Page 1 of 3 123 LastLast
Results 1 to 30 of 86
Thread: Datsun RB30/26 track hack
    Registered User sssute's Avatar
    59
    What I have is a Datsun 200b SSS, that I have owned for a very long time, and had alot of different ideas on what to do with it, but I have now started on making it a Supersprint/hillclimb/trackday car and mabe down the track enter into Sports sedans.
    It has beeen stripped and acid dipped, and is currently on a Rotisserie so I can seam welding and do all the underside stuff.
    I have been collecting parts for a bit now, so its time to get stuck into it.
    Over the last few weeks I have fabed up some front larger wheel tubs, to clear the bigger rubber. I have sent off the RB30 block for machining, and started stripping the RB26 head. The block will be built with forged rods/pistons/bearing and studs, and the head will be standard with oversized valves an bigger cams. I also have a dry sump pump ready to be mounted and have started on the dry sump pan.
    Plans.
    RB30/26DET Dry Sump, Built bottom end, Rebuilt head with Cams, E85, Bigger injectors, Large single turbo, Autronic
    Gearbox ????
    Rear end is a modified 350Z subframe, and arms
    Winters IRS quick change
    Performance Friction Brakes
    Modified S14 front end
    Cage
    18x9.5 Enkei F1 Front
    18x10.5 Enkei F1 rear
    V mount Radiator
    Carbon panels
    And there is more that will be posted along the way
    I'll try and get some photos up to start with.
    Scott
    59
    Pics
ID:	58205   Click image for larger version.
Name:	IMG_0055 (Large).JPG
    [DIRTY31] lysdexia's Avatar
    Apr 2005
    Bunbury
    1,909
    fark.
    nudder dirte30 fanboy
    Newy Braaah
    674
    This looks like it'll be interesting. Sounds pretty serious for a track hack, sure your not going to Sports Sedans straight away?
    Tastes like victory EVOSTi's Avatar
    Copenhagen
    2,142
    Looking forward to more pics!
    59
    I want to keep it looking pretty for a couple of years, before racing door to door.
    Sensei Cobra bahaimus's Avatar
    In a Panamera
    5,095
    You've got my attention!!
    piss taker of the piss Uncle Arthur's Avatar
    10,975
    That all should work, just set the engine as far back as you can. Nose heavy cars are not good for circuit stuff.
    59
    The whole engine is just behind the front axle, so i'm hoping the weight balance wont be to bad. My seat will also be back about 300-400 mm from the standard location.
    Leeewwwwiiissssss!!!!!! willsy01's Avatar
    Jul 2002
    In the riot zone
    6,818
    Definitely go for some wider rubber.....
    Registered User boostin31's Avatar
    Apr 2009
    Wagga Wagga
    530
    Jesus H Christ! Will be watching this bated breath!
    Registered User Mini_Me's Avatar
    1,434
    this is cool! subscribed
    10,975
    Quote Originally Posted by sssute View Post
    Sounds good, all you need now is a nice stiff chassis.
    needs boost... morerevsm3's Avatar
    Jun 2006
    Ararat
    2,888
    pretty sure I have seen your ute at Mallala and Mt Alma, I have no doubt this project will be awesome
    Registered User adamRSLC's Avatar
    1,101
    Quote Originally Posted by lysdexia View Post
    fark.
    I said that before seeing your post ! , so +1 .
    Acads
    Sandown 1.23.31
    Calder 1.05.76
    Phillip Island 1.51.50
    Winton 1.37.20
    H/Hills hill climb 1.03.3(FG XR6T)
    Bathurst 2.47.49
    FG XRT . VL LS1 . 02 GT Foz . 09 Hino FC
    Registered User Doyley's Avatar
    Jan 2006
    Wagga Wagga
    157
    Jesus Christ this thing will be nuts!
    Nov 2008
    bm
    1,615
    Fuk yea this is awesome
    Adeptus Mechanicus buzz's Avatar
    Nations Capital
    2,957
    OK... in on one.
    I presume you anticipate a fair bit of rubber outside of the line of the standard guards, will you be trying to keep it within that (I think it is) 10cm max they allow you to flare the arches for Sports Sedans... or do you purely give no fark for rules?
    59
    Yea i'm only going to be 90mm wider than the standard guard, I'm using a 100mm flair that is higher on the guards, so that brings the total in a bit.
    Opens profi's Avatar
    Feb 2009
    1,866
    Are you still going to run your coil overs in the standard strut position or are you moving them inboard?
    Registered User [ryan]'s Avatar
    3,096
    This sounds exciting
    59
    It works out that I can run the coilovers in the standard top postion with adjustable camber tops built in, and still get a 275mm tyre under the flair with room to move. If im chasing a larger tyre on the front later, I'm also going to be making some adjustable control arms for a bit of extra tweeking.
    59
    I made up a jig today to use to narrow the 350z subframe and make the munts for the diff. Used some coil-over sleeves and clamped the frame using the coilover nuts. Made it super easy to get dead square and level. I have to get hold of some aluminium plate to make the diff mounts from, then weld up and i'm also going to strenthen the suspention mounting points.
    The subframe will be mounted in the car on a similar set up to the jig bench, i'm using coilover style tubes, so that I can adjust the rear subframe hight and angle to playwith roll centres.
    59
    Subframe Jig
Name:	IMG_0059 (Large).JPG
    59
    It is all upside down in the jig.
    Smooth is fast Mad31's Avatar
    7
    This is awesome!
    Registered User lightyear's Avatar
    Mar 2010
    538
    Looks like a cool project. Tyres look like they are up there.
    The old banger mx5 - Phillip Island - 1:50.6 (with 125rwkw's no lsd) Sandown - 1:24.7 (with 110rwkw's and lsd) Winton - 1:36.8 (with 125rwkw' and lsd)
    The NA8B 89.3rwkw's - P.I. 1:52.8 -WINTON 1:38.0 - SANDOWN 1:28.8 -WINTON SHORT 1:08.7 -BROADFORD 1:07.9
    Apr 2009
    Wagga Wagga
    530
    Would you happen to know how wide the 350z rear end is compared to a 32 gtr rear end? like wheel track wise?
    59
    I'll have to check, I have it written down somewhere, I have narrowed the sub frame by about 80mm to fit my car.
    59
    I have a bit of an update, I have been making the mounts for the diff into the 350Z sub frame. I ended up using some 10mm and 12mm aluminium plate and cutting it up on my band saw, and fucking around of ages to make it fit. I'll attach a couple of photos, It is only just tacked together at the moment.
