Hand Grenade Navara D22
    Picked this up last week, 06 D22 dual cab Navara with circa 240,000k's on it. Very happy with condition for the price but has a few issues I need to sort
    1/ Overheating - Fine around town but will begin to overheat almost religously at anything over 100km/h...have done a radiator flush but will try a new thermostat and give that a try
    2/ No service manual... No idea when anything has been serviced, but going off the colour of the oil, Its likely everything is due. As such, I plan to do a full service on it.. Engine oil, oil filter, diesel filter, both diffs, transfer case, regrease wheel bearings..anything ive missed that I should look at? Do these need timing chain replacement/valve clearances looked at after xxxxxx/km's? (ZD30DDT)
    Anyway, Having a ball in my first 4wd, climbing alot of things I wouldnt have expected to get close to in a stock 4x4.
    Pics
    309587_10150366184802030_663942029_8372715_1556091 187_n by Crais W, on Flickr
    392031_10150366184707030_663942029_8372714_2150376 57_n by Crais W, on Flickr
    '67 Volkswagen Beetle 1300cc
    '09 VE SS
    Originally posted by Scrad
    You are like some sort of car rapist, Sticking things where they don't belong, and often don't fit nicely
    Overheating sounds like radiator. Flushes don't really do much especially if it's pretty fucked. It's worth pulling it out though and blowing any shit out of it that gets sucked against the front of the core from the fan. If you use compressed air don't blow too close you can do damage.
    Also make sure the fan is working. When the engine is up to temp, turn it off and see how easy the fan freewheels. Should have a bit of resistance and not spin too easy.
    Next thing would be a new rad or get the old one serviced properly where they uncrimp the tanks and give the core a proper clean.
    Can't think of any other service items that you haven't covered. They're a fairly hardy weapon just do regular oil changes like any diesel
    Originally posted by RVK 355
    Hold it flat cunt
      Ive had one of these for 4yrs now and its been a great work rig. Mine gets hot too if u give it some on the highway for a period of time. From what ive read it will be the radiator, just replace it as its a common problem, haven't done mine yet though. They are good utes, been very happy with mine. Change the oil every 5000 though and dont use 20/50, i use 15/40 nulon.
      Hr under construction
        Tried servicing the engine fan? Never done it, but apparently they need gel added now and then so they lock in properly.
        Projects:
        '90 2jz-gte 929
          If the fan was buggered, it would overheat below 100km/h (esp sitting at the lights), but be ok at speed. Is the system holding pressure?
            sounds like a cracked head zd30s are good at it
              +1
              be very careful mate,ZD30s cook number 4 pistons if left unchecked nissan just stuck there head in the sand over it,a few simple mods can alleviate the problem,a 3" exhaust reduces exhaust gas temps which is the cause for all/most ZD30 engine failures,as does a mod to the egr system to retract the exhaust gas straight out the exhaust and not back through the intake to reburn,or eat its own shit......... so to speak.
              take it to a deisel doctor of your choice for some expert advice,before you blow it and your bank balance sky high :cry:
              to a google search on Zd30s you'll see what Im talking about.
                Originally posted by gbanger View Post
                +1
                Its a navara not a patrol. Same engine different management system and turbo. Do your reseach properly before you jump on the zd30 bandwagon and make uninformed posts.
                  fuck sorry man ,Ill run every thing by you before I post in the future .........you telling me you've never herd of a navara ZD letting go.
                  oh and every second post here is uniformed.
                    well looks like wishful thinking has paid off. nothing wrong with the head, just a very severely blocked radiator..around 80%. will throw up a pic later on. either way its a big load off my mind and am now looking forward to getting into things i was too scared to due to overheating risk.
                    as for the zd30, ive still heard of #3 letting go on the nav, but nowhere near as common..cracking heads seems to be more the navara's thing, but Im taking it withe same sorta mindset that was mentioned in the greatwall thread. go on any single make model forum, and you would be convinced they are the biggest heap of shit around. no one ever posts that its a-ok.
                    '09 VE SS
                      I've had my turbo deisel D22 STR navara for 5 years now, paid the thing off today in fact. Best truck I've ever owned and super capable in mud, sand, or anything else you care to think of. Only issue I ever had was a non functioning passenger front window that needed some contacts cleaned on the switch and it was good as gold.
                      I've put a straight through 2.5" exhaust on mine with no mufflers for extra whoosh and whistle, made a marked difference to mid range torque. Also have an aftermarket chip here that I never got around to installing and a bunch of other bits like factory foglights and a brand new front bar.
                      Come to think of it I have a full set of factory wheels that have 0 kays on them and a full set of patrol wheels with legal tyres that would suit too.
                        how many k's on yours now? now that i've fixed the overheating it drives like new, but the k's on mine is a little worrying.
                        Details on the chip?
                        '09 VE SS
                          I bought an 03 in Dec last year.
                          Had a leak in the Radiator, replaced that and was still losing water.
                          Just got the news the head has a hair line crack in it.
                          Will be doing the EGR, exhaust and intercooler once I get it back.
                          Other then that I've loved every min of owning it.
                          Cheers cunt
                          https://www.facebook.com/NeverBailOut
                            Just had mine destroy a piston. I've got 3inch dump blocked egr and serviced every 5k. Just ordered full rebuilt kit from precision international for $1100. Using patrol pistons (thicker rings) removing egr butterfly got some old heads to cut up to see if we can open the ports up more. Intercooler, turbo, catch can, boost controller and tune aswell. Will start a thread later
                              Oh god they are fuckin shit. Life is too short to own zd30s.
