Results 1 to 3 of 3
Thread: Barra Bcm etc
    Jan 2009
    hobart
    721
    Barra Bcm etc
    1/ I haven't searched so I may be going over old ground
    The Xr6t racer still has the 6 stacker in the dash and a heap of other stuff in the xr6 that I really don't want and is heavy including the key ignition. I pulled the ICC out today to experiment and it won't run without it. If I plug just the bcm in and nothing else it will start but has all the engine warning lights on. Given blokes are converting Barra's into everything with just an ecm and bcm I'd assume it's doable but how?
    18,317
    turn the security off in the PCM... may have to fit start button depending on model of car
    Jan 2009
    hobart
    721
    thanks mate
