13s for 1300 Crown ute
    1967 engineless Crown ute jigsaw puzzle $100
    7MGTE $400
    undecided on turbo(s) - I have a Trust Greddy twin turbo manifold ($100 about 10 years ago) that I could run with some TD04s (maybe 3-400 for the pair?) here but could fairly easily get a CT26 manifold for nothing.
    A340 $0
    tailshaft $200ish
    fuel system $100
    I have $500 left for zorst and turbos.
    Clearly I'm going to run over budget by the time I do the wiring and all the other little things I need to make it happen. I actually want to be able to stop so I'm going to engineer a front disc brake conversion - the PF lynch mob can decide whether that's not in the spirit of things. Some of you may have driven a car with non power assisted 4 wheel drums - it's no fun at pedestrian speeds.
    I'm a bit busy with work till NYD so no pics till then.
    Originally posted by ALLMTR
    FWIW, Im happy with a brake upgrade being exempt.
    How did you get an A340 for free?
    Also FWIW Im ok with free bits but need a bit of a story as to why they were free (IMO)
      A340s are a dime a dozen. This one came from a manual conversion 1UZ - I was buying other stuff and this was sitting in the garage about to go to scrap metal. I took it - everyone was happy. I have to source an M bellhousing for it - but that's easy.
        Disc brakes are a safety issue not performance related so I think it should be fine. I look forward to seeing the progress.
        LS Powered FD3S RX7
          The engine has a manifold on it GT. With T3 adaptor also.
          I'll put the feeler out on a pair of turbos.
          The engine comes with a 7M auto bellhousing.
          Don't forget to budget for a hobbs switch to trigger the awesome greddy extra injectors.
          P.S. When you are finished, sell the ute to me.
            wasnt someone floating aound some rebuilt 7mgte for 500 in the 13 for 1300 thread? from the shadowy depths of christmas memory it was making 200rwkw= or something with a steel headgasket? might be cheper to get that than get the current one running with twins?
            ps love the ute
            06/07/2011
              Rebuilt 7m is mine. Spac is/was selling it
              Get some pics if the ute up!
                Definitely up for some TD04Ls. I'd love to run a TT 7MGTE.
                  fuckinwoosh. you'll piss it in GT - fwiw my 7m/auto supra ran 13.7 at ~101mph with full 3" exhaust, k&n and 10-11psi with stock everything else. with a manual box it did the same 13.7 at ~104mph
                  and that was no doubt heavy compared to your crown
                  Originally posted by 350stato
                  100% agree with Shifty
                    Friend ran a 12.something with a 7MGTE Corona Mk2. Not for a second am I suggesting that I'll run a 12.
                      This is by far the classiest 1300 project.
                        The ute is hilarious. Has old handpainted signwriting on it, both the doors are sitting in the tray (amongst a plethora of spares), paint has rubbed off on the corners and there's a little bit of rust/old paint patina about - it's a little bit ratty. Amazing thing is that it's reasonably straight and the wiring is unfucked.
                          pics or it never happened :D
                          lemme know if you want that convertor!
                          this shit is gettin serious quick.. looks like it might end up being 12's for $1300!
                            Love the project. 4 wheel drum is insane.
                            PS try and get a A340 from a 1JZ. Or see if the 1JZ converter fits on. I know it wont fit a 2JZ A340. But a 1JZ converter is much looser than a 2JZ and presumably a 1UZ. You will need a lot of power to overcome the 2.3 60 foot time otherwise. 2000rpm lag lauches FTL. I think I ran 13s at 125 with the GT35 and stock 2J converter. That said this project looks like it will not be lacking in powah. 13s at 115?
                            10.83 @ 125
                            Originally posted by cracka
                              To hell with car hunting up in the sticks in Jan, you have to get this sorted asap purely for the awesomeness.
                              Originally posted by Stix Z
