Results 1 to 13 of 13
Thread: Lubricating tyre valves?
    The Crime Zone
    30,994
    Is this at all a Thing?
    Tyre joint couldn’t find my tyre leak coupla weeks ago; checked it coupla hours ago before driving, and after taking the gauge off the valve I could hear air lightly hissing out. Re-apply the gauge then remove it, hissing sound goes away.
    There’s obviously a sticky valve involved.
    So, is it a Thing to lubricate the valve somehow?
    If so, with what?
    Jun 2015
    West Pennant hills
    220
    Never heard of lubricating that part before.... If you don't have a dust cap, I suppose you could get grit etc that might jam up the schraeder valve. Squirt a bit of WD40 into the valve & give it a quick blast of air (at the servo) ???
    Maudsland, Gold Coast
    6,590
    Something silicon based I would assume..... is putting another valve in not viable ?
    windsor nsw
    1,278
    Gotta have dat stem lube, winter is coming
    https://m.imgur.com/r/TheSimpsons/lfklIFE
    720
    Might have had a small bit of dirt/debris between the valve core and the seat, when you put the gauge back on it got blown out and seated normally, with no leak.
    No lube involved or required.
    Aug 2011
    422
    I've done it before with Inox lanolin spray. No problems yet.
    Brisbane, North side
    1,912
    If it's leaking, replace it.
    5,713
    Take 50c out of your coin purse, and buy a new valve (will need a valve stem tool also).
    The Crime Zone
    30,994
    Everyone has to rub-in the fact that the world doesn't sell wallets with coin pockets!
    Never tried it before; fitting your own valve is a Thing, and you just need a relatively simple tool to do it?
    No goo etc?
    Any chance a fumble-fingered dufus would damage a wheel by Doing It Wrong?
    It's not the first time the valve sticking has happened (while measuring or filling), and this tyre has been going down at about 2psi/week - Occam's Philishave suggests this is the cause.
    I simply didn't consider replacing it because I didn't realise it was something you could do without all the dark magicks of a tyre machine (and hence the inconvenience of taking the car to a tyre place awash with such dark magicks).
    Newcastle
    364
    Don't need to remove the tyre to swap the cores. Takes about 5 seconds.
    https://www.supercheapauto.com.au/p/...lve&lang=en_AU
    6,590
    Quote Originally Posted by R31t View Post
    And best done with a compressor/tyre inflator available.
    ACT Now!
    27,474
    Wear safety glasses. Because Forg.
    452
    Or go to just about any tyre store and ask them to change the valve core as you have noticed it is leaking. Most will do it for nothing and probably check the pressure of your other tyres while at it. Those cores cost us about $0.14 each and we have buckets of used but perfectly serviceable ones just waiting to go to scrap metal merchants.
    Radical SR3
    HSV R8
    BMW 325ti Proddy Car
