Page 5 of 7 FirstFirst 1234567 LastLast
Results 121 to 150 of 205
Thread: Charade V6 budget hillclimber
  1. #121
    10,982
    Getting close, so close!
    I must have missed this but does the turbo just run off the rear bank?
  2. #122
    Mar 2011
    Quindanning WA
    448
    Nah I have half done a cross over pipe from the stock manifold on the front bank... waiting on a v band to finish it.
  3. #123
    canberra
    3,658
    I know you're gonna die fairly soon after this thing is running but let's not do it sooner eh and use some axles stands next time
    GT8
    1UZ Celica
    1.07 flat Wakefield Park
  4. #124
    Aug 2013
    gawler
    2,062
    WOW SUPER MEGA AWESOME
    That is the business, man.
    My last 2nd last racecar was an openwheeler with a turbo 3.5 Magna 5 spd fitted at the rear, and was disgustingly quick. Only 200 rwhp for 880kg, but made far to many very expensive V8s look very silly. All that weight on the drive tyres.......
    You are onto the right thing. I'm waiting for someone to do a 3.8 rear engine Mirage.....
  5. #125
    9,069
    So good!!
  6. #126
    Mar 2011
    Quindanning WA
    448
    I figure if this thing falls on me and i live the nopics will let me get a hoist
    I probably should use stands but I dont get under it while its balanced precariously on the jack. Everything is disconnected before hand with the sub frame sitting on rollers. Once its up i give the engine a kick and it rolls out the side.
  7. #127
    Apr 2003
    Roleystone
    3,385
    I may have a hoist for you, Running out of space to put them all.
    GURU ENGINEERING PTY LTD
  8. #128
    Mar 2011
    Quindanning WA
    448
    Fuck yeah...
  9. #129
    Aug 2009
    1,687
    Man this thing is awesome, top work!
  10. #130
    Registered User sambrad's Avatar
    Feb 2015
    39
    As everyone is saying, super impressive work, I like the way its coming together! Wish I had your fabrications skills, is it something you do for a living or just a hobby?
  11. #131
    Mar 2011
    Quindanning WA
    448
    Its just a hobby but im a mechanical engineer so i like to think that helps a bit. Really i think its more patience and perserverence than any particular skill. I like to give new things a go and learn new skills even if it takes a few goes to get it right. It takes a long time to get stuff done and i still think ive got a long way to go but the end result can be pretty good.
  12. #132
    9
    Finished that Monaro yet.......!
  13. #133
    10,304
    I actually laughed out loud looking at this thing today. Absolute madness.
  14. #134
    1,780
    Um, wow.....it is fully fledged shmick looking insanity.
    Always thought the 1MZ was underrated in its original body, definitely needed something tiny and rwd to make it stupid quick
    *slow clap*
    now with extra gearbox'y goodness
  15. #135
    Mar 2011
    Quindanning WA
    448
    Quote Originally Posted by Missinglink View Post
    Hey I've got important daihatsu things to do... I'l leave the carb V8 stuff to mouth breathers such as yourself!
    You could however come down for a visit like you keep promising and do something with it for me.
  16. #136
    7,247
    2015 is the year of the mirage so it's quite likely
  17. #137
    Mar 2011
    Quindanning WA
    448
    Engine is in for what should be the last time. Turbo install all done bar a new longer oil feed line and some fittings for the coolant connections. Oil drain back connection to the engine was a pain in the arse due to the engine leaning backwards. Ended up tapping a 3/4" bsp hole into the upper sump and screwing a hose tail in with a bit of epoxy putty in the area to give the threads a bit more area to seal. I'm pretty sure its ended up below the oil level in the sump but its as good as it gets with the limited options available.
    Crossover and rear manifold is all done using the factory manifold on the front bank. First section of the cross over uses the original dual wall exhaust piping and the rest is wrapped. Made an aluminium heat shield to stop the exhaust cooking the rear rocker cover and have a blanket for the turbo. Needs another heat shield between the exhaust and the inter cooler at a minimum. Will finish the rest of the exhaust now the engine is back in.
    Waiting on some silicone elbows to finalise the intercooler position and make some mounts for this... Its tiny but fits in the space I have perfectly so will do for a start.
    Modified the wiring harness on the engine to add wiring for oil pressure, fuel pressure, intake temp and oil temp sensors and tidied the rest up to get rid of redundant stuff. All the wiring is basically at the ECU ready to have the plugs installed. I have started to configure the ECU and after a lot of reading think I have a handle on that side of it.
    Cut some big holes in the sides and the rear hatch for ventilation. Eventually I will make some fibreglass flares for the rear wheels that will incorporate scoopy bits so its not just big silly looking holes.
    Still aiming to have this ready for the next antilag supercruise on the 28th but plenty of work still to do. Ironically the biggest issue I may have is that this is too wide to fit on my car trailer and I'm not going to have time to build my new one.
  18. #138
    Registered User agentcrm's Avatar
    Jan 2013
    Adelaide, South Australia
    919
    Can you fit a set of space saver wheels for it so it's narrower for the trailer?
  19. #139
    canberra
    3,658
    That's really looking mad...as in crazy, but crazy good
    GT8
    1UZ Celica
  20. #140
    Aug 2013
    gawler
    2,062
    Mentalist !
    I'm not convinced it is going to be a benign and friendly car to drive, seems more like an old Renault 5 turbo every time I see it, or perhaps a Stratos.
    Short, overpowered, twitchy as all hell, good luck ! Revel in the challenge.... it's got you this far.
  21. #141
    8,139
    Killer
  22. #142
    Sep 2007
    all up in yr grille
    5,505
    It will need a judicious right foot but will be a fucking riot to drive! If it looks like making the supercruise i'd come out just to see it
    1UZ+1NZ...
  23. #143
    On the Shelf
    5,281
    Fuck yeah, it's looking like an awful lot of fun! Great work
  24. #144
    22
    This is just MENTAL man...wow. G200 is a tiny car, and I can't wait to see video of the first angry drive!
    "I'm THE originator of the 'Grill Race' fool!"
  25. #145
    Qld
    111
    Been following this for some time now , love the skills , can't wait to hear how it goes .
  26. #146
    1,576
    Certifiably BONKERS!!!! Look forward to this thing being hammered round a track.
  27. #147
    Peoples Champ Fatboy's Avatar
    11,592
    Just read this for the first time. I am just about to duck off to the bathroom and rub one out. Fucking awesome...
  28. #148
    Apr 2003
    Roleystone
    3,385
    Zac is right, You are Nuts!
  29. #149
    Mar 2011
    Quindanning WA
    448
    It lives...
    Took it for a quick a quick fang up the road and it feels great. Turbo whistle makes me happy. Tune is not good enough for bitumen skids but did a few single peggers on the gravel to celebrate. Still a shit load to do before next weekend.
    ATTACH=CONFIG]82588[/ATTACH]
  30. #150
    Jan 2006
    Sydney, now London
    6,052
    so rad.
