Ex ADF Unimog.
    Ex ADF Unimog.
    I’ve always wanted a Unimog because reasons. As I’m going to start building a shed in my back yard I thought that was as good of a reason as any. So last week I purchased one.
    It’s pretty easy to drive with the 8spd box. On road you start in 5th and you’re in 8th by 50kph to the dizzying top speed of 85kph at 2,800rpm. There aren’t any puttabarrainitforfiftybucksanddomadskidsplans just some taller tyres to help try and get it to sit in 90kph at about the same revs. Will do WTA intercooler and maybe a more modern turbo to help it do a few more KPH up hills along with a little injector pump tweaking. Will also fit EGT gauge.
    Yeah, this things is all sorts of win!
    As this will be so good out on the open road blacktop, when is the first of many round Aus trips to commence?
      Lambo to unimog. I like how you tick all the boxes Uncle
        well, colour me incredibly jealous.
          Was waiting for this thread. Have wanted one of these since I was a kid.
          What is the crane reach/capacity?
            What the fuck is going on with the 3 rings of studs on the wheel? Two I get, but three?
              Larry Perkins does an overdrive kit to help with the cruising speed.
              (TM - AVENGE)
                Drop gear drive.
                  Fuck yes, I used to dream of getting a 404 Mog.
                  6L FD3S RX7
                  GR Supra
                  Jeeps JK, CJ7, WK2
                    Off the top of my head 1.3tn at 3.1mtrs and 890kg at 5.1mtrs.
                      Yeah portal hubs as Slides said.
                        Ok you have me for jealous. That is all.
                          At $20k the ROI isn’t there. 2 years ago you could get the OD from Merc for 10k now it’s double the price for 15kph.
                            Tradie I did my apprenticeship for got a job working on these things...bucket list item.He rates them highly.
                              There is an element of clown shoes hilarity to it. On the (long) drive home I pulled up next to a New Dodge Ram in full Boomer spec. Chrome wheels, lift kit and running lights. Rams roof height was below door window height. We all knew who had the smallest genitalia at that set of lights I’ll tell you.
