13's for $1300. VN of FURY
    you payed too much for the switches and injectors :p are you going to run straight meth through the injection setup you got there? i plan on doing something similar on my soarer, interested to see how it pans out
    also. are you going to do anything about the auto? looks like you may be making some decent power here, it may become an issue...
    i'll put my vote in early and say i think this will be the fastest car in the comp.
      That's fucking excellent. You cunts definitely aren't mucking around.
        13s for $1300 in 13 days! good progress, had the exact idea for fuel enrichment except was going to use methanol.
        Not sure if you know but there is a pipe under the throttle body that runs to the crank case with no valve in it, you need to disconnect it or when you start adding some positive pressure you end up blowing the rocker cover gaskets out.
        2JZ KE20 Corolla 7.97 @ 178
        SR20DET Gemini 8.70 @ 157
        http://www.oke020.com
          There's a bit of weight in those intrusion bars huh!
          The doors come up nice and light with all that shit gone.
            Damn, another commodore making progress! Looks like I better do something with mine this weekend.
              My money is this doing 12's !
              www.unigroup.com.au
              Originally posted by niSSSan
              works for me as the first few years of monthly pay was hookers and coke for the first week, then 3 weeks of jerking off and water...
                You got me worried now :O
                BA GT
                13s for $1300 TE Cortina wagon! Thermighty!!
                  Fucking sweet, should piss in a 13
                  They say i know fuck nothing, but i know fuck all!
                    Originally posted by Supercrown View Post
                    Now this is the sort of new member we actually like turning up.
                    Good stuff.
                    Yup. Plus he appears to own a 2JZ powered HiLux.
                    Nice work mate. This is the sort of thing I wanted to see built with 13 for 13.
                    10.83 @ 125
                    Originally posted by cracka
                      Alright, time for an update.
                      Got a fair bit done in the last few days.
                      We stripped out some more of the interior and found the original factory build sheet from the 22nd of Feb 1990.
                      Many people have said that the car was too good to turn into a bunky drag car but at the end of the day its still a VN haha.
                      We took the dash out and removed the heater box and all the non essential garbage that Holden hid under there. It took a fair bit of effort to get the aircon unit out when you forget the bolt in the plenum hahaha
                      We trimmed up the rear bumper to stop the bottom lip acting like a parachute, for when it traps 140
                      We then looked into the drivetrain and the lack of LSD was unacceptable. Seeing as single wheel skids are only for kids on a BMX, with the MIG turned to full blast the diff was promptly locked.
                      We finished the dump pipe off the turbo. We used an old jap cat back exhaust which also gave us the muffler we need for it to be run at a street meet.
                      We finished the wiring for the injectors and some general neatening up under the bonnet.
                      Just a few little things to do now and we should be ready to rumble.
                        jeez you dont muck about.. nice work!
                          Good work!
                          What is the quality like on the wastegate?
                            Not too bad, the shaft on the valve needed cleaning up but other than that worked OK on my other car.
                              I see this being the front runner currently, awesome work
                                I agree!
                                Do you have a figure on how much this has cost you all up?
                                12's???????
