(iVtec) Yo, thought I would make a new build thread for my 91 Integra. I have owned it for about 5 years, was my second car and my first "nice" one. Will be built to under 2L IP specs, initially with the stock engine then will be having a K20A slotted in. Cage is complete except for dash and harness bar which should be easy enough to get added, all done by Walker chassis (2.5k which wasn't bad I thought). The current U2L pace is 1:20 at Mallala, this has done 28's on semis stock, so a fair bit of "quickening" will be needed.
First job is interior fit out (seat - not the one in the pics lol, paint, dash etc) then brakes (either oem honda or forged willwoods, running a 15in wheel) and suspension (fairly set on the ground control koni yellow/coilover sleeve setup). Then pretty up the outside, fit a new clutch, maybe weld the diff and do some practice days/sprints and dial it in. While this happens Ill be picking up K20A stuff as it comes up for cheap, this car most likely wont race until the K20 is in. Obviously lots of other little things will need to be done, but it should be a simple, reliable and fast little car. Ill update with pics etc once I get home and as I go, these are just pics that my brother took after it got the cage done.
Cheers,
Jeff
Reply With Quote.jpg)
