Page 25 of 25 FirstFirst ... 152122232425
Results 721 to 729 of 729
Thread: VL LS3 turbo sleeper
  1. #721
    Registered User Dimi's Avatar
    Sep 2012
    1,721
    Then make a fancy bracket with angles and weight reduction slots so it doesn't look like a piece of 80mm flat bar
    Weld the washer thing to the bracket
    Bolt it in
    Weld it to the cage and done. That took me the best part of today. Can't be sure if I'm not overly productive or this sort of work just takes alot longer than it looks like it should
  2. #722
    Opens ALLMTR's Avatar
    Newcastlish
    24,074
    Good work. Yeah, roll cage looks like finicky PITA work
  3. #723
    10,057
    It's weird seeing someone doing a fully welded cage in a nice car, I used to guys cutting the roof off to get to the top of the tubes.
  4. #724
    Sep 2012
    1,721
    Cheers Chuck!
    Believe me I did consider peeling the roof skin off briefly while I was cursing welding the top of the main hoop, then I remembered Ive made the cage that tight to the roof I'll never get the roof lining back in ever.
  5. #725
    Shitney
    1,111
    Who bent up the hoop and the rest of the stays? Or did you grab yourself a bender and knock them out yourself from templates etc..? Fucking mint fab work man! You're killing it
  6. #726
    Sep 2012
    1,721
    Quote Originally Posted by krisr View Post
    I bought them from JL racecars, His front legs and hoop profile are nice and tight to the bodey, it was quicker and more cost effective for me to buy them from him than waste tube getting it wrong.
    A mate also has a bender, so i could bend what i wasn't happy with from his stuff. Rear legs, taxi bar, window bar.
    His front floor boxes are also shit and i have no idea what rail profile they are designed for, but its not a VL. Had to make them again.
  7. #727
    Sep 2012
    1,721
    A bit more progress, works picked up so car time suffers.
    I've had multiple issues over the years with different sorts of the keyed kill switches corroding internally over time creating resistance problems. I didn't want to put a hole in a panel and my old key switch inside the fuel flap setup technically doesn't comply for racing. Best solution I could find was these push rod one switches, highest "rated" for cranking amps I could find. The push rod exits between the bumper trim and the tail light so I can remove it when I want to street it with no visible hole.
    Cars off for a full retrim next week as we can't match the leather unfortunately.
  8. #728
    Canberra Nth
    3,374
    Nice and neat man.
    Shame about the trim
    - PSN: rotacoupe
  9. #729
    10,057
    It's pretty much impossible to colour match interiors due to fade/wear etc. There's also a few issues at the moment with the supply of coloured hide etc, the tannery is having trouble getting his hands on certain colours of hide and sheepskin.
