Results 1 to 11 of 11
Thread: Holden 6lt l76 problems
    Dec 2016
    Mexico
    21
    Hey all, recently bought myself a wl statesman 2006 with the 6lt l76 and ever since its been a pig.
    No power no acceleration at all, struggle to climb to 60 wont change into gear withkut backing off from WOt
    I would say maf but its been mafless tuned and has a ramair intake
    Has anyonr experienced similar with this engine and what was the fix...
    Hoping this isn't the time and someone has come up across this before as i need it fixed to get it rwc and in my name
    Only thing i noticed is the ltft in bank 1 are up around -15 where ltft on bank 2 is about -1.5 to -2
    Really hoping it doesnt need a dod delete done already
    Car was left with a dead battery for 6 months or so could the ecu have lost the tune?
    Cheers
    6,548
    The ECU can't have lost its tune no. Was it running OK before the dead battery for 6 months?
    How's the fuel situation? Stale/water etc
    are hairy Dogsballs's Avatar
    7,830
    O2 sensors. If one is slow to heat up or dead, ecu has a hissy fit. Dumps in fuel and run like shit. Sometimes the connectors also get shirty with loom extensions for long tube headers
    Sent from my HTC One M9 using Tapatalk
    Look behind you... Milkman Don's Avatar
    look behind you
    3,199
    VEs can be pains in the arse. Our old clubby battery went flat a couple of times and played up a bit when restarted, a good Italian tune and letting it sit with aircon on helped if I wasn’t near a laptop.
    As balls said the o2s play games, also give the maf a clean that may assist also. Look for any pcv leaks too.
    I agree with Rdyno
    25 schmeckles? Do the safety dance.'s Avatar
    4,488
    You'll know when it's DOD delete time, it'll drop a cylinder at best or not run at worst.
    4,273
    Whats the fuel pressure like? Never been a fan of letting fuel sit in things for extended periods of time.
    Fuck I'm retarded
    U gon dun wha now? Speedyblue's Avatar
    Mar 2007
    Queensland, The Tax State
    1,130
    Are these flexfuel? E85 sitting around wouldn't be good.
    Ya'll don't know what it's like. Being male, middle class and white.
    DakDakDakDak Crais's Avatar
    Townsville
    1,255
    06 wont be flex fuel. that came with series 2
    '67 Volkswagen Beetle 1300cc
    '09 VE SS
    Quote Originally Posted by Scrad
    You are like some sort of car rapist, Sticking things where they don't belong, and often don't fit nicely
    Dec 2016
    Mexico
    21
    So got some time to spend on this thing over the weekend, looks like it's dropped compression on the LHS bank so heads off but no noticeable damage, will check for metal fragments soon.
    I am thinking it has collapsed the cat on that bank possibly through bad 02's dumping excess fuel or something. if no chunks of metal are in the oil, going to throw a set of head gaskets and bolts and it button it back up hit the key with the exhaust off and see what happens.
    If not, has anyone got a good lead on a reasonably price L98? or a DOD deleted L76/L77
    Cheers
    4,488
    If you do a DOD delete you need to do a cam at the same time, and a re-tune. If you just want it going again you can just replace the DOD lifters, they aren't that expensive.
    look behind you
    3,199
    An L77 is basically an l98 with the DOD shit. In my humble opinion find yourself an LS2 cam and lifters, that will liven it up enough to not take away the standard feel of it.
    Or go to town and plonk a stick in it that will wake the neighbourhood
    I agree with Rdyno
