1998 Dualcab Hilux of Nuggetyness
    10-15 psi on my 300,000km Datto motor.
      Interesting. Will have to keep considering this one, as it will likely only be next year that I will get around to turboing it.
        Another week and certainly invoking the 80:20 rule here. But the box of heater hoses finally arrived and so it became a process of mix and match to figure out where everything went:
        Not terrible, but a pain as a bunch of them were too long and needed to be trimmed shorter, or joined in two for some reason. Plus the entire heater hose catalogue doesn't include the feed and return to the oil cooler or the throttle body. Minor annoyances, but they are both absolutely painful to get into and I hope they never burst, as the old ones had to go back on there. The oil cooler ones will be fine as in the long run they will be replaced when i do the turbo.
        Plus i put on my new Jaaaaag alternator, only to realise that it had the old style of plug, which required a plug adapter:
        Mercifully they are available off the shelf, but another couple of day wait.
        Then I started bolting it all back together and one of the fuel pressure regulator bolts sheared off... Mercifully it came out with the application of a sacrificial torx bit
        After that I made up a hideous overkill of a fuel line to replace the damaged one, because getting a new fuel hose crimped up in lockdown was all but impossible, so a 200 series -6AN line it is:
        But hey, bling bling.
        At which point you get to here:
        And so late one afternoon
        Still has a slight exhaust leak as the secondaries were only finger tight, and I now need to bolt together the rest of the random bits and pieces, but its pretty much good to go.
          Mint. ETA Till it skids like this?
          https://youtu.be/AVU5tugKbrI
            Lol, 4AG.... thats adventurous.
            Turbo conversion will be sometime next year. I have to liberate an ECU for it first, and going to wait until i have had enough time over the summer with camping etc to do it.
              Another week, another update.
              Didnt get much of a chance to do much until the weekend as it basically lashed down all week here, but got back into it after it dried out. Well after the weather did anyway.
              Fitted up the radiator and the rest of the pipe work, and filled the radiator, only to find that the water pump gasket had pinched at some point in the fitting, and was just pissing water out of the side of the pump:
              That necessitated pulling the entire front of the car apart again to try and figure out what has gone on. Replaced it with RTV and bolted it all back up, but had to wait for the RTV to dry, so set about doing other things... namely moving onto the tray. Got the ute through into the back yard:
              Then set about pulling the tray apart. But thought I would document just how bad it was before i started. First up was this terrible roll hoop/ladder bar/spotty bar that was bolted and then welded to the tray because they had used bolts that had a longer non-threaded shoulder than the tray thickness.
              Oh and everything is rusty, so needed to be cut off:
              All of the bolt heads on the tray mounts were rounded off, probably some redneck security measure. Out comes the grinder:
              Every 6" or so there were these really badly drilled holes for side marker lights. EVERY SIX INCHES! Would have been at least 50 of them on the car:
              Anyway, after an hour or so it finally looked like this:
              At which point I was able to clean out part of the accumulated mud... yes only part of it. Still a ton more to go, the chassis rails were almost full:
              The next day I got stuck into making the new tray. Firstly set it up with clamps to get some measurements and levels.
              Make the noise:
              Managed to get it all square and within +/-0.1deg of deflection, which I figure is good enough for a ute tray.... You can also see in that picture the mounts i built for the tray with random 3mm square plate washers for spacers.
              Then weld on some bars, and take it off for trimming up the cab end:
              Go back to the trusty mitre bandsaw and start chamfering ends:
              Then the outer bars get tacked in place:
              After that it is time for the main hoop, measure measure measure then cut:
              Do a bit of maths and measuring and you end up with one main hoop:
              Looks a bit weird, but thats because its the same profile as the canopy.
              Finally, do a bit of trimming where you screwed up and forgot that the under tray drawer has to go in the space that you just filled with the rear bar:
              All in all decent for a half day of work on the tray. Still need to build the light plate, and start to weld up a bunch of mount pieces for the behind rear wheel boxes, plus some gussets etc, and then have to weld up the entire thing. But its getting there, not too long now.
                Damn it's looking like a totally different nugget than 9 pages ago
                  But with the new tray will it fit down the side of the house to get back out?????
                    Oh fuck he's gone and built a Countach in his basement
                      Hahahha. The new tray is narrower than the old one, so if it got in it will get out....
                      I do have a friend who did the NCIS thing and hand built a boat in his basement and then had to demolish part of the house to get it out.
                        Luckily you can put a 1UZ in this and it will still be able to get out of the driveway
                          Not a huge amount of progress this week, as it has spent most of the week lashing down with rain. In between the downpours i managed to fully weld up the basic tray, and it is still within a degree of warp. Good enough.
                          Then I set about figuring out how the under tray drawer was going to mount, and I am leaning towards this solution, which uses ears mounting that hang off the drawer and also off the tray.
                          Welds in blue, 2x M8 high tensile bolts in red, and 4x 4.8mm stainless rivets in green, with the drawer bracket also sikaflexed in place for sealing and general vibration resistance.
                          After that solution was partially sorted it was time to figure out what sort of tail light panel arrangement works well:
                          And then replicate it with actual metal:
                          I also added some 50mm RHS posts for a future rear hoop, and started working out if the old tray sides will suffice for now (until i can find some OEM Toyota ones to butcher).
                          And then realised i had these tiedown mounts still lying around, and so added some brackets for them:
                          After knocking back all the welds it looks like this:
                          The rear light panel gives me a reference point to be able to figure out where the wheel boxes should be mounted. Which is kind of here I think.
                          Now just waiting for the aluminium sheet to clad the tray and then I can set about painting it and mounting up the canopy.
                          While i was waiting I started refurbishing the old ARB bar that has seen better days. So many holes to be welded up from the bodgy side marker lights. Heaps of them dont even have sufficient wiring clearance (nor properly drilled holes) so i can only presume that a lot of them were non functional:
                          Anyway, after some welding, removing the roller hawse mount, and a TON of grinding and flap discs it now looks like this:
                          Still need to fill in the old winch clutch access hole because the new winch has the clutch knob on the passenger side. Plus I think i am going to have to weld up the other access holes which are just useless now as the spotlight mounting plates were cut off the bar when I got it. That will leave me with plenty of room to properly situate my lights and the winch controller. Hopefully wont be too much of a pain...
                          Anyway, aluminium sheet is on its way from the supplier. So I may even get to fitting that and finishing the tray this weekend.... :o
                          Oh, and the keeneyed might notice that the ute has been turned around in the later shots.... yes it fit out of the back yard
                            Looking ace.
                            Norbie!
                              keep going i wanna see more box section
                              rocksliders
                              brush bars
                              exo-cage
                              www.holditflat.com
                                rocksliders
                                brush bars
                                exo-cage
                                Hahaha, why do that in box section? Especially when I have a new tube bender and a length of 38mm tube that was mistakenly ordered as cage tube but doesnt fit the right specs...
