13 for 1300... Cortina coon goon
    jesus....
    are you sure you want to invest too much time into this thing? Not trying to be rude or funny, but it's a fuckload of work for something that ultimately won't give you much back.
      I'll have the inner sill, floorpan and kick panel done tomorrow. Once I'm happy it wont buckle, I'll be throwing the engine in.
      By the same token, the same can be said of the VN's in terms of rate of return!
      BA GT
      13s for $1300 TE Cortina wagon! Thermighty!!
        well you got the EF there as a donor
        transplat floor and sills from that. keen to see the thing twist like a fatman hearing the words free mars bars
        Royalpurple Oils
          BURN! :rotflol:
            Originally posted by turbohemi View Post
            BURN! :rotflol:
            nah, so far the VN has cost $800 and two cartons of work
              A little update while I'm having lunch... EDO spec...
              BA GT
                Geezus that's some pretty fucken bad rust you got there!
                now with extra gearbox'y goodness
                  Fucking gas regulator on the welder fucked up. Welding and tools supplies were shut. Looks like I'll be just cutting and forming til monday... :'(
                  Started oxidising
                  Chewed the fuck out=gay.
                  BA GT
                    Cut out the rad support...
                    Turns out a VB-VC rad fits well with minor mods...
                    Starting the welding shit tomorrow! :D
                    BA GT
                      Got some done before the wire ran out.
                      The panel cut out and scribed...
                      Half way through bending...
                      Started clamping in place for test fit..
                      Partially welded in, then ran out of wire...
                      Work on driveline side of things tomorrow.
                      BA GT
                        Nice work. I feel all guilty because my car has only one bit of rust.
                          You should've got a coast dwelling 80's Fiat that sat under a pine tree for the last 15 years if you want rust...
                          BA GT
                            Had a bit of a shit day... My 4x4's head cracked 30km from home on a bush road in 38c heat, so it had to be towed home. So, now I'll have to drag my falcon wagon out of moth balls (read foot high weeds) and put new tyres on it just after putting a set of muddies on the 4x4. GAY.
                            On a positive note- I have the engine and trans home and a new roll of mig wire for the weekend! :D
                            BA GT
                              Protip: Ditch the serpentine belt set up (balancer/alternator/air con/pwr steer/water pump/radiator) and replace with a simple EA-B-D v-belt parts.
                              note - water pump outlets and radiator must be matched. EA doesn't work with EF
                              Will be far less frigging around to set up.
                              Chin up mate. Shit things happen that distract all of us. Just think of the lolz you'll have when its done.
                                since he's got an entire falcon donar car sitting there to work with, wouldnt it be easier/cheaper just to keep the serp belt?
                                unless he's ditching the a/c compressor though?
