1980 GXS 750 - resto project
    Well I've finally bitten the bullet and gotten a new (to me) bike after being bike-less for about 8 years
    I'm now the proud owner of a 1980 GSX 750. It's a fixer-upper so it'll be a while until I'm back on the road but it'll be a fun process getting her back up & running.
    Here she is in all her glory:
    The plan is to end up looking something similar to this:
    Plan is to just get it running and source missing parts (front calipers, instrument cluster) then trim the seat and paint the tank & panels.
    I love the look of the bike on the beach but don't think a light as small as that will the registerable here. Will most likely go a round light (or possibly keep factory - will depend on the cluster I get). Also I want the seat to be practical so instread of a full café racer style seat I'll go something similar to this:
    Then ditch the factory taillight (as it's massive) and go some small round flush mount LEDs - mounted in something similar to the below setup:
    Current plan for paint is a dark metallic blue for the guards & side panels then a dark silver with red & blue stripes. I have NOS badges for the tank so want it to look like it could have been a factory Suzuki scheme.
    don't ask to ride my bike and i won't ask if i can shag your missus
    I have a set of GSX front calipers.
      Also, these look epic with the seat shortened and the stock tail light.
        Fuck yeah!!! What would you want for them?
        I was thinking if I had to purchase I'd try to see if I can get something more modern to fit but less fucking around sounds so much better....
        That pic below looks awesome too. I like the idea of being able to pillion someone though.
          Also have a GSX1100 alloy swinger hanging in the shed - will have to check if it's the twisted one.
          If you want to upgrade brake wise, I designed a kit that uses SV650 calipers and VFR800 300mm discs that bolts straight on (well, with brackets).
          Slot a stock front disc onto the rear - exact same size, but 500gm lighter or somthing stupid too.
          Let me dig out what I've got and I'll PM you
            Legend - cheers mate!!
              Well slight hiccup with the brakes in that the calipers didn't fit
              I've sourced the R hand one out of the states, just on the hunt for a L (worst case scenario the L one is somehow still available from Suzuki new as a genuine part).
              Looks like the seat re-trim is out of the question as my seat pan as rusted to buggery (apparently common as on these) so I'll be going a scrambler style bench seat.
                Left hand one should be easy to find - same as GN250 according to the parts fische!
                Sorry that those calipers didn't fit - who'd have thought there was a single year GSX750 with unique calipers!
                  LH caliper sourced & on its way from NZ!
                    I pulled apart the seat today to see if it was salvageable & with a re-trim & re-shape.
                    I'd say the pan is pretty much cactus:
                    Love the random plywood repair...…
                    So definitely an eBay seat job now. Am thinking a cheapy to test fit then re-cover that if need be. Something like this:
                    https://www.ebay.com.au/itm/Universa...0762ad01a547f2
                      Wow that seat base really is past its used by date.
                        Looks like I lost a few posts in the forum shenanigans....
                        I now have two front calipers & the HEL lines should arrive Monday!! I've bought a heap of new cam cover bolts (most were missing) and gave to get new tacho input assembly (all still available from Suzuki).
                        eBay spec seat arrived yesterday - just sitting in place I think I like it but am concerned it may look too small once everything is trimmed off:
                        Also new headlight arrived - I went a 6.5"
                        Looks big in the photo but its about a foot closer to the camera than the stock light
                          Was bored this arvo so started pulling off bits.
                          Light, rear plastics & indicators all gone:
                          Was considering Gammaboys look in the pic above:
                          (I've a 53cm seat which I think may be too short - will also get a 63cm one then decide where to cut once I have both....)
                          My HEL lines arrived so I now have front brakes!!!!
                            Finally pulled my finger out and spent some time this arvo checking if the engine will turn over and everything move as it should but hit a pretty major hurdle straight away
                            Took the cam cover off & noticed that each of the camshafts aren't bolted down at one end :o I'd say someone has used this as a parts bike at some stage!!!!!
                            The little semicircle bracket without a part no. between 5&6 is what I need...... (as well as 2 each of 5 & 6 I guess)
                            I called Mick Hone in Melbourne & they said these won't be a separate part & will be part of the head itself *FUCK*
                            So I either need a spare head or see if I can get someone to machine me something up.........
                              Cam lobes look rusty?.
