Page 1 of 4 1234 LastLast
Results 1 to 30 of 118
Thread: ZD30 - Pin fell out of the Grenade
    Opens GAZ914's Avatar
    1,624
    So I've had this thing for a couple of years after crashing the previous one.
    It needed a head on it when I bought it and since then I've put about 100,000 kms on it.
    It has done a great job towing the racecar and camper trailer around - albeit slow up the hills.
    Had the usual 'NADS' - EGR Block, Dawes Valve, Catch Can plus boost and EGT guages to keep an eye on things.
    Driving to work on Wednesday morning, it lost power and made a shed load of smoke.
    The smoke was the oil being pushed out of the catch can onto the exhaust.
    Managed to limp it home and park it, leaking oil everywhere.
    I'm 99% sure its put a hole in a piston, so game over.
    Leaning towards sticking in an LS1 with the existing auto as the best bang for buck 'fix'
    Race Car: VT Commodore (Murray)
    www.vsport.com.au
    sexy fingers
    Nov 2016
    Traralgon, Vic
    212
    Yeah fuck the cancerous ZD off. Donít care what people say that they get them reliable theyíre still shit.
    Mine went bang 3 times before I learnt.
    VF2 Redline Ute
    E36 Track Nugget Project
    Registered User landbarge's Avatar
    Aug 2016
    69
    Why not boosted 4.8l?
    Quote Originally Posted by GAZ914 View Post
    Sent from my Pixel 2 XL using Tapatalk
    1,624
    Quote Originally Posted by landbarge View Post
    Seems the 4.8 is a bit of a nugget - LS1 has more scope
    www.vsport.com.au
    Gympie, QLD
    2,035
    Ls1 is still going to be slow as in something that heavy. What about Barra? Boosts and turbo torque will go a long way towards moving it with ease.
    Projects:
    '90 2jz-gte 929
    4,974
    Arenít 4.8ís pushing a billionty hp in Dubai etc?
    Gympie, QLD
    2,035
    Yrah, but they need rods put in them. 10psi is apparently their limit, although 10psi in a 4.8 would still go well.
    Projects:
    '90 2jz-gte 929
    24,348
    Gen IV 4.8/5.3 has the good rods. Open up ring gaps, chuck a set of head gaskets, springs, cheap cam and try and keep the power under 1500hp on E85.
    Aug 2016
    69
    https://youtu.be/BBzWVqJcL1Q a few years ago now
    Desert Nigga vet 180's Avatar
    Dubai
    3,337
    4.8 is far from a nugget. I still vote barra though.
    1,624
    My thinking is that LS will be better at low revs (larger capacity) plus it is simpler and I can always add boost as required later.
    Might do some more research though.
    www.vsport.com.au
    8,707
    LS isn't a low down grunter at all. The Barra is though. Especially with the added load of 3T.
    Dubai
    3,337
    I vote barra for the same reason. I think it produces more torque when needed low/mid rpm. LS ainít great down low but the do rev well for a pushrod V8.
    Barra is also cheap and plentiful.
    2,394
    Barra for the win...
    3,287
    Unless you are planning on boosting the lsjuan it will be a slow thirsty nugget. Iíd run with the Barra or turbo 4.8 litre otherwise wouldnít put less than a blown 6l in it
    9,823
    I'd lean towards the 4.8, with or without boost.
    8,005
    Arent LSA's cheap for what you get?
    Barra's are great at low down torque. An FG XR6T motor with the smaller turbo would be the go but still makes good power with the usual mods.
    Why does anyone but a Patrol with a ZD30 anyway given how well known there explodyness is?
    agricultural aerobrick's Avatar
    Jun 2016
    Tas
    749
    Because they're so cheap. A guy I know who's not good with cars just replaced a Volvo and a Micra with two auto ZD30 patrols, on gas. I drove one of his for a few Kay's with a trailer full of gravel and wanted to pull over and top myself.
    Registered User Gats's Avatar
    7,491
    They don't all blow up. I know of a couple that are trucking along just fine with 250k+on them.
    Slow as fuck, but so was a standard TD42
    Gympie, QLD
    2,035
    Quote Originally Posted by aerobrick View Post
    Why would you waste money putting putting gas on a diesel, especially a zd30?
    Projects:
    '90 2jz-gte 929
    Gympie, QLD
    2,035
    Coincidentally the only two people I've known with early zd30's have both had 360k km and 380k km on them respectively and both on original motors. Both oldies from out west that didn't even know there was meant to be issues with them when I brought it up.
    Projects:
    '90 2jz-gte 929
    Jun 2016
    Tas
    749
    😂😂😂 Clearly my morning hangover has far more powerful than I realised. His are the old petrol shitbox. Much apologies for 'tarding up the thread
    8,005
    So any idea which way you're going to go with this yet?
    Jan 2013
    3,923
    a12 on dellortos.
    12,921
    Nine2nine was talking about tb48 motors, not 4.8 LSs.
    +1 for barra. There is a page dedicated to barra patrols on Facebook. They go hard.
    U gon dun wha now? Speedyblue's Avatar
    Mar 2007
    Queensland, The Tax State
    1,144
    Didn't someone have a 20B looking for a home?
    Ya'll don't know what it's like. Being male, middle class and white.
    1,624
    Plan at the moment is LS1 with adaptor plate to the RE4 auto that is in it.
    Modified valve body on the auto plus TC modfied for lower stall, etc.
    Ball park 10K conversion - depends on how much I end up buying vs making.
    While a Barra turbo 'may' be better, the LS1 will be less work and sound better
    I don't think the cost will be any different and can always go boost if needed later.
    As much as it would be great to do a 'cool' project, I would rather spend money on the Commodore/motorsport.
    The aim of this is to be able to tow the campervan and car trailer reliably - hopefully slightly faster than the ZD30 without using too much extra fuel.
    I like the simplicity of NA in this application and the auto should make up for any 'off idle' torque issues.
    If I don't like it, then I can sell it and probably recoup the conversion cost and do something else
    www.vsport.com.au
    sexy fingers
    Nov 2016
    Traralgon, Vic
    212
    Why the low stall?
    VF2 Redline Ute
    1,624
    Quote Originally Posted by SuperHoon View Post
    Why the low stall?
    ZD30 stall is about 2500, LS! is about 1800 I believe.
    The guy I was speaking with does quite a few transmissions for LS1 conversions, so i figure he has sussed it out already.
    www.vsport.com.au
    Dubai
    3,337
    Before you commit to the stock auto with different converter etc I would check out the options and prices of changing to a 6L80 auto. They do make transfer adapters for that trans. 6 speed trans will be better for towing, provide better fuel economy and 4:1 first gear through an auto is going to be epic off-road.
    As you said it will be 10k for the convention, if it cost the same or a little more for a result thatís twice as good itís worth researching. In theory the 6L80 will be much better and my experience with the new Denali indicates that you will get more fuel economy from the gearbox than the engine. However I have no practical experience with the 6L80 with as LS in a patrol other than the fact I know they make the adaptor. If I was in your situation I would be researching.
    The 6L80 ratios
    4.03
    2.36
    1.53
    1.15
    0.85
    0.67
    RE4
    2.784
    1.54
    1
    0.694
    So you get a much lower first gear for off-road, a much better spread of gears, more torque to the ground from standstill to highway speed, more torque to the ground while off-roading, a better cruising gear and less jump between each gear, if you have bigger tires this will really effect your fuel economy.
