Page 3 of 3 FirstFirst 123
Results 61 to 70 of 70
Thread: Brake/clutch pedal set specifications with brembos.
    16,733
    Yeah, dunno I'm afraid.
    720
    Quote Originally Posted by MAZMAN View Post
    What about the comments in regards to the master cylinders being lower then the calipers and needing the residual valves as fluid can drain back?
    No personal experience sorry, but Junior's FSAE team run that setup on both their cars, I'll check in with them and report back. It might take a few days to get an answer, it's exam season.
    NSW supra club Member
    978
    What about this antirattle plate that seems to be pushing against the pads as well, should i remove this to help with minimising push back of pads? I do t care about noises/rattles.
    93 tt supra,black 6 speed
    SINGLE
    720
    You donít need anti rattle clips/plates on the track, piss them off.
    Still trying to get an answer out of Junior for you on the floor mounted pedals lower than calipers. Itís like pulling teeth....
    978
    Yeah cheers, ill modify it so it doesnt push the pads back in or remove all together.
    Knockback springs are in, and calipers on, just about ready to bleed, i can always add those valve later so just let me know whenever you find out.
    Thanks
    SINGLE
    16,733
    Thanks
    I think knock back springs plus the check valves might lead to brake drag.
    978
    Yeah i dont want to do it if its going to cause issues. Just wantng to know if someone has tried, as i cant find anything while searching if they used both at same time.
    But mainly that blurb from wilwood about my masters being lower then calips has got me worried now!
    SINGLE
    720
    Finally managed to get an answer out of Junior..... to be fair, now that exams are over.
    The brake guy from his FSAE team reckons that if you mount the reservoirs above the calipers, it doesn't matter that the master cylinders are below the calipers, there's enough hydro static pressure that the calipers can't bleed back. They have the master cylinders below the calipers in both team cars, and don't run a valve, due to the reservoirs being remote from the master cylinders, and higher than the calipers.
    Title pending
    2,926
    I thought that was self explanatory
    Hence why Formula Fords etc have resi extensions on them... not just to hold more fluid... but to lift it up abit
    I guess when you do stuff... you forget other people don't
    http://race.parts/Catalogue/Braking/...R-EXT-64475476
    978
    Good stuff, thanks for the update Sprinkles.
    Everything is on, and ready to go testing.
    Endless rf650 brake fluid.
    Circo m119 pads.
    Anti knock springs.
    All feels good... so lets see.
    SINGLE
