{edo joke}
My Suzuki 1402cc turbo
All together, but the clutch is not biting. I took it for a 100m ride and the clutch takes up really late, and as soon as the throttle is opened (well before boost) it spins to redline. Something as simple as needing to be bled?
It's just strange, as this is what it did on the way back from the dyno. It rode fine for the first few minutes then just suddenly spun straight to redline, then wouldn't really bite at all. Wasn't really an issue as I know from the other few people that have turbo'd these that the stock springs are no good at this power level. So, I upgraded the clutch springs... but first ride and it slips exactly the same.
Thoughts?Originally posted by 350stato100% agree with Shifty
^ I proper lol'd.Pest Control - Brisbane, Gold Coast, Ipswich and South West QLD PF discounts apply.
Nah it's only a back-torque limiter. It's square drive forwards, angled drive backwards.
As the clutch slave is sort of an integral part of the clutch, I wonder if there's some trick I needed to know - perhaps I'll read the destructions?
Bled the fluid this morning, it's fine.Originally posted by 350stato100% agree with Shifty
Insufficient preload on the clutch springs?"Where can we get hold of a Vincent Black Shadow?" "Whats that?" "A fantastic bike," I said. "The new model is something like two thousand cubic inches, developing two hundred brake-horsepower at four thousand revolutions per minute on a magnesium frame with two styrofoam seats and a total curb weight of exactly two hundred pounds."
I'm not sure about that. The lever is heavier than it was before, so there is obviously more clamp, but it does bite a lot later in the lever travel.
The springs are torqued and loaded to spec and although they're shorter than the stock springs, the spring shop was aware of the loaded height & deflection so it would be fair to say that this has been taken into consideration. All they do is make springs, so it would be reasonable to run with the assumption that the springs
The other thing is that the bike rode fine when I left the dyno, but about 5km up the road the clutch slipped straight to redline.
The only thing I'm thinking is... it's slipping now like it was before so I'm wondering if (although the clutch needs to be upgraded anyway) there is another issue that has actually come up and I've just jumped to the conclusion that the springs were the problem.Originally posted by 350stato100% agree with Shifty
Just had a thought - what oil have you been running?"Where can we get hold of a Vincent Black Shadow?" "Whats that?" "A fantastic bike," I said. "The new model is something like two thousand cubic inches, developing two hundred brake-horsepower at four thousand revolutions per minute on a magnesium frame with two styrofoam seats and a total curb weight of exactly two hundred pounds."
Yeah, I figured you'd be using a good bike specific oil - lotta people don't, and wonder why their clutches slip.
Could be the slave cylinder hanging up/pumping up? Thinking about it some more, the slip up to redline sounds more like it's not engaging properly more than the clutch pack slipping..."Where can we get hold of a Vincent Black Shadow?" "Whats that?" "A fantastic bike," I said. "The new model is something like two thousand cubic inches, developing two hundred brake-horsepower at four thousand revolutions per minute on a magnesium frame with two styrofoam seats and a total curb weight of exactly two hundred pounds."
ha.!
