FWD: 13s for $1300 Hyundai Excel
    I like it!
      :likes this:
      When will the kits be available?
        Ghetto turbo setup testing....
        2JZ KE20 Corolla 7.97 @ 178
        SR20DET Gemini 8.70 @ 157
        http://www.oke020.com
          awesome! so what are plans for fuel and management?
          caprice nugget.
            Can't do much about the timing, factory knock sensor might just come to the rescue, also might be able to fool with the air temp signal. As for fuel twin early Hobbs switches and two jaycar duty cycle controllers firing auxiliary injectors.
              Mint. Can't wait
              caprice nugget.
                Turbo looks very low...oil return going to be a problem ?
                  Did the oil drain this afternoon, it's almost level on it's way to the sump. Ran it for about 20 mins gave it a few big revs and no smoke, seems to be draining ok so far. Left over waste gate valve is not seating properly as I had to weld a pipe into it, not bad enough to effect spool time but enough that i will have to plumb it back
                    is it possible to squirt some methanol in there somewhere ? might help stop the detonation ?
                    Originally posted by Skompa
                      Hoping it should be ok. Tomorrow I am swapping in some 250cc 1uzfe injectors and switching to e flex. Scored an 040 intank for $80 so might put that in to
                        The cressida got away with crazy timing at 15ish psi. Crazy like nearly 30 degrees. Thinking since excels can run on 89 octane so maybe the stock tune is not all that aggressive
                          Swapped to na 2jz injectors, fresh fuel filter modded the rail and plumbed up an external reg. Drained up and filled with eflex, seems very revvy now. Got intercooler mounted and the hard intercooler pipe made. Still got alot to go but making good progress
                            14.3 at 96mph
                              Not dragging your feet, are you?
                                Hopefully I can get all the intercooler pipes made tonight. Have to survive a day of mothers day chores first
