Page 4 of 9 FirstFirst 12345678 ... LastLast
Results 91 to 120 of 265
Thread: That Fiat guy bought an MX5
    8,928
    I'm leaving that up to camber-Ken @ Accurate. He's set up a few of these now. Once I get a few laps under my belt with this car I'll be able to give him some feedback as to what it's doing and go from there.
    serial cyber nudist YBS1OW's Avatar
    canberra
    834
    interested to know what you end up with.
    ~ mmm...stick boobies~
    SKYHI Motorsport TCR's Avatar
    Jul 2006
    2,721
    Quote Originally Posted by YBS1OW View Post
    You won't know for sure, because Ken doesn't do print outs
    2015 Skoda Octavia RS162TSI
    2004 MX5 SE Turbo
    2016 Toyota 86 GTS (No Pics)
    8,928
    Ended up with -4 front, -3 rear, 6 degrees of castor on the front 0 toe, slight toe in rear. Yet to drive it. He's kept it at the ride heights above.
    Spring rates are currently 8kg front and 6 rear, may end up being on the soft side. Once I know the car a lot more may end up with 10 front and 8 rear.
    Jul 2010
    Mt Cotton
    4,566
    Pretty sure all the MX5 boys like it harder in the rear end.
    no offence
    496
    Those figures look familiar. With the motion ratio of the suspension, the front springs generally end up with a higher rate. From memory I ran 6/5 on a my last NB which was a really nice place for road based tyres. -4deg is certainly the higher end of where I would be unless it was slick shod with decent chassis and body strengthening in which case more was nicer. Mind you, my info is a bit old now and I also always chased wheel travel (esp on droop) over neg camber or lowness.
    Might get myself another MX5 after reading all this.
    Motorsport is a disease, where poverty is the only cure
    The ego writes cheques that skill can't cash - DJ
    8,928
    Well it drives far nicer than expected. Really doesnít feel that much firmer than standard. Certainly donít need a kidney belt. There was some rubbing on the RHF guard. I removed the liners the other night but kept the splash guards in front of the wheels. Looks like it was rubbing there, a Xmas tree plug was broken and hanging and must have been grabbing the tyre on light lock. Have removed the splash guards now too.
    If anything it feels a little soft, I havenít played with dampener settings yet and will reserve judgement until giving it the full rissole on the track.
    CNGAF rowdytoot's Avatar
    hotel vast horizon
    10,269
    8/6 is quite soft on the track and very easy to live with on the street.
    Ive gone to 11/7 and its better on the track and still fine, if firm on the street with the dampers backed off. Will be going to 8 kg rears soon though give a more neutral balance.
    -4 is a lot of camber.. I've only run - 2.5 with my elbjs and the camber wear on my PS3 street is noticeable after 4000km, and tge are ready for the bin (so are the rears but for different reasons... ) but I do drive it hardm.
    Sent from my G8141 using Tapatalk
    8,928
    Yeah, Ken's always loved his camber. Interestingly there's a well known turbo 2B car up here he sets up, runs -4.25 on the rear!
    I imagine there's more than one way to skin a cat and everything needs to be taken into context. Just in here we have vastly different set ups used/recommended. But he's got the runs on the board and I've been using him for nearly 20 years now.
    I'm also under no illusion that things won't be changed up a bit, but at the same time I haven't even belted it on the track yet, so I'm not even at the "trying to drive it quickly, being uncomfortable, gaining comfort, dropping time, understanding what needs to be changed" bit yet.
    Oh, the new intake also sounds awesome at 6-7k!
    Moderator Cal's Avatar
    Nov 2002
    Brisbane, Queensland
    22,654
    Who's car?
    Jul 2006
    2,721
    Who's car?
    I'm guessing it's Mr Ferabees I've never run more than 3 degrees negative on the front, and that was in a fully caged car, big front sway bar, 10kg front springs and R spec tyres.
    2004 MX5 SE Turbo
    Nov 2002
    22,654
    Quote Originally Posted by TCR View Post
    Likewise; I run -3
    canberra
    834
    yeah wow that's camber! I also "only" have 2.5 and 2.5. lucky tyres are pretty cheap for 15s
    8,928
    Cal last week "you need all the camber". Cal this week "I only run 3".
    This isn't a daily driver, it will drive from home to track. I gave the instruction that daily driven tyre wear is not a primary concern when setting up the alignment.
    Asshole rorge's Avatar
    3,888
    Did you fit the ELBJ's? If not you can sell them to me for my garage ornament!?
    '10 Forester Diesel 6Spd - Slow and sensible
    '93 SWB Pajero - Slow but scary
    '89 MX5 B6-T - Scary not slow
    8,928
    Yep, they're fitted, hence the -4.
    Nov 2002
    22,654
    I sent you my alignment sheet you penis
    8,928
    You sent it before you said you need all the camber. If I'm woefully slow next weekend, it won't be because of the wheel alignment.
    I'm actually looking forward to giving a car 12/10ths again without fear of one of 11ty parts potentially not being up to the job.
    Jul 2006
    2,721
    Will be good to hear how you go. Do you have a pyro to take tyre temps, or are you just going to keep an eye on how the tyres wear?
    2004 MX5 SE Turbo
    8,928
    I think I do have one somewhere. I reckon I'll just keep an eye on where this weekend.
    I'm trailering it up too, as while the purpose is to have a car to drive to the track and back, unfortunately I can't fit a swag, tools and kit in a clown car. So at least I shouldn't be putting an un-needed 400 road kms on this rubber. They're pretty bloody soft.
    Registered User Bren's Avatar
    Lockyer Valley, Qld
    2,390
    Sure you can!! I've done it a couple of times with my clubman for sprint meets, hahah!!
    2,653
    Yeah, what Bren said, that's quitter talk.
    I used to fit the four track wheels with R888's a trolley jack, my race kit, and a tool box in my NA6 for track days.
    If you need to take a passenger, well that's a different story....
    Lockyer Valley, Qld
    2,390
    Good point re passenger, that changes things. I didn't even have the passenger seat in my car when I did it
    Nov 2002
    22,654
    I can't fit a swag
    A room at The Criterion Hotel is $70/night.... sif sleep on the ground.
    8,928
    Hmm, might do a trial pack tonight. *cue MX5 jokes*
    I'll definitely be camping *cue MX5 jokes*, bought the swag for this reasons and going up there with a few mates.
    Nov 2002
    22,654
    ^peasants
    Living The Dream
    7,380
    Like everyone else that seems like a crap ton of camber.
    Off the top of my head and it been a very long time the go to suspension spec for a road/track setup was:
    1-1.5 neg camber all around
    0 Toe Front
    1-1.5 mm Toe In Rear
    And as much castor as it'll take, typically 5 degrees though I remember Edo saying that he managed to get 7 degrees into his with I guess a lot of patients.
    Me being a 20-something year old idiot got 1mm Toe out in rear which wasn't a good idea especially with old tyres on the rear at Morgan Park, was super taily and cost bulk time.
    hotel vast horizon
    10,269
    Care to share Cal?
    I've not been happy with my setup for some time--not enough grip and too taily, and I know your thing is well set up and you can drive a bit
    Nov 2002
    22,654
    Care to share Cal?
    Sure, PM me your email address and I'll send you a PDF.
    hotel vast horizon
    10,269
    Thanks dude pm sent..
