Results 31 to 60 of 67
Thread: Bitsa cheap as Open wheeler
    Jun 2016
    Blue Mountains
    77
    Yep, that's the one.
    16,764
    Isn't that the body Steiner started with for his first "F5000" ?
    Jun 2016
    Blue Mountains
    77
    I think he had an original mold to take it from. amazing job that was.
    Jun 2016
    Blue Mountains
    77
    Spent the morning playing around and compromising and think I finally have it. Fully triangulated, 300mm between sprocket centres, room for drive shafts, engine as stressed member (partly-maybe just adding that extra bit ) BUT reduced length of diffuser quite a lot
    Obviously the finished product will have substantially more tape, may even use higher quality 200mph racers tape.
    Really wish I could get my head around uploading these photos. For some reason kept loading upside down or half rotated.
ID:	100032   Click image for larger version.
ID:	100033   Click image for larger version.
    Jun 2016
    Blue Mountains
    77
    Sometimes (oftentimes) i can be quite dim. Just looking at those photos after posting and running back out to the garage, realised can still have my original length diffusers and go narrower so have equal width top and bottom attachment points with only oil filling point now an issue- can work around that. Oh happy days.
    Jun 2016
    Blue Mountains
    77
    Well bugga that rear sub-frame took a thousand different iterations to get it right. Don't know how many times had to cut out tubes and start again. It aint pretty up close but it is strong with as much triangulation as I could get in. Had to build in 2 pieces as engine is too wide to lift in and out. Once finished placement of all tubes, welded together permanently. Just need to work out how to finish off the ROP brace as not sure on regulations for that (does anyone know?)and fit a 6mm aluminium plate to brace between engine and diff. Also left tubes on the end as not sure which way I want to attach rear suspension.
    Now jigging up rear uprights ready to weld. Also bought a new Chinese invertor MIG off evilbay. Really impressed with this beast- 260amp, digital display; lite as. Very easy to use and a super stable arc makes it so easy to get a nice weld compared to both other MIGs I've used (Transmig 180 and a cheap 120amp Bunnings pos), even on a 20 metre extension chord. Eats 4mm steel for breakfast and only cost $329.
    Anyway, now feel like I'm getting somewhere. Going to run 2nd hand Formula 3 tyres front and rear. Front suspension will be Formula Vee so stuck with the suspension geometry it came with. The rear suspension geometry is another matter. Need to decide how much travel to accommodate, then work out static/dynamic cambers to build into it. Got no idea where to start there. Suspension geometry, no matter how many times I've read up on it, is witchcraft to me.
ID:	101638   Click image for larger version.
ID:	101634   Click image for larger version.
ID:	101635   Click image for larger version.
ID:	101636   Click image for larger version.
ID:	101639   Click image for larger version.
ID:	101640   Click image for larger version.
    Aug 2013
    gawler
    2,110
    Ah! Now you are really powering on, fabulous stuff.
    Suspension layout? I can only tell you what I know, bugger all. Long arms, the longer the arms the less things change. Bottom arm close to horizontal, top arm, inboard lower. Roll centre between the ground and the centre of gravity, lower the better? I think we tend to give ourselves to much suspension travel, I used to figure on 3 inches of bump and 3 inches of droop now I only look at 2 inches either way... I reckon I read somewhere that the rear roll centre should be 2/3 of the centre of gravity height and front only 1/3... Know your tyre size first, otherwise you are going to have to redo it all.
    At the front end, understand and correct your ackerman to suit your wheelbase.
    I don't know shit, but I haven't yet built a car that was just an absolute pig either.
    Feb 2009
    Gawler SA
    3,334
    vsusp.com
    free to use.
    Jun 2016
    Blue Mountains
    77
    Thx Dave, know vsusp, great site! It's just what results SHOULD i be designing for that has me stumped. Apparently radials need some static camber with slight progression ( how much??) as they are more compliant than cross ply, which are more forgiving but require almost no progression. May ask the F3 boys and see what they do. Had spoken to Malcolm Oastler (F1 designer) at a hill climb and he was almost dismissive of geometry.
