Results 1 to 23 of 23
Thread: Electric hydraulic power steering pump and speed control?
    11,291
    On the MX5 a common mod is to depower the rack by just looping the ends. Mine has this done to it.
    Now on khanas it can be a bit of a pain with a depowered rack, so i have been considering whether it is worth getting an Astra electric PS pump or similar and re-powering the rack like that. Now, what would be very useful is to be able to link that with a speed input, so that it depowers over a certain speed. This seems to be what the MR2 pump is capable of, but with far more electronics.
    Anyone mucked around with this sort of thing?
    The new nugget
    3,618
    Have you ever driven a NA6 with factory power steering? It's a night and day difference compared to the factory non powered cars.
    I'd suggest an electric pump and trying it without the speed input stuff before worrying about it.
    1,911
    the astra ones are heavy, i'd try fit a factory pump as plan A and an electric assist column as plan B before going down that route.
    3,618
    Is it possible to get decent steering feel with an electric assist column without needing a supercomputer to run it?
    1,911
    AFAIK someone was selling a controller box for the toyota columns
    CNGAF rowdytoot's Avatar
    hotel vast horizon
    10,270
    yup.
    Takai- ask smee what he ended up with in the rally rolla. He has an electric column setup with a controller I think.
    1,398
    The Gayzelle has an astra pump in it, nothing fancy controlling it just a dash mounted toggle switch.
    Works well, has good steering feel and you soon realise if you have forgotten to turn it on
    3,618
    yup.
    Gravel tyres, dirt road and FWD. Very different.
    hotel vast horizon
    10,270
    Same same bit different, it's an option..
    Personally id just repower the rack and fit a cooler...
    11,291
    Nah, will live with manual depowered rack over retrofitting an electric. Could go back to the stock unit, and might do when i go BP, but for now refitting the NA6 PS doesnt appeal. Last NA6 i drove with PS felt quite twitchy above 80, whereas this feels quite stable up and above highway speeds.
    The new nugget
    Dec 2005
    Seattle
    2,974
    it always seemed to me like a simple pressure switch would solve all of this.. start turning wheel, fluid flows, pressure drops below X so pump turns on. stop turning wheel, pressure builds up again, pump turns off...
    But there is probably something obvious I'm missing about hydraulics or something that would stop this from working
    Adelaide, SA
    1,042
    Fraud, the way at least the commodore power steering racks I've pulled apart work is that when there's no torque through the input shaft, the fluid flows freely through a bypass hole. So very little pressure.
    As you apply torque through the input shaft it starts closing the bypass hole (increasing pressure against the pump) and opening a hole connected to the hyrdaulic "ram" on the rack, which of course provides the assistance.
    11,048
    Could you put an i30 rack in there which is full electric assist, no hydro?
    16,733
    I thought they did it in the column?
    11,048
    Actually that maybe true. Might be easy to adapt.
    Dec 2005
    Seattle
    2,974
    Quote Originally Posted by goose View Post
    That makes sense thanks!
    11,291
    Quote Originally Posted by Fraud View Post
    Hence why i want to turn it off entirely when at speed.
    Interestingly i found that the power steering rack is a tighter ratio rack (lower turns lock to lock) than the manual one, which is probably why it feels pretty ok at highway speeds when depowered.
    The new nugget
    Adelaide, SA
    1,042
    Can you do something like a pressure bleed off? Maybe the pressure on the pump relief valve can be made adjustable somehow?
    The commodore variable assistance racks use a PWM solenoid to bleed off pressure increasingly with speed.
    11,048
    Just grind the pressure relief spring in the pump down at bit at a time.
    10,063
    Have seen guys using these before:http://www.heidts.com/part/adjustabl...-valve-ps-101/
    Registered User MWP's Avatar
    1,840
    I still do plan to make & sell my Toyota CANBUS based EPS controller sometime.
    It'll work with most, if not all, 2005+ Toyota EPS systems (including the 86).
    Adelaide, port syieed
    2,558
    When will that be???
    Still running in limp mode on my setup and it seems to be running fine. Have not been able to beat it, even on tarmac and with tight hairpin corners.
    Problem identified though.
    If you lock a front wheel, and it is enough to stall the car, it interrupts the power supply to the power assist. This makes the steering very heavy (not a good thing when you are trying to conquer a slalom between big hay bales on a wet dirt road at speed and even on loose gravel). It also takes a while to identify it has power to it on start up.
