13s for $1300
This is a sticky topic.
    PLEASE dont bring NCOP into this
      Buy a BHG 7MGTE engine/ecu etc off toymods (from some cunt that's pulled it out of a MZ20).
      Bolt all turbo shit and ecu up to a stripped-as-fuck auction special MX83 7MGE Cressida
      Drop in some RX7 550cc injectors + 1UZ afm then boost = ezy 13's
        ok so assuming I can weld and tune myself and we're allowed to sell parts to mke money back...
        Fiat 131/132 2L $400
        remove head, reassemble with 2+ head gaskets to drop comp - $50 (assuming bolts are okay, and the head doesnt need machining)
        T3 flange on end of stock exhaust manifold - $50?
        T3 flanged 2nd hand turbo of some kind - $250
        2nd hand ecu - $200
        Fiat croma inlet manifold (complete with fuel rail and standard reg) - $50
        13b injectors, half decent pump - $300?
        fuel hose and stuff (ghetto spec) - $50
        intercooler and ghetto piping - $300?
        weld diff - $0
        remove dash/seats/headlining/whatever and sell, gaining $350 in the process, and decreasing the weight of the car...
        thats bang on $1300.. it'd do at least a few 13's before the standard clutch died i reckon.. the diff should hold... the motor would be questionable..
          done! (on paper anyways)
            superbeetle - $500
            EJ22 - $200
              Damn you Dennis for coming up with this
                presumably the afm swap makes the 550s work with the standard ecu? that's pretty rad if so, and a good candidate for this idea. fine a cressida grande and you get the torsen lsd too.
                    Gutted 6cyl Chrysler Centura and very simple basic old skool carb exhaust,Cam job can do 13s easy.
                    GURU ENGINEERING PTY LTD
                      Originally posted by Imposter Forg View Post
                      superbeetle - $500
                      EJ22 - $200
                      Rest of conversion - $5000
                      Still would struggle for 13's.
                        Crown ute $100
                        7MGTE $400
                        Trust twin turbo manifold $100
                        2 TD04L $????
                        zorst $????
                        multiple Crown diff pumpkins $0
                        A340 from behind a 1UZFE $0
                        tailshaft $200
                        By the time I add in the turbos, exhaust and all the little bits to make it happen I suspect I'll be over the $1300.
                        Originally posted by ALLMTR
                          im in
                          * needs to be 1300 or maybe 1500 but no more
                          * registration costs not part of 1300
                          * mod plate up to owner but not part of 1300
                          * consumables ie welding rods fluids etc not included in price
                          * stuff had for free needs to be documented and a a fair price for said item/s logged
                          * build thread with all receipts to be promulgated
                          * must stay within weight/capacity guidelines
                          * date needs to be set (around 6 months time might be fair)
                          Nope
                            So do we start a 13s for $1500 build thread for each entry?
                            13S1500 - Project Moo Gemini Fail
                            How many are in?
                            2JZ KE20 Corolla 7.97 @ 178
                            SR20DET Gemini 8.70 @ 157
                            http://www.oke020.com
                              im in
                                IMO we need to set the rules before getting numbers cause if someone has say a 265 val in mind and then you allow moo nos geminis. . .
