Results 1 to 25 of 25
Thread: Electric Air Conditioning - VW Compressor
    9,621
    Guys,
    I want to start planning a AC retrofit into my Datsun 510.
    Does anyone know anything about these VW Electric AC compressors?
    https://www.ebay.com.au/itm/Original...frcectupt=true
    Some kind of wiring diagram or service information would be magic. They seem like a suitable option.
    Thanks
    Tim
    ACT Now!
    27,474
    Following with interest.
    If they arenít CANBUS managed Iíd be shocked.
    5,173
    x2
    i've used the renncool units before (used for truck cabs)
    BLING BLING PLAYA's Avatar
    adelaide
    6,399
    I have been importing these, you might notice they look exactly like rencool units lol. The rencool units they market as 20,000 Btu are not close to that. They are about 7000 to 10,000 but seem to do well because you just run them flat stick instead of at idle half the time like a combustion engine compressor.
    Issue with all of the electric vehicle compressors is they run at like 400 volts, great for them but not going to happen on your 12v system.
    Sent from my SM-N960F using Tapatalk
    3D scanning
    3D modelling
    Structural certification
    3 and 5 axis milling
    Founder Nick's Avatar
    New New Zealand
    4,615
    Here is a good read up on them, looked at this a while ago.
    https://www.vintageair.com/tech-topi...or-my-hot-rod/
    TLTR; To run a compressor to cool your car like a engine driven one requires shitloads of amps @14v, hence why most are 400v in hybrids. Can run lower 3000-4000 BTU ones, might be ok in your 510.
    9,621
    Compressor and condenser packaging are the issues.
    I don't have available front space to change the accessory drive on the front of the motor.
    Perth WA
    737
    Cant run inline with the original belt setup?
    6,716
    It'll always be alternator dependant.
    Once the alternator is upgraded, size up the correct compressor based on reserve current around the 2,000 RPM mark. Whatever BTU that gets you, is all you can have!
    That ebay item is likely 400 VAC too, off the hybrid motor/alternator.
    Being linear a 3000 BTU compressor will draw 83 A at 12 V but only 2.5 A at 400 V. That's why it only has a DTP sized plug on it (unless I can't see a bunch of post terminals elsewhere). Don't forget to budget load for fans.
    I've wired a 3000 BTU compressor in to a 1200 ute in Townsville, and through summer it was OK still.
    9,621
    I understand current draw will be pretty high. I'm just looking at my options.
    The engine has a single v-groove pulley which drives the alternator only at present. It may be possible to add a A/C compressor, but I wonder if a V belt will slip with those kinds of loads.
    Eurotrash :D
    Jan 2013
    4,126
    why has no one made an alternator and compressor in one. would solve so many issues.
    how about driving the alt off the diff and mounting the compressor where the alt goes normally?
    ACT Now!
    27,474
    Use a ps pump and aristo hydraulic motor on the ac compressor?
    9,621
    I probably wouldn't get the alternator up the back easily.
    Got anything internally from VW you could share?
    8,928
    Alternator off the diff is the world's shittest idea for a street car. Especially one that has a bit of current draw.
    Defective Faux Forg's Avatar
    Sydney Traffic
    1,765
    How about a compressor with a twin groove pulley, with one groove driven from the crank and the second groove driving the alternator?
    9,621
    That could work. I totally agree a mechanical AC compressor is superior.
    1,911
    I have a 12v version I got direct from china about 10 years ago, apparently pulls something like 90 amps flat out... will see what happens when I get around to installing it...
    adelaide
    6,399
    That one there is 12v hence those big ass cables. These are the ones rencool put the big label on
    3D scanning
    3D modelling
    Eurotrash :D
    Jan 2013
    4,126
    not from my vw side of things as e-golf isnt an aussie model. however my past at toyota as a hybrid tech...
    https://www.toyota-industries.com/pr...ssor/electric/
    es18 is the part, however these are 201v ac and are 3 phase. also it seems all electronic a/c uses nd-11 oil, a special dieletic oil.
    16,733
    What do the non rencool ones cost?
    VIC
    1,341
    Is there not a cheap 12V motor that could be used to drive a regular AC compressor via gears? Gear ratio would mean the pump could be run at x rpm where its efficient and the electrical load should technically be lower compared to the Prius setup which uses the elec motor to direct-drive the compressor
    adelaide
    6,399
    I think rencool was about 1700 this was about 500 delivered
    3D scanning
    3D modelling
    16,733
    For cobbling together a non 911 install, that is starting to make sense...
    adelaide
    6,399
    Bud if U need send me a PM I have two here as shipping was the same for 2 anyway I can send U some pics. My other one is for the 240z I'm building if you want U can have for my cost.
    3D scanning
    3D modelling
    5,173
    Non rencool labelled sounds like it would be ideal for most, it worked ok the one I had.
    May have to do some measuring for the 911 though a bolt in solution is appealing
    Suspended
    mebourne
    3,996
    Great idea! Why not have everything else on the engine so when something goes wrong you don't need to diagnose the issue and just change everything as they are all one unit.
