Results 1 to 15 of 15
Thread: making an efi manifold.
    VW Service Bloke Sloth's Avatar
    3,889
    so, my basic plan is to use a stock manifold and modify it to take a plenum and throttle body.
    i guess the main quiestion is, will this work?
    manifold is alloy, there are 2 flanges where a pair of su's bolt on. my idea is to use another cars plenum and cut the runners off, add a plate and studs and then bolt it to the carb flanges or weld it. then put a throttle body on the end.
    is this gonna have distribution issues or not?
    Only be concerned if that Dunning-Kruger Motorsports bloke is there and goes all Captain Damphands McGigglefingers on you after a couple of lemon squashes....
    I'M NOT A HOOKER BUT 20 BUCKS IS 20 BUCKS...
    robslothyoung - follow me on insta.
    This space left blank Ben Wilson's Avatar
    3,611
    It should work, but it will probably be just as hard as building a manifold from scratch.
    Imagination is more important than knowledge.
    16,388
    Use an XF falcon manifold as the basis - the runners are removable from memory.
    1,065
    I built one for my datsun exactly the same way you're doing this one. Runners 2 and 5 will run lean, due to differences in airflow distribution. Not *that* big a difference, but a little. You'll see it on the plugs.
    I used Mitsubishi 4G92 throttle bodies for mine, ran the dual 50mm throttles. Ran REALLY hard for what it was, and I just shortened and reworked the existing SU's linkage to make it work.
    7,777
    Is this a filthy triumph manifold? If so using a PI manifold seems like a no brainer.
    6,206
    Registered User clutch-monkey's Avatar
    brisbane
    4,937
    i use a PI manifold with circular airbox and throttle on it (removed here for cleaning)
    16,388
    Ah, didn't read the question properly, assumed you were going to cut it at the flange and weld on fresh runners.
    3,889
    thanks blokes. sat at work today and had a bit of a brain wave:
    3 sets of those would be far fucking easier. just need to figure out wtf the injectors are.
    GTFO of my ED doctor ed's Avatar
    irgendwo
    4,571
    what is that?
    Mit freundlichen Gre
    Quote Originally Posted by Keith Duckworth View Post
    3,889
    cb500r throttle body. $100 each on ebay.
    Gimme six Schlitzes Beavis's Avatar
    Hanover, NH, USA
    7,265
    Was gonna say, that looks awful like two of my CRF250R throttle bodies stuck together.
    That fucking fuel hose assembly is $50 from Honda though...
    Retired dsm2002's Avatar
    1,357
    ^^^ whats the cylinder spacing on those?
    3,889
    only downside is the $500+ asking price for something that needs modification, and theyre rare as. otherwise id happily do that.
    VIC
    1,181
    Can you get triple DCOE manifolds for these cheap? GTR throttle bodies are basically just throttle plates with 45mm butterflys and an almost identical [like, im talking 1mm off] center to center as a DCOE
