Results 1 to 29 of 29
Thread: lifting front inside wheel on turns.
    Jan 2006
    australia
    583
    Hi Cunts.
    Car is a s13 silvia.
    Lightly modified but very competitive in its current chosen format, Hillclimbs.
    I ran at legends of the lakes last weekend and the car went pretty well.
    Felt good. A little bit of oversteer on corner exit under power but it is a turbo car so expected.
    But after looking at photos after the event it cocks the inside front, not massively but enought that its off the ground in a couple of corners.
    Its setup as i would any of my turbo rwd circuit cars, but on the track they always seemed to corner pretty flat.
    Is this having a huge effect on times if its cocking a wheel?
    I know that four on the deck will corner faster than three in a circuit application but is it as critical on a bumpy hillclimb surface?
    Will i die?
    Cheers
    Originally Posted by Tut
    THEY SHOULD ANALYY RAPE THEMSELVES WITH A FUCING CACTUS UPSIDE DOWN WITH COCONIUTS AND PINEABPPLES AS CHRISTMAS BALLS THE FUCKNIG THIEVENG CUNTS ID RATHER DIE FROM HAVING A RAINBOW UNICORN URETHRALLY RAPE ME THAN TO FUCKNIG DO BUSINESS WITH THEM CUTNST EVER AGAN
    2,031
    I reckon it's as much the form of that uphill corner and a bit of powerdown squat. Do you reckon the spring is getting to full droop or is the swaybar holding it up a bit?
    The tyre in the air isn't slowing you down, indeed you are likely getting great weight transfer for traction & punch out of the corner......
    Having seen what else you've survived, this ain't gonna kill you.
    " Racing cars don't have doors. Toilets have doors" : Keke Rosberg
    *Italian Stallion* milo's Avatar
    Feb 2003
    Stuck in a Lift....... In Wollongong!
    1,430
    What are the Swaybar Sizes?
    1969 Datsun 1000 Sedan
    1989 1.6l Daihatsu Charade
    Life For me Has it's UP'S and DOWN'S........ I fix ELEVATORS
    Heyfield
    178
    Suspension details?
    793
    Nothing wrong with inside front off the ground. Indeed, pretty much any old escort lives with the front off the ground. As above, softer rear spings/bar/roll stiffness is good to get power down out of slower corners, which is typical of hillclimbs in comparison to circuit racing corner speeds. Power down is king in a powerful rear drive car - you want to play to your strengths and that is to get the thing punching hard out of a tight corner with no more than a roll of the wrists into oversteer after the apex. It's all a compromise as ever...
    Central West/Lake Macquarie
    1,382
    Yeah sounds right for hillclimb as long as tge front isn't washing out on the way into corners.
    Jan 2006
    australia
    583
    Factory front. no rear.
    I guess its going to be a compromise.
    Hillclimbs are never going to be perfect flat nor always bumpy.
    It has quite a bit of pace and is easy to drive so perhaps ill just leave it for a bit, maybe play with bump and rebound a bit and keep on having fun.
    xxxx BoboTheMonkey's Avatar
    Jul 2016
    past the berrimah line
    33
    just drive slower
    Registered User adamRSLC's Avatar
    1,612
    My car does the same (VL) after i changed the valving in the rear shocks to allow more squat, combined with not a lot of droop on the front it picks the wheel up on power down out of slow corners. Works well, with a solid improvement in lap times.
    Adam
    Sandown 1.23.31
    Calder 1.05.76
    Phillip Island 1.47.95
    Winton 1.33.30
    H/Hills hill climb 1.03.3(FG XR6T)
    Bathurst 2.47.49
    Apr 2017
    690
    Back in the day, RX3's in particular seemed to drive everywhere on three wheels, and were still quick. It's not ideal, but it's more important that the car feels balanced on that track.
    You could dial it out by reducing front roll stiffness and increasing rear roll stiffness, and find the car goes slower because it oversteers more.
    Just check there's enough droop from static ride height too.
    9,961
    Gibson Motorsport liked to have the rear of their Commodores pretty soft.
    Jan 2015
    1,618
    My old 911 did this at every corner. Stock suspension with front sway bar and semi slicks.
    Bigger torsion bars all round and better shocks made it handle properly.
    Soft setup is slow these days with good tyre technology.
    2,031
    Quote Originally Posted by mph View Post
    This flies against all that I've learnt and all I believe to be true.
Name:	rosberg suspension.png
    My view of motorsport is that everything you do with a car comes down to it's attachment to the pavement. You can have all the power in the world, but you've still got to get it to the ground. How you use your tyres is how you beat your opposition. I still believe that the softest possible springing is going to work your tyres best.
    Disclaimer: Aero platforms need different attributes and clearly you want your center of gravity under control.
