vlt 13's for $1300.
    Pics?
      try new fluid in the built box first, if that doesnt help run the stock box, and put the built box in when its fixed.
        Upon closer inspection it also has a PWR tranny cooler. I put a new battery in it today and drove it down the drive way into the car port. Drives fine with no water in it. I'm thinking of just putting the head off the good motor onto this one to save some time and effort.
        Some piccies.
        Just chillin' out but i'm bound by a necklace
        I don't know but I get a little wreckless
        and if I don't make it to the end of the road
        I don't know the weight that I will unload
        i wish I could relapse another time
        Turn back the tap of discovered ryhmes.
          Will pull the good panels off the white vl before it goes to it's new home to make this one neater.
          Also has the grill. it's just in the boot.
            Engine swap is easier then a head swap, pull the gear box and motor together, swap them outside the car, then drop back in together. Saves alot of time
            caprice nugget.
              Or keep the new engine as a spare and buy a $50 head off ebay/Boostcruising/gumtree?
              caprice nugget.
                Yeah came to same conclusion. After a bit more research into the previous issues with the box I've been told has been dropping metal shavings in the oil. Still works from what I've been told. Just sheds shavings :/
