13's for $1300: RX4-929 nugget
    This competition is just the shot in the arm I needed.
    http://www.performanceforums.com/for...php?t=67262287
    When i first saw it a couple of weeks back I thought "cool, but I can't be fucked". Even though I had a potential candidate sitting in the driveway doing nothing and a wicked motor to go in it (EA SVO, manual, and a BA 4.0 twin cam). If PF can get behind me and give me the shove in the back I so desperately need I may see this thing come alive, potentially in a future challenge. (maybe we do a One-make challenge?).
    Quite separately i scored a cheap Mazda 929 coupe (pretty much identical to the RX4) back in November but only picked it up 30/12/10 due to not getting any time off for yonks. I really bought this to use up all the left over shit that one accumulates over a decade or so when trying to build a really clean rotary (a much better RX4 is in the build). I think back to the multitude of mazda's that I've bought on the cheap, usually because they're in the middle of nowhere and near fucked. There have been some good scores at times (more on that later) but i suffer an affliction that seems to come with owning rotaries: I am a hoarder. Just seems I can't chuck anything out if its even remotely useable.
    Hence, coming back from collecting the latest coupe, the plan was just to use up some of the spares, rotorize it, basic clean up without spending money, and flip it for the typical ausrotor drug money prices these things seem to pull. Then pour that cash back into my other RX4/Luce.
    Now for a sight unseen car (i just hit the buy-it-now button out of reflex) I really wasn't expecting much. The photos made it look like a complete and utter shit heap. Here she is in all her glory:
    http://cgi.ebay.com.au/ws/eBayISAPI....#ht_500wt_1156
    But after a fair old road trip (depart Melb 3.30AM arrive Wagga 9.00AM get back home at 5.00PM) and some more time to appreciate its redeeming features I started to think it would clean up "ok". No terminal rust, dings would all be easily repaired, missing/fucked parts I had spare. Just had to get out to the farm to start picking out the replacement parts.
    DAY ONE: 1/1/11 INTERIOR and DAMAGE ASSESSMENT.
    What a filthy job. The car had been left parked for what I can only guess was a number of years. Quite likely with the window down and no small amount of good old fashioned red Aussie country bulldust through out. The seats were completely fingered. The carpet was wet (my fault I think). So I took it all out and vac'd it. Had to completely rebuild the drivers seat as the donor seat had a broken frame. Pulled original and donor apart to make one good one. Find same fracture point. Out with the mig and 15 mins later I have a repaired frame. 30 mins later I have a new seat. The carpet was out of a perfectly good car (BUZNUT from Maztech) that some moron wrecked out - i scored a good chunk of bits from it for peanuts. So with decent carpet and seats, and with liberal application of armourall, the interior was coming together. I threw a worn out MoMo in there and called it a day. There is a little more to do to get the interior right but its mainly the door trims - completely sunburnt and warped. Buts lets remember this is about ET's not interior detailing.
    I also had to start stripping the damaged LH guard and bumper. A bit of WD40 on all the nuts and bolts seized after some 36 years of neglect ensured that I got it all undone and only snapped off the one nut at the bottom of the guard (they always seem to do that). About this stage i noticed the damage to the front corner was really minor. A slide pull and hammer/dolly work will set it right. And you never see this under the guard/headlight bucket anyway.
    Called it quits for the day a happy man. Bang for buck I'd used some household cleaning shit, my nouse, and some elbow grease to really lift the appearance of the car from "Shit heap" to "Nugget".
    DAY TWO: 2/1/11 MECHANICAL ASSESSMENT and PARTS LISTS
    This was the morning I woke up and said to myself "Fuck it, this would be cool as a 13's for $1300 candidate".
    I got a burst of motivation and set to work. I pulled the brake master and loosened off the brake lines. I pulled the clutch master. Removed the brittle washer bottle and overflow reservoir. I took a look at the brakes. Squealed like a girl when i found all the redbacks. Thankfully the rear brakes don't look all that old. Apart from pretty suspect flex lines and the leaky master there isn't much to fix. There is however the audible sound of a rooted diff centre or wheel bearings. No worries: I have a cunning plan. Rear suspension is pretty basic and typical stuffed rubber bushes.
    Front steering is "ok". A little free play in the steering box - I may have a better one. Front suspension needs total overhaul. It all has to come out anyway to change out the piston crossmember for the rotary one. A true backyarder would have just lopped the mounts off with an angle grinder but already have one done.
    Not certain if the 929 coupes have strut inserts like the RX4 but 929 sedans have an open oil-bath. This will not do. Also mazda's are notoriously under-braked. So the smart thing to do is raid the parts bin and swap in some better struts while i'm there. I have been tripping over some struts with koni inserts and volvo brakes for a while so it seems they will do nicely. I went to my box of tricks and pulled out a heap of used but re-useable nolothane bushes.
    For wheels I was just going to slap on some RX7 series 2 mags. But they're 70km away and I had some 14" challengers with decent, if not ageing, rubber.
    Then as the afternoon wore on, much like my longest post EVAR lol, i went into the shed to start pulling out the shit that would kick-start a faster Mazda.
