Results 1 to 19 of 19
Thread: Bead Lock question....
    Modulator Southo's Avatar
    Sydney, NSW
    7,503
    OK, So I understand how the outside of the bead lock rims work with the bolting together of the lip to hold the outer tyre bead secure...
    But what about the inside bead. What stops it just popping off the inside of the rim lip when running really low pressures ??
    Shitney
    1,111
    Put a bead lock on the inside too.
    Maudsland, Gold Coast
    6,584
    double bead lock rims are a thing.
    10,061
    8,203
    You still have an internal bump that the bead needs to go over
    Sent from my HTC One M9 using Tapatalk
    Registered User Gats's Avatar
    7,608
    This. Hummers (H1) run a double beadlock with a PVC insert to hold the inner bead against the rim.
    Or there are inflatable inner beadlocks.
    Sydney, NSW
    7,503
    Yeah, I understand how they work, why they are used etc,
    I wasn't aware of double bead locks - and they make sense....but.....
    I was watching some youtube channel where they were sprouting on about how awesome their trucks were and the fact they lowered their tyre pressures to 8psi to get over one obstacle that could have easily been tackled by taking a different line - (but that wouldn't make for exciting TV right...)
    Anyway - they were tugging each other about how great bead locks were and 8psi blah blah and the next shot was a go pro in the rocks with the tyres scrambling in shot and the inside of the rim was standard..
    So by removing all chance of the bead coming off the outside, does it not just mean that the inside is still at risk.. possibly more so as it is the ONLY place where it can come off ??
    (yes, I understand force doesn't exactly work like that - but if you only have beadlocks on one side - you are still at a huge risk of popping a tyre off...)
    6,584
    if the tyre comes off the rim on the front side (assuming not rear mount rim) the tyre can easily slip into the fitting recess which fucks things up real quick... if it came off the bead on the backface it has a lot further to travel before getting fucked up...
    Maybe thats the reasoning why double beadlocks are not overly common and one side "locked" still sorta kinda holds to tyre from rotating around the rim even if one bead is popped.
    Does that even make sense ?
    Sydney, NSW
    7,503
    Yeah, Makes sense if they are different lips
    But I went and checked two sets of rims I have here - one steel and one alloy - and the front lip looks identical to the rear lip..
    So unless specific bead lock rims are constructed differently... it makes perfect sense to only lock the front.
    PARRA MartyHusseinXF's Avatar
    vegas
    6,225
    Locking the bead on one side works pretty well because generally to pop one off you want the tyre itself to spin on the rim as well as just be pushed inwards.
    Sep 2007
    621
    I saw an FJ cruiser wearing these or something similar the other day
    https://www.supercheapauto.com.au/p/...le/519824.html
    It reinforced a certain stereotype...
    7,608
    The other option is to Sikaflex the inner bead to the rim.
    Gympie, QLD
    2,068
    The outer bead is under a whole lot more stress. Ie, if a car is on an angle, the outer bead on the lower tyre would be holding most of the weight, whereas the tyre on the high side of the car wouldn't have it's inner bead under nearly as much stress.
    Projects:
    '90 2jz-gte 929
    Desert Nigga vet 180's Avatar
    Dubai
    3,512
    This. Double beadlocks are very rarely worth the weight disadvantage. Majority of the stress is on the outside bead. I have seen many people pop a bead when wheeling I have never in real life seen someone pop just an inside bead. Obviously have seen a tire come completely off but never just the inside bead.
    To Southo you are thinking of it like “once you lock one side there is more stress on the other” the truth is the opposite happens, as soon as you lock 1 side it stops the tire spinning on the wheel which actually protects the inside bead from unseating.
    Sydney, NSW
    7,503
    Cool thanks..
    8,203
    However in the top end of radial racing double beadlocks are used to stretch out tyres to get maximum tread use out of restricted tyre sizes. x235 guys use up to 15x10, x275 15x12 or 15x14
    jack burton sez bv's Avatar
    1,908
    i've seen plenty of tires come off rims when wheeling, it happened to me when i first got my jeep. never seen an inner rim dismount with beadlocks, and I don't worry about mine. I run 5-6psi or there abouts, sometimes it's got a bit lower when crawling. I'd imagine what marty said is right, its tough for it to come off the rim without spinning somewhat.
    Sunshine Coast
    447
    As others have said the outer bead is under alot more stress than the inner. Some rim designs are suspectable to dropping the inner bead tho, like allied savannahs
    Registered User ar3nbe's Avatar
    Mar 2008
    454
    Generally speaking, offroad its the outside bead that is the first to go. Remove that as a problem and loosing the inside bead is far less likely.
