Results 1 to 14 of 14
Thread: Mazda BP-Z3 turbo selection
    8,929
    Hey guys, while I'd still like to squeeze as much time out of the homo-mobile as possible with it N/A, realistically I will be adding a snail in ~ 12 months so I'd like to start piecing together bits.
    The motor is a 2003 VVT Mazda BP-Z3, so 10:1 compression. The requirements are as follows:
    * internally standard motor
    * max of 250rwhp only
    * must be budget friendly
    * must be reliable (as in circuit reliable)
    * must be snappy with a decent power bound
    Currently I am thinking an OEM Nissan S15 T28 would probably fit the bill. I'd like to limit boost to no more than 15psi. I'd prefer to keep it on 98, however if there's significant reliability to be had on E85 I'd run 2 boost settings & flex fuel. I'm looking to run the Nitro Dann manifold and dump pipe, Haltech Elite 750 with plug 'n' play adaptor, Inconel studs, generic intercooler, upgraded radiator and some bonnet venting.
    I'm not interested in big power options, the whole idea of this car is cheap fun, once gearboxes need to be factored in there's just too much scope creep. And a 1000kg car with a real 220-250rwhp should be plenty quick for a circuit thrasher. Heat management/reliability is a big concern too. The car will end up being used in endurance events, ideally no more than 15psi.
    Is there any other turbos I should be considering?
    2,655
    When you decide on turbos and if you go the T28 I have a few lying around that won't be doing anything now that Prod Sports changed the rules for turbo cars.
    Aug 2010
    1,341
    Easy done with a t28rs
    Did it on about 14psi on a unopened bpt
    11,291
    GT28RS will work a treat.
    Look at the Kraken manifolds over the Dann ones.
    Rods will probably go first.
    8,929
    At what point to rods go?
    Aug 2010
    1,341
    On a bpt over 250hp is getting close.
    11,291
    Yeah, consensus is around 250hp. After rods then generally oil pump is the next weakest link.
    Pistons have been known to go with far less though, although that is probably tuning issues.
    The new nugget
    8,929
    I'd have though revs would be a greater killer than boost?
    So looks like my ultimate power target is the upper limit. It all depends on what the thing actually makes, but maybe something like 10psi on 98, 15 on e85.
    Canberra - ACT
    3,791
    Yes and no.
    The BP engine has been boosted and blown up for many many years and for every “went pop at 220hp” there’s a “300hp stock internals” story.
    That said, rods, pistons and all the main failure items are relatively cheap easy to go 250-300hp at which point the rest of your driveline will be an equal issue.
    Also remember with a BP-26 (original BP turbo) which still had “weak rods” compared to a B6 Turbo they still took 14-18psi with too much issue.
    Honestly, don’t overthink it, put GT28RS on it, tune it well and don’t lean on it for numbers and you’ll probably not break anything if the engines good to start with.
    11,291
    Yes and no.
    This.
    If you are taking the engine apart then rods pistons and a billet oil pump are cheap.
    Canberra - ACT
    3,791
    Oh and remember the original BPT builds used the factory ECU with a bleed valve on the two stage boost and fuel pump control, and an adjustable rising rate regulator. If you’re lucky they hadn’t thrown the Knock Controller away, or hadn’t melted the knock sensor. Oh and crank the dizzy to advance the timing
    Owning an early BPT that’s been “modded” just like that I am 100% sure that most of the failures are from taking the factory turbo that ran out of puff at 16-18psi and replacing it with one that makes 18psi all day long and not having any real ability to tune it is what causes many many failures.
    8,929
    Ok cool, cheers. The limiting to 250hp max bit was to keep the 6 speed intact. I'm very mindful of the fact this car is meant to be cheap and reliable. The current motor is quite strong, so I guess its just a case of me not getting greedy.
    Canberra - ACT
    3,791
    Yep. The motor is cheap to replace if you pop it, the gearbox isn’t.
    With you plans for proper tuning and non-ghetto thinking you’ll be fine.
    I swear every time someone talks about their BPT explosions more than half the time you’ll scratch into the engines history and find some truely genius thinking like “I taught myself to solder making my megasquirt” or “I got the turbo from the dumpster behind a Subaru workshop”.
    Neither of those are bad things but they’re and insight into other shortcuts or misssteps that may have occurred.
    11,291
    Quite a few BP4W + turbo failures around 250hp though with decent tuning. I would peg it as the roughly average rod failure point.
