13 for 1300... Cortina coon goon
    Just get a non ac belt and keep the serpentine system. It's neater and has less drag anyway.
      Yep, I'm keeping the circustime belt. I have plans for the 'tina should it survive...
      Anyhoo... I smashed out a small rust repair out of some sheet. I know it's rough, but it'll work...
      Back at it then, I guess...
      BA GT
      13s for $1300 TE Cortina wagon! Thermighty!!
        Got my 5 stud conversion today, would have fitted them but they gave me the wrong seal. $20 for the old rotors from a wrecker, $45 for the bearings and seals. No discount on the bearings... bugger . Dummied up the mag off the val to see what it'd look like
        Good thing about these rotors is that they use a hat pressed onto the hub: I might be able to fit a better rotor on it in future...
        BA GT
          OK........ Just spent a stack on eBay. $219 on a chinese special GT35 and another $49.97 (lol at the exact exchange conversion) on oil lines. Sent the exhaust gasket to the engineer to be copied into a flange to build a manifold. Gotta start watching the pennies now...
          BA GT
            Fucking win.
            10.83 @ 125
            Originally posted by cracka
              Got some EA calipers to fit to it... Does it classify as safety items or do I have to add it to the total?
              As for "win", things are starting to happen but I'm not yet cranking about it...
              BA GT
                definately not performance.. brakes only slow you down
                  Finished the lower section of the A-pillar this morning, and picked up some more steel.
                  BA GT
                    Love your work. I'm shit with bodywork, my skills lay elsewhere.
                      great metal work as usual !
                      my youtube channel
                        Wow thats a lot of effort to go to for a shit box that only has to do a few drag passes. I say that in the most loving way possible as my first car was one of these. I would love another but they all seem to have rust like that. With those skills you might fully resurrect the beast. Top work.
                        10.83 @ 125
                          Cheers guys! Like I said- if it survives I have plans for it lol.
                          Something I knocked up for a mate, if you're interested in a little fab work...
                          BA GT
                            Got a prezzy in the mail today!!! AWESOME!
                            Should do the job...
                            BA GT
                              Specs? Cost?
                                flogged from ebay page:
                                GT35:
                                Inlet Diameter 101.6MM 4"
                                Outlet Diameter 65MM 2.55"
                                Turbine Housing AR: A/R.63
                                Comp. Housing AR: A/R.70
                                Turbine Wheel: *56-65.25mm
                                comp. wheel: *61.4-82mm
                                Flange:T3 Flange
                                Bearing Housing: TB34 M8*2 Oil:M14 M10*1.5*2
                                Oil and Water cooled: Water cooled
                                Thrust Bearing:360
                                Wastegate: Internal
                                v band:79mm
                                BA GT
