Page 3 of 8 FirstFirst 1234567 ... LastLast
Results 61 to 90 of 231
Thread: Toyota Cressida MX73 GL-i
    1,257
    Quote Originally Posted by fnlow View Post
    Cool project. That intake manifold came up well. Was it hydroblasted?
    I believe so.
    Clean. Yes, Walbro 460 are e85 compatible. I run in my original vs ute tank, on 98 and it is mint. Only 320rwkw
    I meant the foam type sock that came with the pump, wouldn't make much sense if they broke down in e85 seeing that the pumps are compatible.
    24,371
    My 460 sock has been fine in ethanol for over a year. Good to go.
    1,257
    Perfect, thanks.
    1,257
    Fuel tank all cleaned and re-sprayed, I think it came up really well.
    Pushed the foam baffle through the opening
    Walbro pumps
    All in, so much stuffing around, wouldn't fit how I wanted it to but the pumps sat nicely so it should be fine. Used 25 amp wiring to the fuel hat so should handle the pumps without melting. Bolted the stock vent, fuel sensor and filler back on.
    Need to buy another fitting...
    Also treating myself to a 3/8th Warren & Brown digital torque wrench for engine stuff.
    Opens ALLMTR's Avatar
    Newcastlish
    24,091
    Tank come up good, well done
    Oct 2012
    711
    Did you fit 2 pumps in that foam sock thingy? I looked at buying these for the VL, I asked them and they said only 1 will fit
    1,257
    I wouldn't recommend it - I am not too happy with it. Maybe twin DW400 (46mm diameter) will fit a bit nicer. The opening is around 3 1/4" (82mm) - the base of the walbro are 50mm. I had to lower one in at a time, the bolt down the fuel hose to the pump.
    Newcastlish
    24,091
    I just made up a TT shaped area in my cell with some raceworks E85 safe foam
    1,257
    Bought the o-ring speedflow fitting and finished the vent.
    Flange welded to intake. Will go around the outside weld with some scotch-brite to blend it in.
    Throttle body clears the rail
    A lot nicer than the factory thing
    Registered User my limp penis's Avatar
    949
    nice, looking good
    '84 Supra 7MGTE
    '86 Supra 2JZGE track
    '99 Supra GTX35 VVTi
    '10 C63 AMG
    PSN: RyleyMA61
    SEQ, Australia
    4,012
    Ooh, shiny bits!
    Can I ask why you went with a DBW throttle? I'm planning to replace my factory throttle body with something smaller/simpler but this didn't occur to me as an option. What are the pros/cons?
    Norbie!
    1,257
    Pros;
    - no need for idle air control valve
    - remove ugly throttle cable from engine bay
    - neater in engine bay
    - can use BPP fuel rail on VVTi engine - stock TB fouled on rail
    Cons;
    - uses 4 AVI from Haltech which could be used for temp / pressure sensors elsewhere (but free's up 4 DPO which would be used on a stepper motor anyway)
    - expense (throttle body, connectors, pedal assembly)
    I looked at other non DBW throttle body assemblies and IMO they look like crap and weren't a lot cheaper than my set up. This is similar size to the Q45 that a lot of the Americans use. Bosch make a 74mm one which I think is same size as stock 2j.
    9,101
    Thanks for the explanation. Makes perfect sense in that scenario. It looks great too.
    949
    I'm going Bosch DBW too but keeping it reversible. The 68mm is close to factory 65mm.... here's a CAD of my set-up (to be)
    '84 Supra 7MGTE
    '10 C63 AMG
    PSN: RyleyMA61
    SEQ, Australia
    4,012
    Quote Originally Posted by [RX3] View Post
    Pros;
    Thanks for the info, I was wondering what to do about IACV so this could be a good solution. I also like the idea of making the engine bay a bit neater.
    Norbie!
    Melbourne, Aust
    715
    Never thought of this either, looks like a good option that i may consider for my JZ engine's
    might just go this version though as i'm no good with a welder.
    http://www.garagewhifbitz.co.uk/inde...onversion.html
    a quick question, what will do you in regards to pedal?
    CISCOKIDS
    The Gentlemen's Club
    Midnight Rocker
    SEQ, Australia
    4,012
    Quote Originally Posted by ROBAPHENT View Post
    That looks like a nice plug-and-play solution, but $1500 + shipping? They're having a lend surely.
    Norbie!
    949
    Lexus SC430 pedal is virtually plug and play - needs a few spacers to get position right - a hundred bucks off ebay
    Bosch TB - $550 brand new, whatever diameter you want, cheaper if you buy S/H porsche item
    I am going to be making the nice billet adaptors as above, but can weld up a nasty whiftbits style one for anyone that would like it.
    Or can get a flange waterjet cut from Aluminium and you can weld it to the plenum like the OP
    '84 Supra 7MGTE
    '10 C63 AMG
    PSN: RyleyMA61
    1,257
    New pedal - $275
    Connector to suit - $29
    74mm throttle body - $269
    Flange to suit - $44
    Connector to suit - $17
    $634...
    Add a couple of dollars for bolts and maybe $100 for someone to weld the flange on the intake and it comes in quite well priced.
    I don't like that Whifbitz piece. The adaptor looks weird.
    949
    yeah, their adaptor looks shit
    '84 Supra 7MGTE
    '10 C63 AMG
    PSN: RyleyMA61
    Melbourne, Aust
    715
    I need it to suit a 1JZ though :P
    good to know you will be making/selling i will keep it in mind.
    CISCOKIDS
    Midnight Rocker
    949
    I just need to CAD up a 1JZ TB, and I have a 1JZ in the family, so shouldn't be too bad
    '84 Supra 7MGTE
    '10 C63 AMG
    PSN: RyleyMA61
    Melbourne, Aust
    715
    I might have the 1JZ flange drawn up. (will check when i get home) but i also notice you are from VIC, you going to all toyota fest at all? i might be able to give you one.
    This would be good new's as i could do the swaps in my X8s
    CISCOKIDS
    Midnight Rocker
    949
    that would be even easier. let me know
    That's this weekend yeah? I'm on the track at broadfjord so can't make it sadly
    '84 Supra 7MGTE
    '10 C63 AMG
    PSN: RyleyMA61
    Melbourne, Aust
    715
    I know you probobly dont want to start all over again but this just popped up. X7 Wagon????? lol
    https://www.gumtree.com.au/s-ad/huon...x70/1187901203
    CISCOKIDS
    Midnight Rocker
    1,257
    No.
    1,257
    Fuel tank now back in and waiting for the exhaust parts to be ceramic coated.
    Gives me time to focus on the fuel lines. Thought about running a 200 series speedflow hose for the return but noticed the existing hard line in a good place so thought it would be a good idea to use that. Found a spot for the flex fuel sensor too, may not be the best place for it being in the return but was happy how it turned out.
    I used some speeflow fittings and the Gates brand Barricade hose which is good for E85. Just need to put on some hose clamps and weld a nut on the inside of the strut tower to secure it.
    Decided that I will have the engine bay painted, unsure what colour just yet, maybe a darker grey. But would be nice to do it before everything is locked in.
    I will start on the cooler pipes in the next day or so.
    Newcastlish
    24,091
    Nice, where are you getting the alloy bends from?
    1,257
    Plazmaman.
    1,257
    Did some welding today.
    Fits nicely, but need to make the hole a big bigger where the battery tray was.
    Bumper still fits which will hide the BOV. I need to find some nice clamps and put a couple of beads on the ends.
