My Suzuki 1402cc turbo
    did you run the oil drain into a little tank then into the pump?
    is the turbo a ball bearing? if so you will need a restrictor..
      conventional bearing oil cooled only, general internet sp33k has been that i will not ned a restrictor.
      hose to oil pump is fairly flat but pump inlet is well below turbo outlet so this shouldn't be the problem
      Originally posted by 350stato
      100% agree with Shifty
        disconnect oil feed and turn pump off and run it, see if smoke clears.
        wont hurt it if you run it no load for a minute I'm sure.
          fair call
          no load, low rpm and low temp will be fine
          will do the same with the return as well, will disconnect the pump and see if it gravity drains into a container
            Kill the ignition and take off the hose to the tubo- if you have litres of flow then you found the problem. Did you run it for a while? The oil and crap inside the manifold and turbo take a while to burn off.
            Oh and are you sure it isn't fuel smoke? Does it smell like oil?
              Yeah I'll disconnect the hoses tonight and see how much of a mess I can make.
              It's blue as your balls mate, definitely oil haha. Ps how good is that pic of you that Dale put up? Pps love the sig
                Nah I fucking seriously hate it bud. No shit.
                  By the way;
                  3SGTE... going into something... sometime.
                  What happened? Got rid of the Corolla?
                    what pic did i put up?? LOL i cant remember
                    the only way i found these little pumps work is to run the oil into a sump and then pump it out,
                      scavenge pump is working fine... i had the line off it and the farker shot oil two feet from the bike
                      the exhaust tip (post muffler) is wet with oil, the dump itself was fairly wet and there was a little pool of oil in the turbine housing
                      i think i just need to connect everything back up again, bleed the brakes and take it around the block. can't really achieve much free-revving it in the driveway, other than pissing of the neighbours
                      out of interest gave it a spin to redline and it makes turbo noises even with no load. woo!
                        if we don't hear back from you in 20 minutes....
                          Nah bleeding the brakes is a carnt of a job on this thing, is a job that should involve less mozzies & more daylight.
                          So, based on the oil in the exhaust and the fact that the plugs don't seem to be fouling, it's fair to say that we are down to one of three issues:
                          fucked turbo oil seal
                          too much pressure/flow
                          scavenge system not working/inadequate
                            yep rolla gone, young bloke had someone crash into him and bought the car off me to put his 100kw running gear into. glad it's gone to a good home.
                            also sold the fwd-specific running gear (shafts, box) so if I don't sell the 3sgte it will be going into something rwd
                            although at the moment i'm doing fuck-all of anything until this bike is a goer
                              Wrong Dale Dale :D
                                does the turbo's oil drain have somewhere to pool? or does it go straight into the VDO pump?
                                perhaps some kind of 'mini-sump' might be required for the times when the pump can't keep up with the amount of oil that the engine pushing into the turbo's core...
                                also , what kind of voltage does the pump get at idle?
