-Fingers's Avatar
    Darwin, NT
    1,694
    I used permatex #2 non hardening compound on my chev after much googling. hasn't run yet so no idea if have leaking headgasket/pingu issue.
    HTH.
    '06 Mitsu Pajero DiD - Daily and Boat tow rig
    HQ SS - rollin' on 14's
    North QLD
    1,054
    The parents are paying since it's their car so I went with the holden stuff ($50) which co indecently is branded aldecco shit I've seen all the batteries round the place getting switched to. Must be part of Govco's master plan to save holden....
