Results 1 to 30 of 50
Thread: Engine stand to engine bolt strength
    Registered User OvlovMan's Avatar
    Mar 2009
    934
    What do you guys use to hold your engines on engine stands?
    I'm thinking high tensile (i.e. 8.8 + ?) or is that overkill for this purpose?
    1,004
    i use high tensile 8.8 to hold a toyota v12 to a supercheap auto engine stand. i did find that the washes supplied with the stand were too soft and bend easily so i would replace them.
    one of the wheels is sitting in the air but none of the bolts have broken.
    Mar 2009
    934
    LOL. The brand of stand I am about to blood is a SCA item as well. So if 8.8 is good for a toyota V12 then an all alloy 5 pot should be fine I'm guessing. Thanks
    Pollitically incorrect
    Aug 2007
    7,235
    I have used the belhousing to block bolts in the past. Only on L series dattos though.
    9,115
    whatever bunnings have that is cheap. your over thinking it dude.
    5,815
    I think "cheese" bolts are OK but may only come in coarse thread, 4 8.8 bolts aren't going to break the bank, although i did avoid buying bolts that were fully threaded because they were shitloads more than the ones that weren't. ideally you would use the bellhousing bolts but it depends on geometry of the stand.
    Meh
    Jan 1970
    26,940
    ^this^
    Cheap & nasty is fine.
    Mar 2009
    934
    Bell housing bolt up points will be used. I was considering more the length of time the thing might be hanging there and possibly getting leaned on to undo/tighten stuff on it.
    Not the actual engine but same block.
    Sidetracked BMWTurbo's Avatar
    Aug 2004
    3,375
    Factory belhousing bolts to hold 'no shits' to my Aldi stand.
    CNGAF rowdytoot's Avatar
    hotel vast horizon
    9,782
    my supermoo has been on a stand for 18 months using 1/2 bellhousing bolts and 1/2 random coach bolts left over from house projects
    Meh
    Jan 1970
    26,940
    Luxury.
    Mine's got bolts that have been cut in half and welded back together with extensions to make them long enough.
    hotel vast horizon
    9,782
    lol gold !
    Registered User xm-221's Avatar
    Clifton Springs (close to buttfuck no-where)
    48
    I've got Holden 6cyl head bolts holding a Clevo and a 250 crossflow on the engine stands at work. Use whatever you can find, the higher the grade the better though.
    3,575
    Luxury.
    I think last time I had an engine on a stand, I used sockets as "long washers" because the bolts were too long...
    Meh
    Jan 1970
    26,940
    I think last time I had an engine on a stand, I used sockets as "long washers" because the blots were too long...
    Damn those blots.
    TOKEN AUSSIE BOGAN tut's Avatar
    stupid sexy flanders
    6,544
    just use really wide zipties.
    Cuntberra
    6,096
    i use 10.9's only because there all i can find in the old bolts draw the right size for my engine
    10,411
    I reckon a clevo with cast iron heads would be on the scale of heavy, near the top, I just used some black grade 8.8 fasteners random length with some big nuts as washers.
    Don't stress.
    Mar 2009
    934
    Quote Originally Posted by Greg Rust
    Don't stress.
    I'm starting to see a common theme emerging here ...
    10,411
    Stress your fastener, not your head.
    Jan 2008
    Bris
    1,014
    Just be sure they engage as much thread as possible, especially in an alloy block.
    wants Sloan clone Lonx's Avatar
    2,839
    I think I re-used the old nissan head bolts to hold up my CA
    PF Gamers List
    Quote Originally Posted by klampykixx
    if a motor has big enough injectors to run say, 7psi but only just starts to max out right on rev limit, will it run more boost lower in the revs without maxing out if you lower the rev limit?
    15,311
    Don't stress.
    I was always more worried about the flex in the stand - used to have a prop under the balancer when rolling it cross country to keep it from fatigueing at the bottom joints...
    Registered User caged's Avatar
    Jan 2011
    christchurch/sunshinecoast
    283
    I welded nuts to some studs and rounded off the hex so they fitted inside the sleeve on the engine stand and used normal bell housing bolts into them. It looks as dodgy as it sounds.
    Apr 2010
    Bogan City
    813
    Quote Originally Posted by xm-221 View Post
    what kind of engine stand do you have the clevo on? we tried 2 different stands when attempting to do a rear main on the boat motor. even tried welding steel onto the second one to stiffen it and it was still creaking and groaning. we gave up and took it to the engine builder to deal with.
    Apr 2010
    Bogan City
    813
    Fumb duck
    Apr 2011
    Not commuting so much...
    599
    Luxury.
    Opened thread to say this. I used some 8mm round bar to extend the bolts in mine...
    Used to be TehEkHo
    あなたの母親の肛門 Shifty's Avatar
    10,774
    I amnot even going to start correcting this.
    100% agree with Shifty
    10,411
    Quote Originally Posted by Shifty View Post
    I'm
    Meh
    Jan 1970
    26,940
    Photo of one of our half-arsed bolts for lols.