    Roy, how do you measure CoG, or is it just a guestimation? Thx for tip on suspension travel, will give it 2" either way. What rake are you running? I've read some different thoughts on formula ford forums, they all talk about (eg) 50mm front and 75mm rear ride height, but where are these points measured from- axle centre lines or extreme front and rear of car?
    Anyway, need to concentrate on mounting Vee front end next, then can play with rear suspension.
    16,764
    Quote Originally Posted by rodoe View Post
    Had spoken to Malcolm Oastler (F1 designer) at a hill climb and he was almost dismissive of geometry. .
    When there's almost Zero movement and the tyre is doing most of the suspension work, geometry doesn't matter worth a damn - the front end of F1s have been a good example of this for years.
    Jun 2016
    Blue Mountains
    77
    Probably right Gammaboy.
    Just trying to mount up the vee front end now. Not looking good at all. Need to cut out 2 tubes out of chassis (not such an issue), and then change the whole mounting of current pedal set up from top pivoting to mounted on floor so can fit steering shaft. Either that or fit a rack- of which i have a choice of 2- in place of the vee steering box.
    Last choice, find out if selling the Vee front end will pay for rod ends, inserts, tubes, calipers, discs etc to fit A-arms front end. Anyone know what a ready modded link pin, disc brake converted, height adjustable and spring modified Vee front end goes for?
    Aug 2013
    gawler
    2,110
    Again I only have my own experience to draw from. I run 75 mm from bottom of chassis to ground front and rear. Rake is for aero, I've decided aero means nothing at Collingrove.
    I'm guessing camber depends on the tyre, I run less than 1 degree, at full bump it would have a little more....at full droop a little less. Long arms = little change. And I still don't see the whole face of the front tyre being used...
    I suspect that Malcolm is right, the geometry only needs to be there or there abouts. Really it all comes down to outright grip (tyre size and compound) and power to weight on the part of the car. Remember that the serious cars work on putting all of the front weight on the outside tyre in turns with a single shocker front end working the front tyre as hard as possible getting heat into it and extracting maximum adhesion. Given the low tyre pressure and soft compound the actual geometry is probably a secondary consideration (especially considering the other tyre is flailing away in the air).
    Yes, F1 has totally gone away from the norms in regard to front end geometry, everything is about aero
    Exposing Swamp Creatures Walt Kowalski's Avatar
    May 2010
    WWG1WGA Washington D.C.
    1,559
    I so like your work. Subscribed. Will be awesome gadget.
    For those people like me who don't have much in the way of your skills there is a simple, fast and cheap way to build a clubman - not an open wheeler like yours but a fast simple gadget.
    Take a front subframe, rack and Alum A Arms from an FD RX-7 caliper to caliper. Four bolts hold it to a chassis. Then at rear of said home built chassis bolt the rear subframe caliper to caliper Incl the strong diff and Alum A Arms.
    There's a street registered one that races in Sportscars at Lakeside and it beats everything. Radicals, Minettis you name it. Ugly body but simple and cheap to build and effective and he drives it home. Does .54's. Incredible.
    The FD Subframes are readily avail and cheap. James Pearson on FB has 'em.
    Jun 2016
    Blue Mountains
    77
    Thx Roy. What tyres were you using on the little green beast?
    My cheapest option are 2nd hand set of F3 Hankooks With fronts at 180mm wide and rears at 240mm wide for $200 complete set.
    Will have aero as mostly being usedcas track day car. Diffuser is 5 , so hopefully 7 inclusive of rake.
    Walt, i seriously have very little in the way of skills. I'm full of book knowledge but little in the way of hands on skills. Just determined to own a rafe car. Would much prefer to slap the money down on a complete car, just don't have the money. Might look up that beast you're talking about. Sounds simple.
    Jun 2016
    Blue Mountains
    77
    Btw, who is the owner or what is that car called?
    Aug 2013
    gawler
    2,110
    Round and black Avons, 9.5/20-13 in hillclimb compound. I lucked upon them 2nd hand on Gumtree, fitted to Randy's wheels with the right stud pattern as well...$1200.
    May 2010
    1,559
    His name is Chr1$topher F1ng
    The beauty of the FD Subframes with F3 style Double Alum A Arms of all four corners is it works. His car is basic but you could probably put a pretty Clubman body on one.
