Page 3 of 7 FirstFirst 1234567 LastLast
Results 61 to 90 of 205
Thread: Charade V6 budget hillclimber
    Mar 2011
    Quindanning WA
    448
    I would rather have a shed full of immobile, spider infested diahatsus than drive a datsun...
    9
    Thats because you have no soul or any sense of class.....
    Mar 2011
    Quindanning WA
    448
    Front suspension is starting to come together. I changed my mind on what to do for the uprights about 5 times but in the end I have made some new ones using some slimline trailer stub axles I had sitting around and using the ball joints I bought to suit the holden uprights. They look like shit but seem pretty solid.
    The new front sub frame is bolted into the car using the original bolt holes. I started with the original subframe and have been cutting out the original pieces out as I welded in the new bits. Probably made it harder than it needs to be but it seems like a good idea to be able to remove the complete front suspension. Its still a work in progress and I need to cut out most of the remaining original pieces and tidy it up once the roll cage is done and the tied into the top of the subframe.
    Currently working on making the coilover for the front so I can finalise the lower control arm attachments and the remainder of the front frame. Want to do the cage after this but I'm thinking I might get side tracked and make a new tube bender first. My bender wont do the main roll hoop and I've been keen for a while to make a new one like the JD2 model 53 so this seem like a pretty solid reason.
    1,609
    Good progress. If you remake the uprights a 6th time consider HQ Holden knuckles. What you are making looks close geometrically.
    Is the fuel tank living in the front sub frame?
    Claimed horsepower sceptic.
    Apr 2003
    Roleystone
    3,385
    Don't know what to say? I have a Charade superlaggera here if you want more.
    GURU ENGINEERING PTY LTD
    Mar 2011
    Quindanning WA
    448
    Quote Originally Posted by Momus View Post
    I'm going to make up some tabs with tapered holes and weld them on for the steering... I thought about using something bolted but it doesn't really seem worth the effort. The uprights are basically copys of a HQ-WB holden with the ball joints moved around to increase KPI and reduce the scrub radius. I had a good look at modifying a holden upright to make it work but I couldn't get the lower joint in the right place.
    Yeah I'm thinking I might make a tank that sits in the subframe... it seems like the ideal spot.
    Don't know what that is but I'm interested. Actually if I hold off what are the chances of you starting a project on it then selling it to me partly done with a bunch of parts? Maybe a LS powered desert rally charade?
    Apr 2003
    Roleystone
    3,385
    SuperKarts are my thing now, Rebuild the whole thing in a day or 2 and very fast at a fraction of the cost.
    How many LS engines you want? NO MORE PROJECTS. Except the 240Z.
    Mar 2011
    Quindanning WA
    448
    Done a bit more on the front suspension... thought I was closer to having this bit finished but there still seems to be a stack of stuff left to do. Got a big old milling machine so my first job on it was to make the brake caliper brackets... came out pretty good i reckon... fuck milling machines are the shit. Also made up the coilovers and had to modify the lower control arms because i fucked up the jig and made them 25mm too long. Had 7 degrees of negative camber and couldn't adjust it out when I test assembled it the first time.
    Now working on the top mounts for the coilovers but looking forward to doing something other than supension.
    Apr 2003
    Roleystone
    3,385
    The men in white suits will be around to get you soon.
    Mar 2011
    Quindanning WA
    448
    Dropping off a couple of LS's for the next project... How thoughtful.
    Actually Zak mentioned that jeff might have the gear to bend the main hoop for the cage... If i make a template of what i want any chance he might be able to give me a hand? I've been feeling pretty motivated to get this finished recently.
    Apr 2003
    Roleystone
    3,385
    Yes we have all cage building gear.
    Mar 2011
    Quindanning WA
    448
    Been plugging away at this.
    Front subframe mostly done including radiator mounts.
    Cut the camry struts apart, threaded the end and made some caps to fit koni inserts.
    Cut most of the rest of the original front end out and still need to go a bit further to clear the wheels at full suspension travel. Left some tabs on the top to tie it back to the cage once its in to stop it folding in half.
    Needs a wash...
    Registered User Drizt's Avatar
    354
    Mother of god
    V8 or GTFO
    Mar 2006
    Not Mt Druitt
    1,267
    Holy Shitballs!
    Registered User jezza323's Avatar
    2,088
    I think you might be broken in the head, in a good way though
    Toyota Starlet
    QR Sprint - 65.9 secs
    QR Clubman - 70.2 secs
    Gatton Street - 42.5 secs
    Flickr - Picasa
    Slanted big_pete's Avatar
    Sep 2003
    Wagga
    7,849
    Awesomesauce.
    8,139
    why not just make a full chassis car and drape panels over it?!?
    Mar 2011
    Quindanning WA
    448
    Quote Originally Posted by dogsballs View Post
    Yeah this is what I should have done but I think I've gone too far to change now.
    Maybe the mark 2 can be a full chassis.
    8,139
    hindsights a bitch hey!k
    [DIRTY31] lysdexia's Avatar
    Apr 2005
    Bunbury
    2,421
    looking great man!
    15,070
    Quote Originally Posted by XXX19X View Post
    . crack's Avatar
    BNE
    2,484
    yo kneelo,
    anything stopping a 85kg lighter g100 charade from being used for a similar mid engine conversion? were there any reasons why you didn't use one? just curious. cheers
    Mar 2011
    Quindanning WA
    448
    I prefer the shape of the g200 and there was one available nearby cheap... Having said that the only original charade parts that will be left is the exterior panels and lights, some of the body and the steering system, so I'm not sure a G100 would end up weighing much different. Anyway there are already plenty of quick g100's around but not many g200's.
    Mar 2011
    Quindanning WA
    448
    Made up a fuel tank. 1.6mm steel coated inside
    Modified the original pickup to suit the deeper tank
    Patched up the firewall
    subframe porn
    pedals modified to mount the clutch master cylinder and convert the brakes to dual masters with a balance bar (which you cant see)
    Made some new linkages for the shifter to move the cables so they come in from the front and reverse them to suit the reversed camry shifter
    now with less doors
    solid rack to lock out camry steering
    hacked the wiring harness to try and remove all the extra... bit of a failure as i cant figure out what half of it is. started and ran though so at least it goes
    8,139
    Awesome
    Sent from my LG-P990 using Tapatalk 2
    2,088
    you cray cray
    awesome
    Toyota Starlet
    Flickr - Picasa
    On the Shelf
    5,281
    Wholly fuck. It's been a while since I've visited this thread and well, haven't YOU been busy! Looks awesome!
    8,139
    whats stopping the chassis bending like a banana??
    Registered User E-Z's Avatar
    3,784
    The subframe?
    caprice nugget.
    Mar 2011
    Quindanning WA
    448
    Dogballs is right... at the moment theres not much stopping the whole subframe bending up. The plan is to tie the cage to the subframe at the little wing plate things near the top coilover mounts.
    Getting main hoop bent up today so hopefully i can get cage done over easter.
