Results 1 to 2 of 2
Thread: Mini Class D amps, Cayenne upgrade
    366
    I'm about to take on an upgrade of the stereo in the Cayenne.
    These things are a pain in the arse because the head unit, amp and stacker all communicate over a MOST fiber optic link. There are adaptors, but they are expensive and have limited functionality.
    The factory setup has 9 channels of amplification. I'm going to turf the front center and rear effects (in the D pillars) leaving me with 7.
    I reckon packaging 2x 4ch mini amps is going to be much easier than full size A/B amps. Like these:
    https://www.clarion.com/au/en/produc...410/index.html
    https://www.pioneer.com.au/shop/car/gm-d1004/
    Has anyone used these? 2ch will be driving the 8" mid bass in the front doors, and I will bridge 2 ch for a 10 or 12" sub in the boot. The clarions have no low pass filters, so I'm wondering about their suitability even if I can use the crossover in the head unit.
    At this point I'm leaving the factory drivers which are all 2ohm, so can't run them from the head unit.
    Not having cross over controls on the amp is going to make the front tricky too, as it is a 3 way setup driven by 2ch per side.
    Happy to look at other options if anyone has any ideas.
    Here's what I'm working with.
    366
    Just for some closure on this.
    I went with a Kenwood X302-4 that drives the front and rear splits, and a Cheapie JVC A/B 4 ch to drive the 8" door woofers and a sub in the boot.
    Both amps fit in the space where the old amp and cd changer were, so it's pretty neat.
    I left all the factory Bose speakers for the time being and it sounds pretty good.
    I used the 3 way crossover in the new Kenwood head unit which took a while to get sounding right.
    It was worth it for the upgrade in functionality (reverse camera and car play were the big ones) and being able to get rid of the separate hands free kit and aftermarket aux in, but it was a big job.
X vBulletin 4.2.5 Debug Information
  • Page Generation 0.13090 seconds
  • Memory Usage 8,336KB
  • Queries Executed 14 (?)
More Information
Template Usage (30):
  • (1)SHOWTHREAD
  • (1)ad_footer_end
  • (1)ad_footer_start
  • (1)ad_global_above_footer
  • (1)ad_global_below_navbar
  • (1)ad_global_header1
  • (1)ad_global_header2
  • (1)ad_navbar_below
  • (1)ad_showthread_firstpost_sig
  • (1)ad_showthread_firstpost_start
  • (1)ad_thread_first_post_content
  • (1)ad_thread_last_post_content
  • (1)footer
  • (1)forumjump
  • (1)forumrules
  • (1)gobutton
  • (1)header
  • (1)headinclude
  • (1)headinclude_bottom
  • (2)memberaction_dropdown
  • (1)navbar
  • (4)navbar_link
  • (1)navbar_noticebit
  • (1)navbar_tabs
  • (3)option
  • (2)postbit_legacy
  • (2)postbit_onlinestatus
  • (2)postbit_wrapper
  • (1)spacer_close
  • (1)spacer_open
Phrase Groups Available (6):
  • global
  • inlinemod
  • postbit
  • posting
  • reputationlevel
  • showthread
Included Files (28):
  • ./showthread.php
  • ./global.php
  • ./includes/class_bootstrap.php
  • ./includes/init.php
  • ./includes/class_core.php
  • ./includes/config.php
  • ./includes/functions.php
  • ./includes/functions_navigation.php
  • ./includes/class_friendly_url.php
  • ./includes/class_hook.php
  • ./includes/class_bootstrap_framework.php
  • ./vb/vb.php
  • ./vb/phrase.php
  • ./includes/functions_facebook.php
  • ./includes/functions_bigthree.php
  • ./includes/class_postbit.php
  • ./includes/class_bbcode.php
  • ./includes/functions_reputation.php
  • ./includes/functions_notice.php
  • ./packages/vbattach/attach.php
  • ./vb/types.php
  • ./vb/cache.php
  • ./vb/cache/db.php
  • ./vb/cache/observer/db.php
  • ./vb/cache/observer.php
  • ./mobiquo/smartbanner.php
  • ./mobiquo/include/classTTConnection.php
  • ./mobiquo/smartbanner/head.inc.php
Hooks Called (72):
  • init_startup
  • friendlyurl_resolve_class
  • init_startup_session_setup_start
  • database_pre_fetch_array
  • database_post_fetch_array
  • init_startup_session_setup_complete
  • global_bootstrap_init_start
  • global_bootstrap_init_complete
  • cache_permissions
  • fetch_postinfo_query
  • fetch_postinfo
  • fetch_threadinfo_query
  • fetch_threadinfo
  • fetch_foruminfo
  • load_show_variables
  • load_forum_show_variables
  • global_state_check
  • global_bootstrap_complete
  • global_start
  • style_fetch
  • global_setup_complete
  • showthread_start
  • showthread_getinfo
  • strip_bbcode
  • friendlyurl_clean_fragment
  • friendlyurl_geturl
  • forumjump
  • cache_templates
  • cache_templates_process
  • template_register_var
  • template_render_output
  • fetch_template_start
  • fetch_template_complete
  • parse_templates
  • fetch_musername
  • notices_check_start
  • notices_noticebit
  • process_templates_complete
  • friendlyurl_redirect_canonical
  • showthread_post_start
  • showthread_query_postids
  • fetch_postattach_query
  • showthread_query
  • bbcode_fetch_tags
  • bbcode_create
  • showthread_postbit_create
  • postbit_factory
  • postbit_display_start
  • postbit_imicons
  • bbcode_parse_start
  • bbcode_parse_complete_precache
  • postbit_display_complete
  • memberaction_dropdown
  • forumrules
  • navbits
  • navbits_complete
  • build_navigation_data
  • build_navigation_array
  • check_navigation_permission
  • process_navigation_links_start
  • process_navigation_links_complete
  • set_navigation_menu_element
  • build_navigation_menudata
  • build_navigation_listdata
  • set_navigation_tab_main
  • set_navigation_tab_fallback
  • navigation_tab_complete
  • fb_like_button
  • showthread_complete
  • page_templates