    So I have two piles going. The first is all the junk and broken stuff I have removed. The second is all the stuff going into the car. In the interests of transparency I will photo all the gear so the PF lynchmob can assign values as it sees fit and basically scrutineer my efforts as they quickly progress. I will come back to this first post and add the pics and parts lists.
    This is a genuine case of slap-together racing. Some of the parts i'll be using certainly have a value but all of them are on hand and genuine orphans, left-overs, "unknowns" or just plain junk. I don't want to raid my *good car* for anything because that's just not in the spirit of the challenge. I've also decided this is an achievable build because its largely a bolt-together project where looks don't count for shit.
    In this build i will be assisted by my good mate Geoff [username: Sv_i]. As some of you may know Geoff is building a 929 wagon and we've given each other a helping hand from time to time. We know our way around these cars pretty well and I expect the "roller" to be pretty much done within another day or so of serious effort. The driveline is yet to be determined but will be 13b-something. I have choices and don't want to commit to any one path at this early stage. Needless to say the car will not be powerchipped. Technology will be limited by budget and parts to "old-school". I'm notionally drawing that line at year 2000.
    If any other Melb PF crew want to check out the build you can call me and drop by for beers. But what I think I will really need is some hook ups with fabricators and clever cunts. There are a few things I would like to do that may require stuff being welded or machined. I just don't have those sort of connections and i certainly don't have the time (long office hours). But I do have the money and prepared to spend where needed up to the nominated limit.
    Finally, after a long time in the rotor scene, this will be the first running and drivable rotor i've owned since 2004! Now there's some motivation that has really got me going unlike anything else.
    Flame on cunts.....
    <EDITED SO THE SPECS ARE EASILY FOUND>
    Looks like my rough set up will be:
    RX-929 coupe (guesstimate weigh in around 1100kg)
    s4 turbo block - basically stock rebuild - can't "feel" any porting
    Haltech E6a fuel and ignition, 12aT primaries.
    Garrett TO4e-66 or similar combo with external gate
    Water to air cooler
    Jatco 3 speed
    stock welded 929 24 spline diff with 4.44's
    2-link
    volvo brake kit
    Challengers plus slicks
    The "lynchmob" are just pedantic sooky cunts playing for sheep stations who need to shut the fuck up so just value it how you want and build it!
      Ebay link says item sold so no pics. So post pics cunt
      Otherwise good stuff, our first rotary entrant!
        yeah i cant feel the project without pics, its like just listening to porn or something
        Originally posted by Karnage
        Sounds like a candidate for involuntary euthanasia or perhaps surprise assisted suicide.
          aren't the old style oil filled struts the go for modding to get 90/10s ? it may help your 1/4 times. the seal in them is generally easy to get and cheap.
          Originally posted by Skompa
            I received a text message yesterday telling me that hoges had had a brilliant idea. I thought it was going to be "Im going to get this fucking EA on the road and do 13's" but no, it was this one, which is an even better idea as hoges literally has a shed and farmfull of old japanese and ford shit
            Hoges, what about using the diff out of the green wagon? I notice that you have left it sitting outside, it needs some loving, it has the locked centre too. I'll rig up a day this week to have off and we'll smash some more stuff in.
            I also suspect that once you get this running, you will get fired up again for the other build*
            Don't forget I can get stuff machined up/welded at work if the techie guys are around.
            ps gianttomato lives about 10 mins away and he gets stuff knocked up for his projects, he might know peoples?
            *aaron has a extremely tidy RX-4 coupe that has sat unloved for ages.
            **I drove the wagon today, superawesome, just have to get that lead that the dickhead at autobarn got wrong and put the points into it.
            ***I know what you are like hoges, make sure you throw the shit pile away and not horde it in your driveway!:rotflol:
            Also, had a thought, maybe keep those old monroes in the back, cause if they are soft and shit, like monroes usually are, it'll help launch rather than the firm konis?
            Is the auto box coming out of the fucked red RX-7?
            Originally posted by Stix Z
              Fuck you for finding this cunt before me
                hit up aaron for one of his other 929s
                or
                cheap 929/rx-4 sedan bodyshells are out there, spac has one for sale IIRC.
                I'm heading over to aarons now, I suspect I will finding him sitting inside it making whoosh noises or this thing will be 99% done.
                  Spac's finally went a couple of months ago.
                  He was so happy that he began to talk in the third person.
                  $500 and it was a GOOD shell - a bit battered but absolutely rust free and never really pranged.
                  Despite all the AR talk, they're not worth that much.
                  the source:
                    I still lust after an RX4 Coupe.
                    "We never get that high tech jap stuff in here, should be no problem though" lol
                      I'm still surprised that RX-5s never really took off in value.
                      Went to aarons, thundercunt was not home and is not answering his phone, so I suspect he is down on the farm under a car ripping off bits or rooting somewhere.
                      I have pics though (hoges tell me if you want them to come down).
                      Dashboard is rooted, rest of interior is good, tripped over bits lying around ready to go in. This thing should easily make 13's.
                        What are you talkin' about that dash looks mint!
                        I'm putting my money on this thing so far!
                          a bit of armorall and that dash will be sweet
                          CJM 4 Life yo!
                            Originally posted by Lobster View Post
                            a bit of spak filler and that dash will be sweet
                            fixed.
                              a bit of shag pile carpet and that dash will be sweet
                              fixed.
