Results 1 to 5 of 5
Thread: Air Compressor build with a Auto-man Air compressor head
    1,009
    Came across this Automan 2 stage air compressor head for the right price.
    The data plate reads 42 Cfm with a working pressure of around 171lb
    The Automan Type is a 1004T 7B is that means anything
    I am intending on mating this to a petrol engine, therefore I will need a unloader valve to control the entire assembly.
    Looking at the pump head it appears that it has a pair of ports in the head directly over the valve gear in the head with a diaphragm valve and a threaded port. this gives me the impression that the air compressor can run in unloader mode (presumably installed on a electric system)
    Looking closely at the diaphragm valves in the head I can't see any exhaust ports venting to outside the unit. Would this mean it's bypassing the inlet valves on the head
    I guess I am looking for information on the unloader head on this unit. Or a similar unit.
    "1000 safari suits and matching blunderbuss, along with a 1:56 scale diorama of a porn movie set" was what I originally figured you were hiding, but I'm guessing it's probably an E30.
    Flogger of dead horses kneelo's Avatar
    Mar 2011
    Quindanning WA
    447
    I have a big 3 phase compressor I got for free that i am doing a petrol conversion on. I've got as far as mounting the new motor so far. The plan for the unloader is an electric ball valve to vent the discharge of the compressor before the non return valve to the receiver. This will be controlled by an arduino that will also start and stop the motor and adjust the throttle. I like the idea of being able to easily adjust the running pressure the compressor depending on what I'm doing and having it start and stop by itself. The plan is to mostly use it with my sandblasting cabinet.
    You can get mechanical unloaders on ebay that vent the discharge and throttle down the motor but I like making things more complicated than they need to be.
    Jul 2007
    Blackwater, QLD
    1,669
    you could quite likely use a governor valve from a truck air brake setup too. some of the petrol compressors i've looked at over the years had a spring and an air ram to shut the throttle on the motor when it got up to pressure.
    The throttle linkages jammed on the CDs in my old Triumph 2000 and stuck it at WOT.
    I didn't realise for about 15 mins as it never broke the speed limit.
    Registered Fuckwit oioioioioi's Avatar
    Feb 2007
    2,187
    Quote Originally Posted by kneelo View Post
    I was going to ask why you don't just use a standard regulator to control the running pressure instead of building a convoluted computer system to do an incredibly simply mechanical job - then you explained
    4,294
    Quote Originally Posted by briney View Post
    Yeah, a D2 valve, cheap as fuck from every truck spare parts shop in the country
    Fuck I'm retarded
