13s for $1300
This is a sticky topic.
    Originally posted by OKE020 View Post
    $1300?
    Quite possible. $500 e30, $3-400 barra motor, maybe $600with box but Probably less for an ex taxi setup, few hundred left over for scrap steel for mounts and ghetto exhaust/ radiator pipes etc. Guess it all depends what the 1300 covers.
      Non turbo BA/BF motor in an EA should do it.
      Will it bolt to a manual gearbox of an older ford?
      10.83 @ 125
      Originally posted by cracka
        A cheap series 3 bluebird eg
        http://forums.performanceforums.com/...php?t=67257597
        would be a good start as the SR20 just about bolts in ask playa for more info, wait till you find a cheap SR20DET, perhaps boost or damaged cars auction for a written off S13
          Early girl commodore VB/VC/VH V8 + Nos ??
          I attended the PF vs Powerchip thread 2010 and all I got was this lousy Signature.
          Came for the drinks, but stayed for the gangbang.
            But if you just stuck the N20 on a $200 VN or EL it would do 13s for less money and a massive amount less fucking around. Yeah it wont be as cool but it will come in under $1300. IMO total drivetrain swaps like this are out from the beginning since the drive shaft will be around $300.
            10.83 @ 125
              I dont think an engine converted car is possible within the budget. You forgot tailshaft too, and money for the n20 bits and bobs to get it into the 13s. Dennis wants every day power to run 13s, n20 is not every day , well it can be but it shouldn't
              2JZ KE20 Corolla 7.97 @ 178
              SR20DET Gemini 8.70 @ 157
              http://www.oke020.com
                early commo with a ford 4.0L and NOS would probably be better and more likely be cheaper than a V8 commo
                  every day 13's for $1300?
                  7MGTE MA70 supra. lighten the interior and up the boost and it'll run 13's all day every day, and I've seen a few of them for this sort of money.
                  or 7MGTE into a crown/cressida. can do it with stock toyo parts bin shit and 7M's are almost throwaways these days.
                    That is what gave me the idea in the first place. I started this thread after posting about 13 or 13 in that very thread.
                    10.83 @ 125
                      i dont think itl be possible to an engine swap, but definately could turbo something. cut and shut manifold, ghetto exhaust, safc2, extra injectors fuel pump, you could get an ea falcon into 13s pretty easy id say
                        haha posted at the same time as I said the same thing. This isn't so much as a car for me really. Just a brain storming exercise and maybe PF piss up car. But if it could be done, and the car not look and drive like a shit heap I would build it for myself. However if I done it to drive it, common sense would have me spending a bit more here and there, like getting a mint $1000 shell instead of fucked but 13 capable $100 shell etc.
                        10.83 @ 125
                          IMO an engine swap is possible if it really is just an engine swap. Like the CA18 into said bluebird. Full powertrain swaps are out, unless they are full bolt in or close to. The bluebird is mint and would sorta be cool, but I am not sure how much a CA costs or if it will even have the grunt for 13s without too much money. EG stock turbo stock ECU.
                          10.83 @ 125
                            ye but not every one has the skill to do it, i meant it in that sense. some of us can with ease but some people will struggle. either way 13s for $1300 is hard to do
                              Pretty sure it will, just need the eariler bellhousing. You can also use the original tailshaft.
                                That is why this is about skill VS money.
                                10.83 @ 125
