Page 3 of 5 FirstFirst 12345 LastLast
Results 61 to 90 of 126
Thread: 4 link info
    1,316
    Thanks Cheap..
    @ RogerRider; Certainly simpler packaging than a Peaucellier link...
    What happens if the gears get a stone in the mesh though?
    2,175
    Quote Originally Posted by Momus View Post
    Thanks Cheap..
    true
    maby shielding around the gears
    but yea i meant in packaging sense
    Jun 2006
    Ararat
    2,922
    Attachment 57828
    OK. This is another one that has actually been fitted to cars.
    There is a tarmac rally RX3 that I did a cambered full floater for out in the wild with one of these Grasshopper or Scott-Russell straight line (nearly) linkages.
    Old mate did the suspension and the fit up of the linkage as shown in the upside down non animated picture.
    The swinging green link is exactly twice as long as the anchored blue one and the slide arangement involves a channel and track rollers. The free end of the green link is attached to the diff with the rest mounted to the body. On the dif I did, but never saw as a finished install, it had been done with the slider/blue link on the diff and the free end to a panhard bar type chassis mount. I considered this to be wrong for a couple of reasons.
    @ Billzilla.
    The WOB rocker looks like it would be fairly easy to integrate into that space frame either as a double shear mounting or probably more conveniently in single shear. I use a slotted mount with a serrated plate and washer for incremental adjustment and positive lock.
    That diff housing has seen some action. Looks to be pie slice cambered at the tube junction. On the WOBs I have done it was convenient to mount the short top horizontal link to bracket on the housing web in single shear and the lower one 110 below it (the rocker is made on 110 mm centers; 220 overall) tying into the coil over mount in double shear and both with several vertical mounting holes.
    would have similar constraints as jacob's ladder wouldn't it? better for something that turns one way, so it is in tension, not compression?
    Trendsetter is awesome cheapracer's Avatar
    Jan 2010
    Sichuan Province, China
    2,063
    Panhard Rod, Watts link and others are all in tension and compression.
    Or you could just piss off all the complication and weight entirely ..
    DON'T PANIC Gammaboy's Avatar
    8,481
    Ah, the old sliding block. Never seen it used beyond the dedion on the mid engined Bugatti GP car, and Alfa GTA/GTAms...
    Jan 2010
    2,063
    Yup except it's a roller bearing of course.
    Not sure why I haven't seen it before (not saying someone hasn't), seems so logical and simple but of course not always easy to execute, the GTA looks nightmarish.
    Lister Jag also a famous one that used it as well as Lotus, well "a" Lotus that I know of anyway - but all bronze blocks not rollers .. I find that strange.
    1,316
    The under diff A arm (Lotus Cortina) trunnion upper arm on 105 Alfas and the sliding block in it's various fitments, including BRM GP cars, can all be said to have been of questionable benefit to unsuccesful.
    The Jacobs ladder has a home in American dirt track racing more because of regulation, and tradition than performance benefit. Panhards, leaf springs, inclined arms, either upper or lower all have shortcomings, at least in racing.
    All these and the diff mounted Watt's rocker to my mind have the same weakness; the roll centre is fixed and does not move with the sprung mass centre of gravity. It introduces a varying lever arm length for the roll stiffness and appears to create issues with the roll axis and front suspension and steering.
    Regardless of the reason and almost universally, replacing these with a chassis mounted Watt's or WOB (or I suspect the more complicated and highly loaded Mumford link), seems to iron out handling problems at the rear and turn a car into a driveable machine.
    The Jacob's ladder with suitably long links and mounted on the diff with the 'A' member anchored to the centre of the chassis to give a RC might work but would be cumbersome and still compromised compared to a straight line linkage.
    1,316
    Succesful 105 Alfas rather than faithful GTAM type builds, usually have a chassis rocker Watts for about half the trouble and a quarter the expense of the slide block.
    Jan 2010
    2,063
    Lister did very well actually but doesn't answer my question, why did they all use a troublesome high friction and high stiction bronze slide rather than any type of rolling device ....
    8,481
    Impact loadings flogging the bearing would be my guess?
    8,481
    Oh, and most of what you see is support structure - 105 alfas are very soft structurally once you get further back than the diff. You should see the reinforcing kit for the big endurance tanks.
    canberra
    1,285
    So what are my options with this puppy? I'm happy enough with the front suspension, at least until i run at and see how it goes. I would like to ditch the panard at the rear though and was thinking Wob link. With bugger all chassis at the rear for mounting though it's looking like a major headfark? How about a chassis mounted Watts that sits under the tailshaft?