    Other advantages of using the FD stuff are a multitude of cheap 18" rims and slicks as the Mazda PCD is 114.3 - same as Nissan, Ford and many Toyotas.
    PREPARE yourself for the shocks that are coming Worldwide:
    DO YOURSELVES A FAVOUR.
    GET ON THIS:
    www.qmap.pub
    Jun 2016
    Blue Mountains
    77
    Finished welding up rear uprights. Thankfully black paint covers a multitude of sins :-)
    Unfortunately, front uprights didn't go so well. Awful and unusable actually.
    So been looking for old Holden Gemini front uprights. Found a pair complete with hub, discs and calipers fresh off a car for $100. Ready to pick up in the morning but then got message he has sold to someone else as i couldn't get there quick enough. Aaaah!!
    Jun 2016
    Blue Mountains
    77
    Walt, got any photos of that car?
    May 2010
    1,559
    I did rodoe but I think I deleted them. I'll have a look.
    GET ON THIS:
    www.qmap.pub
    May 2010
    1,559
    I never said it was purdy.
    GET ON THIS:
    www.qmap.pub
    Jun 2016
    Blue Mountains
    77
    Who cares if it's pretty. As long as it goes hard.
    Well, managed to save front uprights and they match on the jig perfectly :-) So now need to work out what brakes and rotors to use. As budget is tight, will prob go for 2nd hand single pot cheapies. Any suggestions to fit under 13" wheels?
    Aug 2013
    gawler
    2,110
    I use Magna rears, because the sliding half is aluminium and there is no integral handbrake gubbins, so quite light.
    Jun 2016
    Blue Mountains
    77
    What year are they Roy? Is that for the front and back?
    Jun 2016
    Blue Mountains
    77
    And what rotors?
    Jun 2016
    Blue Mountains
    77
    So got wheel centres drilled to 4x100 PCD at CNC wheels. Recommend these guys, great job and good price.
    So putting bearings into rear uprights. Heated uprights in oven and froze bearings in freezer. One fits in nicely with tap from hammer, other just drops in. Now at room temp, first one nice and snug, second one slides in and out as you can see on the youtube clip i made.
    https://youtu.be/WNHDtB4oxl0
    What do you guys think? Safe or not and how to remedy -was thinking some kind of loctite maybe. What are your thouhts?
    Also Roy, trying to get accurate measurents to do geometry. What is the face thickness (between hub and upright)of the rotors you used?
    Aug 2013
    gawler
    2,110
    I used Magna rear calipers all round with a 3/4 " master cylinder for the rear and a 7/8" for the fronts and I use MX5 rear discs all round ( from memory they were from the first series MX5). I had to trim a little from the Echo rear hub to get it inside the MX5 disc.
    Note the rear pressure bias for the rear weight bias?
    I'll pluck a number out of my arse for the thickness of the disc ....6 mm ? Not enough to make a poofteenth of difference to anything. I'll have a look tomorrow.
    There is a circlip holding that bearing in, isn't there? Indeed even if there were not things are all bolted together, so the need is to stop the bearing outer turning. Loctite retaining compound is very good and getting the centre punch out and smashing some dimples inside the bearing housing to assist retaining the bearing helps.
    Jun 2016
    Blue Mountains
    77
    A fountain of knowledge, thanks Roy!
    Jun 2016
    Blue Mountains
    77
    4 x MX5 NA6 rear brake discs on their way.
    Next are Magna rear calipers. Are all models the same or what model did you use Roy?
    Aug 2013
    gawler
    2,110
    I was using TJ Magnas 2000 to 2002 ( from 2000 the ECU could be reprogrammed and in 2002 they made the conrods a little less strong)
X vBulletin 4.2.5 Debug Information
  • Page Generation 0.20967 seconds
  • Memory Usage 9,062KB
  • Queries Executed 12 (?)
