Results 1 to 13 of 13
Thread: Seized 2JZ Motor - Damaged main
    1,249
    I recently bought a complete 2j motor that had a seized crank.
    Pulled the motor apart and found the bearings for the first cap / mains were toast, melted and badly worn.
    After removing the bearings there is a decent sized score mark on the block and cap where the bearing possibly spun before seizing.
    Without getting an accurate depth of the gouge - is there any way this could be repaired ?
    Pics,
    The main caps aren't so important as I could always use billet ones - just the one on the block is my main concern.
    Thanks
    Central Coast - NSW
    3,166
    Surely machining down the caps and line boring the block would fix this?
    1,249
    hope so, but not too sure.
    probably easiest take it to a machinist and have them check it out.
    4,625
    Slap new bearings in and send it.
    9,618
    take the high spots away, and do this.
    4,386
    I would do that and sleep peacefully but how far are you turning the dial on this one?
    1,249
    I was going to sell it.
    The crank doesn't look that good either, probably need some work done to it, might even be easier to buy a used one in Japan than spend the money on mine.
    12,984
    Is the cap discoloured?
    1,249
    No.
    Sep 2012
    917
    line hone will fix it good
    Sonova Beach
    7,026
    It's probably ok as is, but wouldn't take much more to make it good enough to use without fretting over it.
    Line hone it if you're paranoid. The damage isn't too significant.
    Vietnamese Gang im_boostn's Avatar
    Jul 2002
    1,152
    How much do you want for it
    1,249
    Make me an offer
