VN Bogandore
    right, got it back from having a wheel alignment. Paid my $20 and got a UVP. I was nervous as hell driving it, because what the UVP legally covers is very ambiuous, and the few cops I have asked have never even heard of a UVP, meaning if I got pulled over I'd be relying on them believing the paperwork.
    It drove really well, though the gearbox is mushy and I nneed to fix an exhaust leak that has developed. Everything else is good! Drove great on the way back... fuck I got some looks
    wheel alignment guy had a whinge because I had jammed the adjustable strut tops hard over to set the camber from "upright" to "aircraft wings" and it bent the needle on the wheel alignment machine, because it only measures to 3 degrees negative haha! They set it to 3 1/4 degrees neg which will do me fine to start with. I can see I'm going to have to invest in some aligning gear though.
      Pyrometer is all you need Jim...
      Classic Auto Fabrications:
        pyrometer?
          It measures how damn hot your VN really is...
            Measure tyre temp at the track, lean in more if the outside is hot, straighten up if the inside is hot, leave as is if it is even heat from side to side.
              ahh okay.
              changing camber messes up the toe tho, cbf'd doing a full alignment at the track.
                Need adjustable strut tops then.
                  it has adjustable tops, but it will still change the toe
                    anyone around on satuday to help me fit the clutch in the applause and fix the exhaust on the commo? Also need to replace battery terminals and fix the seat mount I forgot to finish off but remembered at 4am last night.
                      two bits of bar and some string?
                      Royalpurple Oils
                        my brother has just finished putting a gen 3 in his VN was a pretty straight forward swap only thing he is waiting for now is his powerglide to be built, if you run into any problems let me know and i might be able to help!!!
                        When are we fitting the LS1 hotness?
                          um, fuck yeah!
                            looks awesome! (except for the yellow and the carby lol)
                            Was there a reason why the motor wasn't moved back further in the bay?
                              Fuck I'd offer my limited assistance but I'm doing a clutch in my Ford. Sorry...
                              as an example, an elephant pushes over a tree to eat the fresh leaves at the top, but a human isnt allowed to build a machine that makes a car so he can drive around to places quicker?
                                fix your shitty ford on sunday then. priorities man!
