Results 1 to 26 of 26
Thread: Ballpark diagnosis for a dead WRX gearbox?
    Tripping balls willsy01's Avatar
    Jul 2002
    8,820
    Gearbox went pop this morning. Accelerating in third under maybe half throttle and there was a bang and what sounded like a handful of nuts and bolts had been thrown into it.
    • Engine is unmodified
    • Rattles when rolling neutral
    • Shifter feels mushy.....gear selection is possible, but feels terrible
    • Stills drives, managed to limp home using 2nd and 5th
    • No fluid loss or smoke
    • Clutch appears to be fine
    Just trying to figure out what i'm up for.
    ACT Now!
    27,476
    A second hand gearbox.
    The main shaft is very long and has the bearings spaced a long way apart with 3rd being roughly in the middle. Under power the shaft flexes and the gear lash increases, then the teeth get stripped off third gear
    Jul 2002
    8,820
    Figured that was the only course of action. I only just dropped $2.5K on the fucking thing replacing the entire cooling system.
    agricultural
    Jun 2016
    Tas
    886
    $500 or less used, new selector fork, new throwout bearing. My old 5mt dropped 3rd similarly.
    ACT Now!
    27,476
    I have a post 2010 Impreza box under my bench here in canberra if you want it. Will swap for Laphroaig.
    TJzone TJ's Avatar
    25,926
    What year WRX?
    But yeah as per above it's probably stripped 3rd.
    #teamtremolo
    And i'd still fuck Betty....
    Central Coast - NSW
    3,168
    Quote Originally Posted by willsy01 View Post
    Paid $2500 to rebuild a GC8 WRX gearbox about two years ago. Looked at options and other rebuilders and there was nothing really around without changing the back diff to suit the box.
    Jul 2002
    8,820
    Quote Originally Posted by aerobrick View Post
    I'd wondered if it was a selector fork. Might have to get someone to crack it and take a look.
    If it's a match for the current box (5sp MY00), I might have to take you up on that.
    Quote Originally Posted by TJ View Post
    What year WRX?
    MY00. It's lasted 266K kms.....half of those put on it by me. No idea what life was like for it before I owned it.
    Quote Originally Posted by carcrazy View Post
    Called this mob and they want $2750 exchange for a box with a used but fully inspected gear set. $4K with a brand new STI gear set.
    agricultural
    Jun 2016
    Tas
    886
    I have a spare '00 sti 5mt with 4.44 final drive but it's sitting in a container in Tas so not worth shipping. Vaguely remember anything post '06 won't be a direct fit, but can swap internals.
    Eurotrash :D
    Jan 2013
    4,126
    6sp swap. never worry again
    Jul 2002
    8,820
    Too expensive.....more than half the value of the car.
    Founder Nick's Avatar
    New New Zealand
    4,615
    Unless you are Kiahatsu with 500awkw
    Sent from my Pixel 2 XL using Tapatalk
    15,165
    Rorge can change them out in under 30 minutes road side
    5,174
    mob in sydney rebuilt my mates one when he busted it over mt selwyn 10495895 km from anywhere (limped it to jindabyne with only 1st and 2nd working..)
    they use 2010 or 2015 internals to make it stronger iirc
    can find details if you need
    Jul 2002
    8,820
    Started this thing up again yesterday. Has a ticking noise at idle that rises and falls with engine speed......goes away with the clutch disengaged. Can select all gears except 3rd. Whatever broke off is rattling around in there when underway.
    Quote Originally Posted by clutch-monkey View Post
    That'd be handy.....thx.
    5,174
    techworkz automotive in canberra did the diagnose yada yada but sent the gearbox to a mob in sydney.. trying to find the receipt for a shop name, otherwise may be worth just giving techworkz a call.
    Sunshine Coast, Qld.
    7,841
    They are under $2k for a H6 6 speed. Grab one of them and an auto tailshaft and a hummunbird electronics gps speed signal generator and you are done. A GC8 is not going to go down in value if you look after it.
    5,174
    Do the H6 boxes bolt up to the ej20? Very interesting
    Jul 2002
    8,820
    I thought a different cross member and matching rear diff were needed as well?
    too old for this shit Kiahatsiu's Avatar
    Brisbane/OkTedi
    2,594
    The pre facelift h6 box wants a 3.9:1 diff.
    Sent from my SM-G973F using Tapatalk
    Torque sells tow cars.
    Horsepower wins horse races.
    Toowoomba
    1,890
    Any 6 spd swap is going to require matching ratio rear and shafts.
    My 5 spd finally went pop in my 99 a couple of months ago. Cunt of a thing! Just took off normally out of a driveway and it developed a very loud tick tick that sped up with speed but changed down with higher gear. It got worse very very quickly. Ended up being a few smashed teeth in the center diff.
    Got a replacement box for next to nothing and the local mechanic swapped it out for about $600. Was just lucky to have quick access to a box.
    Will start acquiring parts for a 6spd swap very soon. 6 spd liberties regularly come up for 3k complete. Will buy for driveline and sell the rest.
    Jul 2002
    8,820
    Getting it towed to this mob and swapping in one of these;
    https://www.alldrivesubaroo.com.au/g...s=#yellow-back
    Seems like a batter option than chancing a second hand box that some swede has flogged.
    Registered User Marty!'s Avatar
    Sydney, Aus
    1,068
    6 speed conversion? good job! if you're keeping the car you won't be sorry. I have a gen 4 liberty one behind my EZ36 with plenty of tourque and it breaks driveshafts before the box has any dramas
    agricultural
    Jun 2016
    Tas
    886
    What's that worth, willsy? Upgrading to R180 too?
    Jul 2002
    8,820
    They're website is fucking weird. That link went somewhere else the other day. I wish I was getting the 6sp......I'm at the opposite end of the price bracket. Standard Box, pulled apart, inspected then screwed back together, using a 2010 gearset.
    Better than going in blind with a second hand gearbag.
    5,174
    Similar to my mates gc8, heís happy with it and itís holding up well
