Results 1 to 2 of 2
Thread: Brake master cylinder question
    Registered User Ferrarist's Avatar
    May 2016
    STZG
    7
    Have standard tandem brake master cylinder and i plan to convert my braking system to non-ABS.
    My question is which port(pipe) provides more volume(pressure) to brake calipers - rear(closest to servo) or front.
    AFAIK ABS use one pipe for FR and RL wheels while other is for RR and FL - but not 100% sure. And that's my concern - if ABS distributes pressure to FR-RL(main pipe) and RR-FL(second pipe) will it make any difference connecting wrongly(one for rear wheels, other for fronts)??
    16,733
    Unless it's a stepped bore master cylinder, the pressure/volume will be the same from either port.
