Page 2 of 2 FirstFirst 12
Results 31 to 51 of 51
Thread: MIG weld basics - spares, useful shit to have, resources
    16,730
    Any tips to stop the wire from unravelling the minute you try to feed it through the roller?
    Hold it really fucking tight.
    I guess you could try running a strip of Gaffer tape around it?
    VIC
    1,339
    When it happened it was literally like in a cartoon where they open the box and shit goes flying everywhere
    Yeah might give that a stab, surely it would have to help
    16,730
    As for the ear plug - there should be hole you feed the wire through before it hits the feed roller - feed the wire through the earplug before it goes through the hole. Some welders use a short length of liner there too.
    VIC
    1,339
    Has a short piece of flexy spring as a guide there prior to the wire hitting the roller, not sure how much space is avail [im using the 5kg reel] but ill give it a stab thanks
    Registered User MZ21's Avatar
    Sydney, NSW, Australia
    6,735
    Coregas (bunnings) is now doing e bottles. Bit of extra deposit but much more useful if welding regularly.
    Ps. DO NOT USE SHITTY DISPOSABLE BOTTLES!!!!
    Australia wide? Only seeing D size on their website, would be good to swap my D size out and pay the deposit difference to go up to E size
    5,711
    Coregas announced via faceballs last month. Pretty sure its aus wide. Check bunnings site or give them a call.
    6,735
    Just called local no E size in stock. Looks like they haven't rolled out yet to NSW. Going to hold off swapping my D out until they come in stock. E will be so much better, more than twice the gas for a about 1.5 x the price.
    1,431
    Morning gents.
    -Gas and Gasless wire; is there actually a difference between the two
    -Anti-spatter sprays; do they actually work?-
    My 2 cents;
    The metal in the wire is almost the same, but gasless is hollow with a flux core that melts during welding and prevents the weld metal from oxidising as well as minimising spatter. You therefore need to use a larger flux cored wire to put down the same amount of metal (called the deposition rate) e.g. 0.9mm MIG is about the same as 1.2mm FCAW.
    Anti spatter spray works, but home brand cooking spray works just as well.
    Wear decent gloves so you can feel what you are doing. Use the shit ones for grinding only if you are a tight arse like me. Learn to stand with your feet wide apart or wear good boots - molten metal is hot!
    6,735
    Tip for anyone going via Bunnings (pissed off now!)
    If you get the Coregas from bunnings *keep* the receipt! Otherwise you get a refund should you wish to return the bottle. Best you'll get is a store credit. Pissed off as bought mine almost 18 months ago and fucks knows if i've kept the receipt.
    Went to exchange an Argon bottle this afternoon even then they kicked up a stink because I didn't have the receipt. I said mate that empty bottle is my receipt, give me another bottle, fuckwit relented in the end.
    Registered User Shane001's Avatar
    Jul 2007
    1,235
    Would have thought you'd need to keep the receipt to get your deposit back?
    6,735
    When considering Coregas is owned by Westfarmers, I wouldn't think they'd be cunts about it. I have a box full of Bunnings receipts, and the only one I can't find is the fucking receipt for the initial deposit/purchase. It's not like I'm going to return it anyway, just pisses me off that I wasn't told about it from the beginning, even the receipts they give you fade after 18-24 month, so I would have taken a photo of it and sent myself an email attachment.
    5,711
    Yeah when i got my argon and 75/25 they photocopied the receipts for me and told me the speil. Not sure on the reasoning but they both live in the filing cabinet.
    May 2004
    5,148
    when you feed the wire into the liner, then setup the wire tensioner, just wind the wire spool backwards so there is always pressure against it. Once you've tightened the tensioner down against the wire feed motor, the spool wont unwind.
    CNGAF rowdytoot's Avatar
    hotel vast horizon
    10,259
    Went local bunnings today to get MIG gas after happily handing back my empty cylinder to BOCunts last week. Took my 299 bucks (deposit plus 99 for the cylinder), then went to get me the cylinder... 10 minutes later, sorry we don't have stock... another 10 minutes to refund me...
    FFS... BOC costs but at least you can get the fucking gas when you needed ... closest bunnings with stock is the same distance as BOC.... (about 25 minutes each way, and meh...)
    No welding this weekend!
    Maudsland, Gold Coast
    6,582
    Quote Originally Posted by MZ21 View Post
    I take a pic on me phone via one note (office 365), bunnings shit goes in the bunnings folder other shit goes in that stores folder... is great for that and syncs to the PC.
    12,985
    I didnt think anyone did gas at bunnings anyway? Usually more expensive than the dedicated tool shops that actually have gas in stock.
    719
    Not all the Bunnings stores do gas the two closest to me donít. Per Fondles, photograph your deposit receipt as soon as they hand it to you. I got a deposit refunded off a photo no probs.
    Anyway Iíve now moved on to the BOC deal, much cheaper for the amount Iím welding
    Slobart.
    94
    Gasweld in Fyshwick do swap mig gas, and always have stock in varying sizes.
    Ellis Juan mizone's Avatar
    4,607
    https://www.machineryhouse.com.au/K0...utm_source=EDM
    For retard (Me) who wants to weld upto 1.8mm steel and 1.3 to 1.6mm car panels. Will be rarely used - 2 to 3 times a year.
    Or am I better off saving up and buying a Linclon/Miller 180A unit?
    452
    If hardly using it I say start with the cheapie, that deal seems OK, and its from Hare and Forbes so they will be there if it plays up. Unimig is well known albeit Chinese.
    Personally, I do a fair bit of welding now and use the Lincoln Mig stuff, but I started with a cheapie Rossi and it was better than I was for quite some time.
    I still use a Rossi AC/DC TIG and until it dies its good enough for me.
    Radical SR3
    HSV R8
    BMW 325ti Proddy Car
    4,607
    Quote Originally Posted by GHZ28 View Post
    Thank you sir.