    Jan 2015
    1,618
    Itís all relative. Iím comparing to 40 years ago. Spring rates have tripled
    2,031
    It's true, car weights have doubled!
    Jan 2015
    1,618
    And tyres are much better.... anyway. You know exactly what I mean.
    Registered User gmx's Avatar
    815
    But are wheel rates still the same?
    There is some weirdness with MacPherson struts I cannot get my head around and tunas just recommend ridiculous spring rates or want a consulting fee.
    Soft spring, big bar up front?
    Or stiff spring, reasonable/standard bar front?
    I don't believe there's is perfection. I'm not suspension guru and flip flop regularly. If you're lifting a front wheel exiting a corner, I think that alludes to what Roy said; you're getting good workout from your rear end. Is it stable, snappy, grippy? If you try to "fix" the front, you might just end up penalising yourself in other areas of the corner and resisting load transfer to the rear.
    One odd behaviour I have seen in a lot of cars especially BMWs, Nissans, older (tracked) Supras is the front end skids and bounces across the surface when braking/turning in. Surely this is because of the retarded spring rate and dampers they're running?
    16,567
    The big spring rates people recommend for strut frontends is just to try and get around the poor camber gain thats inherent in strut type suspension design.
    Soft spring, big bar will always ride better and work better on a rough surface for a given total roll stiffness.
    Racer 36's Avatar
    Oct 2014
    329
    My 2c.
    Run the softest springs you can get away with.
    What that is will depend on a few factors, but ultimately the stop watch. You can spend your life tuning the car to feel good in one problem corner only to make it a little bit worse in several others more than negating the gains.
    Ideal setup can vary depending on the particular course. (And driver style/preference.. )
    Apr 2017
    690
    Quote Originally Posted by gmx View Post
    The weirdness you speak of is the roll centre height going under ground when you lower the ride height excessively on a MacPherson strut. This causes more body roll, which the uninformed try to correct with stiffer springs and roll bars. Problem is, the higher spring rate and roll stiffness reduces mechanical grip. The better solution is to put the roll centre back to as close to factory as possible.
    FWIW, my philosophy on his subject is exactly the same as 36, run the softest springs and roll bars you can get away with, compensate for body roll with more negative camber, and use the stopwatch to guide you to the optimum setup.
    815
    Is there a true certain way to calculate that for a given chassis. Or wheel rate for a given sprung and unsprung corner mass?
    Going much more complex and OT.. I found this online calculator/form for E46s: http://www.fatcatmotorsports.com/FCM..._M3_Online.htm
    Apr 2017
    690
    The better method is to calculate or measure spring frequency. For a sedan with limited or no aero you want 1.5-2 Hz
    815
    That seals it for me. The "kit" I'm being pushed to would be 2.15hz which imo, is way too much regardless of good the damper is. Ty
    Apr 2017
    690
    You are welcome.
    I just stumbled upon this article, which is relevant to this thread:
    https://motoiq.com/how-to-make-crappy-cars-handle-well/
    815
    ^ good article. I actually read that a while ago. I'm not lowered, and probably not going to.
    bp, are you lowered?
    On the forums I'm seeing the same argument, "when lowered -> messes with roll centre". Well yeah this applies in compression during cornering for sure. But I'm not a stance cunt so what happens if I just stay with my superior German geometry ride height and travel? lol.
    Mar 2005
    wollongong
    1,103
    Quote Originally Posted by Sprinkles View Post
    It was reckoned to be the best way when live axles were the standard gun set up. Lift the front to load the rear and maximise traction. With fancy diffs, IRS and sticky wider tyres that might not apply so much now, keep it flat and maximise all contact patches?
    Jan 2006
    australia
    583
    Only slightly lowered. Iíve check all the arm angles, bump steer, and got rid of most of the anti squat out rear too.
    I want to get more consistent with times then start playing with bump and rebound against the clock.
    Itís already pretty fast and forgiving so I donít want to change too much.
    code
    Peoples Champ Fatboy's Avatar
    11,586
    Quote Originally Posted by bp18t View Post
    Will i die?
    Eventually yes. But from aids, not cocking a wheel during hillclimbs...
    If it's fast and feels solid cornering go with it. Trying to fix it will probably fuck the balance you have now if it's only getting slight oversteer....
    aka SpaZdA (tm) mondo2000's Avatar
    1,377
    With car set up you can fall into a bit of a trap, where if something feels good to the driver, you go too far in that direction. The Escort handled pretty much as you described and the driver thought it was awesome "because it is getting so much drive out of the corners which is very important on hill climbs." Which is true, up to a point. It stops being true when the driver is focussing on the drive out of corners, he is maximizing that, but neglecting the corner up to the apex. Good drive feels good, so more drive must be better. Except it isn't if all you're doing is making up for lost corner speed.
    The stop watch tells no lies.
