13's for $1300 Barina SB #2
    Started the TR Astra rear disc brake conversion, using a spare rear beam so I can swap it over quickly after it's ready, because the car is my semi-daily driver. Bonus is that the new one cost bugger all and included a thicker rear swaybar being from a GSi.
    Made an alignment tool for the new stub axle mounts.
    Modifying the plate mount to suit the different shape.
    Got the tops of both welded, and one side of the left side, then I ran out of argon, dammit
    as short as possible
      Fully welded the things. Re-welded the handbrake guides on at an angle because the handbrake cable points up a bit now. Need to shorten the handbrake cable.
      Painted the roof because I hadn't done it yet, and it had a few dents from some bogan walking over it. There was also a rust hole on the edge of one of the gutters which wasn't going to get any better so that spurred me on to do the whole job at once. Deleted the antenna too, because I can't remember the last time I listened to the radio.
      Did it the same metallic grey as the bumpers just because I thought it might look ok. Painted the gutter strips the same colour will re-install them soon.
        Cool!
        BF XR6 Turbo - 2L Turbo TE - 75 TX Coupe - Atlas SS
        - PSN: rotacoupe
          I like!
            Are you going to get new plates? Those look out of place..
            1969 Datsun 1000 Sedan
            1989 1.6l Daihatsu Charade
              reinforce the shock mounts on the beam, they have a habit of breaking off.
              Originally posted by Marv
                I also wanted some more practice with metallic. Going to try doing a whole car metallic blue next.
                Sloth just welding it better should do?
                I will probably get the plates remade in black or red at some point.
                  Done
                    I did a Skompa
                      Gonna start all over again with a new car?
                      CJM 4 Life yo!
                        Nah, he's going to build a panelvan out of them.
                          Nah bought it for some parts and to test fit the new engine, intercooler, do intercooler piping, wiring, ecu then transfer it all to the original one quickly.
                            Damn, should've bought a Combo for parts!
                              In other news i'm likely taking the red one to Sydney Dragway tomorrow night to see how slow it is.
                                So that happened.
                                19.348@70.6mph
                                19.3@69.64mph
                                19.477@68.16mph
                                19.616@67.8mph
                                Did a 0.009s reaction on the 3rd run and won $100 for 3rd place in the reaction time competition.
                                Cusscuss's Supra ran a 12 and blew some kind of oil seal.