    GT8
    1UZ Celica
    1.07 flat Wakefield Park
    Forum Adnimistrator
    Feb 2005
    6,194
    best bet surely would be to add more chassis.
    go home helicopter, you're drunk.
    blinks ... Billzilla's Avatar
    Jan 1970
    21,640
    The Panhard is fine thought I'd like it to be a bit straighter fore/aft so the diff moves up/down a bit straighter.
    No need to put a lot of work into something that doesn't really need it.
    Contact me for -
    3D printing in ABS plastic.
    http://www.billzilla.org
    canberra
    1,285
    For sure, less is best and will get me on the track quicker I could move the chassis mounted end easy enough and extend it towards the rear. If i'm going to that effort should i move that mounting point lower as well to make the panard more parallel to the axle line? Any tips on where to try and place the RC ie how far to lower the chassis mount?
    GT8
    1UZ Celica
    Jan 1970
    21,640
    Just make the RC a little higher than the front and try to make the Panhard as parallel to the diff housing at ride height as possible.
    Contact me for -
    canberra
    1,285
    Ta Bill. Given some of the other touches on the car i'm surprised the rear end isn't a tad more thought out? Anyways, i'll measure stuff up and see what can be achieved.
    GT8
    1UZ Celica
    2,019
    Quote Originally Posted by cheapracer View Post
    i cant see how a single roller would work for vertical motion- it still would function as a sliding block
    ie :
    if the roller is constrained by the two vertical guides:
    for the diff to move vertically up- the side of the roller touching the left side of the guide wants to roll anticlockwise, where as the right side guide is trying to roll the roller clockwise
    leading to the outer face of the roller not moving and becoming a slider anyways
    hmmm - or you coul leave a small clearancebetween left and right guides - so one face unloaded with the clearance allowed roller to roll...
    8,481
    If you gave it the same amount of clearance as a sliding block, the unloaded side of the roller would be clear of the guide. Easy.
    Justen, some warped part of me would love to see a 27 T bucket body on that!
    2,019
    lol - editing my post as you replied..
    canberra
    1,285
    It does have a suggestion of that already eh, with that angled ally side panel I'm going to try for minimalist, sorta Atom look, with no attempt at a full body aero package. I'll leave it open wheeled with just a front and rear wing.
    GT8
    1UZ Celica
    Jan 2010
    2,063
    1/2mm is fine for me. I actually gave it zero then welded the braces in expecting pull, it did. I am waiting to see how much it "clangs" and may look to see what composite material rollers are available at a later stage. I have 2 pieces of sacrificial plate lightly welded on for easy replacement as well predicting it will be a high wear area.
    Justen, give me the length, spread and distance apart of your trailing arms and I'll run it through my bind jig.
    And I think the Panhard is fine.
    2,175
    i was thinking a skate board wheel would be nice as a roller just my thoughts
    8,481
    Shhh, Grown ups are talking.
    8,481
    I vaguely recall the GTA guys aiming for less - but see how you go. Incidentally, they mostly run polymer slider inserts set into the bronze block these days.
    1,316
    That skewed and archaic Panhard isn't doing the car justice, and the lack of rear structure seems a bit unsafe.
    My suggestion which I have used to good effect on similar low polar moment coil overs mounted forward Sports Cars and Sports Sedans:
    1,316
    As Gamma said old engineers view rolling element bearings in oscillation or roller skidding conditions with great suspicion.
    The block could just be a lateral application of a working system the designer had succesfull experience with.
    1,316
    Re the use and goodness of the slide block. As Gamma said old engineers view rolling element bearings in oscillation or roller skidding conditions with great suspicion.
    The block could quite easily be a lateral application of a working system the designer hasd succesfull experience with.
    On a different application, an on-car single shear adjustable Watts the slide block guide executed in acetal plastic works ok but getting zero play and fretting, is very hard without going to a difficult gib/slide arrangement in all metal
    canberra
    1,285
    Cheers Momus, that design has appeal. Still pretty simple and also help strengthen up the rear. I was happy to live with panhard based on Bill and Cheapies advice, but with a neat option to ditch it i think this is a better way to go. Plus i get to stamp some input in finishing this thing.
    I'll post up pics as i go to make sure i'm getting it right.
    GT8
    1UZ Celica
    Jan 2010
    2,063
    Indeed that's why the sacrificial plates and the cheapest, most common bearing I could find, maybe an hour's work and $10 every few years.
    Unless it clangs a lot, not fond of clangs.
