Results 1 to 6 of 6
Thread: Supra Torsen Center - What Oil?
    FJ20DEBT
    3,902
    What oil should i be using for the Supra Torsen Center.
    Im assuming it make no difference that its in a solid axle as apposed to an IRS?
    Cheers
    Sep 2007
    all up in yr grille
    5,539
    Torsen is just gears so normal 80w gear oil
    1UZ+1NZ...
    Mexico
    3,971
    When I bought my T2 new I asked torsen themselves (over email and at SEMA) and they gave no fuck for oil. “Just use whatever the gear manufacturer wants” was what they said. So I use oil as per above. Nothing with slip modifiers
    Registered User Shane001's Avatar
    Jul 2007
    1,237
    Yep not a clutch plate LSD so doesn't need LSD oil.
    If track Redline LWS.
    1,911
    oils with LSD additive will lessen torque biasing and make them a little less grabby but hardly noticeable.
    11,291
    Good quality synthetic GL5 is what is TruTrac and Mazda normally recommend for their Torsens.
    The new nugget