More Information
Template Usage (35):
  • (1)SHOWTHREAD
  • (1)ad_footer_end
  • (1)ad_footer_start
  • (1)ad_global_above_footer
  • (1)ad_global_below_navbar
  • (1)ad_global_header1
  • (1)ad_global_header2
  • (1)ad_navbar_below
  • (1)ad_showthread_firstpost_sig
  • (1)ad_showthread_firstpost_start
  • (1)ad_thread_first_post_content
  • (1)ad_thread_last_post_content
  • (5)bbcode_quote
  • (1)footer
  • (1)forumjump
  • (1)forumrules
  • (1)gobutton
  • (1)header
  • (1)headinclude
  • (1)headinclude_bottom
  • (30)memberaction_dropdown
  • (1)navbar
  • (4)navbar_link
  • (1)navbar_noticebit
  • (1)navbar_tabs
  • (3)option
  • (1)pagenav
  • (1)pagenav_curpage
  • (2)pagenav_pagelink
  • (11)postbit_attachmentthumbnail
  • (30)postbit_legacy
  • (30)postbit_onlinestatus
  • (30)postbit_wrapper
  • (1)spacer_close
  • (1)spacer_open
Phrase Groups Available (6):
  • global
  • inlinemod
  • postbit
  • posting
  • reputationlevel
  • showthread
Included Files (28):
  • ./showthread.php
  • ./global.php
  • ./includes/class_bootstrap.php
  • ./includes/init.php
  • ./includes/class_core.php
  • ./includes/config.php
  • ./includes/functions.php
  • ./includes/functions_navigation.php
  • ./includes/class_friendly_url.php
  • ./includes/class_hook.php
  • ./includes/class_bootstrap_framework.php
  • ./vb/vb.php
  • ./vb/phrase.php
  • ./includes/functions_facebook.php
  • ./includes/functions_bigthree.php
  • ./includes/class_postbit.php
  • ./includes/class_bbcode.php
  • ./includes/functions_reputation.php
  • ./includes/functions_notice.php
  • ./packages/vbattach/attach.php
  • ./vb/types.php
  • ./vb/cache.php
  • ./vb/cache/db.php
  • ./vb/cache/observer/db.php
  • ./vb/cache/observer.php
  • ./mobiquo/smartbanner.php
  • ./mobiquo/include/classTTConnection.php
  • ./mobiquo/smartbanner/head.inc.php
Hooks Called (73):
  • init_startup
  • friendlyurl_resolve_class
  • init_startup_session_setup_start
  • database_pre_fetch_array
  • database_post_fetch_array
  • init_startup_session_setup_complete
  • global_bootstrap_init_start
  • global_bootstrap_init_complete
  • cache_permissions
  • fetch_threadinfo_query
  • fetch_threadinfo
  • fetch_foruminfo
  • load_show_variables
  • load_forum_show_variables
  • global_state_check
  • global_bootstrap_complete
  • global_start
  • style_fetch
  • global_setup_complete
  • showthread_start
  • showthread_getinfo
  • strip_bbcode
  • friendlyurl_clean_fragment
  • friendlyurl_geturl
  • forumjump
  • cache_templates
  • cache_templates_process
  • template_register_var
  • template_render_output
  • fetch_template_start
  • fetch_template_complete
  • parse_templates
  • fetch_musername
  • notices_check_start
  • notices_noticebit
  • process_templates_complete
  • friendlyurl_redirect_canonical
  • showthread_post_start
  • showthread_query_postids
  • fetch_postattach_query
  • showthread_query
  • bbcode_fetch_tags
  • bbcode_create
  • showthread_postbit_create
  • postbit_factory
  • postbit_display_start
  • postbit_imicons
  • bbcode_parse_start
  • bbcode_parse_complete_precache
  • postbit_display_complete
  • memberaction_dropdown
  • postbit_attachment
  • pagenav_page
  • pagenav_complete
  • forumrules
  • navbits
  • navbits_complete
  • build_navigation_data
  • build_navigation_array
  • check_navigation_permission
  • process_navigation_links_start
  • process_navigation_links_complete
  • set_navigation_menu_element
  • build_navigation_menudata
  • build_navigation_listdata
  • set_navigation_tab_main
  • set_navigation_tab_fallback
  • navigation_tab_complete
  • fb_like_button
  • showthread_complete
  • page_templates
