Put an LS in it. Don't be a girl.
Do not listen to anything this man says. They are insane, illogical thoughts propagated by us, the voices in his head.
Meh. Timing belts are only a big deal to replace if you have no mechanical nous.
The_Monk, you can't just "pop in" a new ECU without coding it. Some people have transplanted the ECU/BCM/key reader into a car to get around the coding but thats just dumb and too much work to guess what a problem is.
Mechanically they aren't too bad, straight mechanical failure of the short motor/head assembly is pretty rare. Most, if not all problems are timing belt/water pump related or electrical.
Ive fixed more of these than I care to remember...but they're still a shit engine to start with. The car wrapped around it is probably worse than the engine itself.
Hmmmm,
I will put some research into the SR20 and B20 engines
